03-02-2012, 12:23 PM
Who makes the OEM O2 sensor?
Car: 97 Legacy L Wagon
Anyone know who makes the OEM oxygen sensor for our generation of Legacys? I've heard it might be bosch or desno.
03-02-2012, 01:15 PM
Car: 1998 Legacy Brighton
i just replaced mine last week, it was a bosch.
03-02-2012, 09:06 PM
I believe its DENSO. They make a bunch of factory stuff in our cars.
FYI - you can pick up DENSO o2s for cheap on ebay and amazon. I just ordered one for 40 bucks
The Following 2 Users Say Thank You to broknindarkagain For This Useful Post:
03-02-2012, 10:19 PM
I know, I love Amazon. I buy nearly all my parts there.
The Densos are showing as $55 for my model though.
03-03-2012, 11:27 AM
Car: 1997 Legacy L Wagon, EJ25D
Get the Denso's. Bosch are 100ish from an auto store. And if their spark plugs vs. the Japanese NGKs are any indication, it's best to keep our cars speaking Nihongo
03-03-2012, 11:28 AM
That's Japanese for Japanese, in case Nihongo o hanashimasen
03-28-2012, 10:45 AM
Replaced it last night. Only had a 22mm flare nut wrench from harbor freight, wouldn't come out with PB blaster, or after warming the car up. But after I heated the sensor with a torch, it came right out. When I do it again, I'll use the SAE version of the wrench, the 22mm was definitely not a perfect it and started to strip the sensor a little.
Also, the sensor I pulled was a Bosch  Maybe it was replaced before, but I have all the services records dating back to 2000, and it's not in there.
03-28-2012, 11:06 AM
Car: 98 BG GT 5MT EJ25
i just got a universal o2 sensor from Bosch and just had to splice the wires its not hard just a lil time consuming but much cheaper
09-13-2012, 02:17 PM
Car: 1998 Subaru Legacy GT
What special socket should I use to replace the O2 sensor ?
There are some with a cut away for the wire, anybody use these ?
Or will a 7/8 " socket or other size wrench work ?
09-13-2012, 02:19 PM
Originally Posted by silentguy
If I remember correctly, that wont fit.
09-13-2012, 05:42 PM
Car: 95 BK, 93 SS!
I've used a large crescent wrench. Luckily my sensor wasn't seized.
09-13-2012, 05:46 PM
Car: 04 Legacy NA (rip), 07 2.5i, 96 Outback
7/8 will work. But if OP is going to work on Subaru's constantly, he needs to get metric. In this case 22mm. (corrected. thx Jamal, guess I can't convert in to mm, and my memory is toast)
If you can, use a vise grip or similar to hold the bung.
I ripped one right off the weld and had a hard time getting it rewelded.
O.
Reason: correcttion
09-13-2012, 08:32 PM
Car: 1991 Legacy Wagon 5MT
If you have an advance nearby I know they have loaner O2 sensor sockets
09-13-2012, 08:41 PM
Car: 98 2.5GT
should be 22mm. If it's really in there a socket is a good idea to keep from rounding it off.
