Go Back   Subaru Legacy Forums > Technical Forums > Tuning
Reload this Page wideband for logging
#1: 11-17-2012, 03:29 PM
 haycock
haycock's Avatar
Car: 05 lgt cryotuned 18G fmic
Send a private message to haycock Find all posts by haycock Reply With Quote
I'm going to be doing some logging and want to hook up my wide band to the laptop.
I bought a plx wb and got the cable to go from the module to laptop so if i plug it in to the laptop will ecuflash automatically read it? I'v searched with no answers.
Thanks,
Bryan
haycock
Find More Posts by haycock
#2: 11-17-2012, 08:51 PM
 bnguyenbb6
Car: '06 LGT / '10 Forester 2.5i
Send a private message to bnguyenbb6 Find all posts by bnguyenbb6 Reply With Quote
Use Ecuflsh for writing to the ecu. Use RomRaider for logging. There is a plug in for plx I believe.
bnguyenbb6
Find More Posts by bnguyenbb6
#3: 11-18-2012, 07:34 AM
 joeleodee
joeleodee's Avatar
Car: 1863 Covered Wagon Deluxe
Send a private message to joeleodee Find all posts by joeleodee Reply With Quote
Yes, what he said.
Moving forward, once romraider is reading data, you will have to click on plugins and select your respective wideband sensor and switch the com port to which one on your laptop you have it plugged in to. Then go to the 'external sensors' tab and check the box that corresponds to your sensor. After that, it should read.
Check this thread for reference to your wideband.
http://www.romraider.com/forum/viewt...3e429fa472e55c
joeleodee
Find More Posts by joeleodee
#4: 11-18-2012, 08:15 AM
 haycock
haycock's Avatar
Thanks for the replies. I think i got it.
haycock
