Go Back   Subaru Legacy Forums > Technical Forums > Tuning
Reload this Page Why so much lag?!?
Page 1 of 3 1 23 >
#1: 09-11-2012, 12:17 AM
Why so much lag?!?
 Diavolo
Diavolo's Avatar
Car: 2005 Legacy GT
Send a private message to Diavolo Find all posts by Diavolo Reply With Quote
2005 LGT
5spd manual
107k miles
Protuned
Supporting mods:
3 inch Invidia TBE
Invidia Up pipe
HBC manual boost controller
K&N Air Filter (panel)
Stock top mount IC, re-enforced endtanks.
I was tuned almost exactly 1 year ago.
Had the up pipe put in a few months back and the tuner made a slight map adjustment after install.
No mods since the tune.
Haven't had a problem until recently.
First I thought my exhaust sounded a little different.
More like the static/farty sound of an older WRX.
My car was hitting around 15psi, when it should be around 17psi.
I hope it's just some kind of leak.
All my hoses and vacuum lines seem good and tight.
I did not do a good inspection yet to the upipe/turbo/downpipe gaskets.
It's slow to build boost in gear on the highway, and feels like it falls flat on its face when I upshift under throttle. If i try to launch, it will just crap itself and then start to go.
What do you guys think?
Diavolo
Find More Posts by Diavolo
#2: 09-11-2012, 01:53 AM
 wengermi
wengermi's Avatar
Car: 2007 Spec.B
Send a private message to wengermi Find all posts by wengermi Reply With Quote
when was the last time you did a tune up? you can try sea foaming your pvc line to clean your valves and also putting some in your gas tank to clean your injectors. hows your idle? when you let off the gas does your car idle seem normal?
wengermi
Find More Posts by wengermi
#3: 09-11-2012, 03:18 AM
 Schrei Wolf
Schrei Wolf's Avatar
Car: 08 DMG LGT 5MT Sgt 1
Send a private message to Schrei Wolf Find all posts by Schrei Wolf Reply With Quote
.... Why do you have a MBC? The car comes with an electronic boost controller!
Schrei Wolf
Find More Posts by Schrei Wolf
#4: 09-11-2012, 09:33 AM
 wengermi
wengermi's Avatar
Car: 2007 Spec.B
i missed the manual boost controller... my buddy blew up his sti because of one of them. thats probably whats causing it.
wengermi
#5: 09-11-2012, 12:23 PM
 dr_sharp
Title: eat a what?
Car: i ride a bike
Send a private message to dr_sharp Find all posts by dr_sharp Reply With Quote
probably a leak somewhere
lol
The Following User Says Thank You to dr_sharp For This Useful Post:
LosAngelesLGT (09-11-2012)
dr_sharp
Find More Posts by dr_sharp
#6: 09-11-2012, 12:38 PM
 mumblinaviator
mumblinaviator's Avatar
Car: '07 Spec.B 18g Cryo Tuned
Send a private message to mumblinaviator Find all posts by mumblinaviator Reply With Quote
Sounds like a leak... maybe that pesky T connecter under the IC. Definitely check the MBC as well.
What does it sound like when you let off the gas on boost? Do you get the Psssssh from the BPV, or does the turbo flutter?
+1 for sticking with EBCS esp at mild Stg 2!
mumblinaviator
Find More Posts by mumblinaviator
#7: 09-11-2012, 01:46 PM
 Spec B
Spec B's Avatar
Title: JDM tuner wanna be
Car: Spec B- FP HTA68'd up E-Ocho Cinco Stilo
Send a private message to Spec B Find all posts by Spec B Reply With Quote
+1 for needing to sea foam...fixes most boost problems.
The Following User Says Thank You to Spec B For This Useful Post:
seabass07 (09-11-2012)
Spec B
Find More Posts by Spec B
#8: 09-11-2012, 04:54 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
1) Check the T under the TMIC.
2) YTF are you using a MBC...
iNVAR
Find More Posts by iNVAR
#9: 09-11-2012, 04:58 PM
 seabass07
seabass07's Avatar
Car: 05 OBXT 5eat stg 1
Send a private message to seabass07 Find all posts by seabass07 Reply With Quote
Sudden raspy exhaust note plus slow spool? Sounds like a stuck injector. :facepalm:
seabass07
Find More Posts by seabass07
#10: 09-11-2012, 05:05 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
3) Post logs.
iNVAR
#11: 09-11-2012, 07:40 PM
 Diavolo
Diavolo's Avatar
Car: 2005 Legacy GT
My tuner suggested the MBC. Heres a post he made about why:
http://www.iwsti.com/forums/ecu-tuni...-i-need-7.html
Diavolo
#12: 09-11-2012, 07:42 PM
 Diavolo
Diavolo's Avatar
Car: 2005 Legacy GT
I still get a PSSSSHHH!
hmmm,... sometimes my car has start up problems.
I thought it was just the starter drying, but could this be causing that too?
how does an injector get stuck?
Diavolo
#13: 09-11-2012, 07:45 PM
 dr_sharp
Title: eat a what?
Car: i ride a bike
if your tuner is EQ Tuning he seems to be arguing with EFI logics which is a highly respected tuner for the Subaru community. There are very few people who think MBC > EBCS.
Or are you saying that you adjusted your MBC after the tune???
lol
dr_sharp
#14: 09-11-2012, 07:46 PM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
A starter failing would be simple. If its turning over at a good pace that's not your starting problem. I would say to much fuel during cranking from a stuck injector like said before
Sent from my Galaxy Tab using TapaTalk 2
Originally Posted by Stang70Fastback View Post
Clearly, the solution to shit breaking is to break more shit until the shit works again.
I'm Dumber Then I Seem, Remember That, I Won't.
Swagon_Wagon
Find More Posts by Swagon_Wagon
#15: 09-11-2012, 08:17 PM
 Diavolo
Diavolo's Avatar
Car: 2005 Legacy GT
no, i know better than to mess with it.
I was just posting that link since so many people asked why I have one.
Back to topic...
Diavolo
Page 1 of 3 1 23 >
