Reload this Page Grinding/Screeching Startup Sound
#1: 02-24-2011, 10:27 AM
 rathoughts
Send a private message to rathoughts Find all posts by rathoughts Reply With Quote
Ok. I have searched around and have not found a good answer, or one I like, about my issue. So, my car has been acting weird as of late. It seems that when I startup the car in the mornings, it makes a loud screeching noise and immediately goes away. I brought in my car and Subaru told me that it was my belts since it was almost 100k. So, I did the work and it cost me a whooping >$1000. But that didn't fix it and I brought it back to them. They said that it was a matter of just adjusting the belts since they are new so I went a long with it. Well...that didn't fix it and I brought it back to them a third time and they kept it overnight and called me back and said it was my starter. I don't buy it because they should have diagnosed it in the beginning before immediately trying to jack me for $1000.
Anyways, I wanted to see if anyone had the same issues. Also, what I have noticed was that my interior light level indicator randomly moves for 5 to 6 at times. And I used to have random CEL with rough running before but that went away.
Any suggestions would be greatly appreciated.
My car info:
- 05 Subaru Legacy GT Limited
- 98K
- Second owner
- New belt
rathoughts
Find More Posts by rathoughts
#2: 02-24-2011, 11:04 AM
 boymk123
boymk123's Avatar
Car: Martin bicycle
Send a private message to boymk123 Find all posts by boymk123 Reply With Quote
when they told you belt, what belt? timing belt or AC, ATernator belts? if it was the AC, AT belts, I think you got scammed... if it was timing belts, yea it is $1000
I had this problem before, my AC, AT belts were loose, so I had it all tighten up for $30 and no more sound (mine sound like sweaking tho)
boymk123
Find More Posts by boymk123
#3: 02-24-2011, 11:43 AM
 citka
citka's Avatar
Title: Donating My Member
Car: 05 Blk/Blk MT OBXT
Send a private message to citka Find all posts by citka Reply With Quote
This sounds like the starter issue. Search the forums, you'll find our 05's (and mabye others) have a noisy starter on initial startup in the cold. Try starting it cold, and releasing from the "Start" position to the "On" possition just a 1/2 second earlier. If it goes away with that, it's the starter issue. I'm thinking of replacing my starter for this specific reason. It's nothing that will hurt your motor, but REALLY annoying.
citka
Find More Posts by citka
#4: 02-24-2011, 01:03 PM
 rathoughts
It was the whole thing, timing and AC. That is what is making a little ticked off. I told them about this noise and before they even looked at it, they said it was the belt.
Now, they are saying that it is the starter. How can I test that it is the starter or not?
rathoughts
#5: 02-24-2011, 01:04 PM
 rathoughts
Are you saying, put it in the Start position, wait for 1/2 and then ON? It is really annoying and painful to hear. I am debating whether to wait on it and see.
rathoughts
#6: 02-24-2011, 01:12 PM
 miro123
Car: '05 Legacy 2.5GT
Send a private message to miro123 Find all posts by miro123 Reply With Quote
Ive been trying to figure out what that sound was as well. It occurs from time to time but mostly when its really cold out. If it starts occuring more often guess ill have to replace starter as well.
miro123
Find More Posts by miro123
#7: 02-24-2011, 02:29 PM
 citka
citka's Avatar
OP, no...I'm saying put your key in and crank it over as usual. Just stop the cranking a split second earlier than you normally would.I'm not sure why it works, but it does.
I think it has to do with the armature in the starter getting sticky.
citka
#8: 02-25-2011, 09:42 PM
 DGMwagon
Send a private message to DGMwagon Find all posts by DGMwagon Reply With Quote
My car makes that same sound when it's really cold out, but when I plug in the block heater it starts up much quicker and without the squeal. It seams like the colder it is the longer and louder it squeals, which makes me think that it could be a starter sound. With the thicker cold oil the starter has to work harder to turn over correct?
DGMwagon
Find More Posts by DGMwagon
#9: 02-26-2011, 07:52 AM
 shaneomac1602
Car: 2005 OBP LGT 5MT Stage 2
Send a private message to shaneomac1602 Find all posts by shaneomac1602 Reply With Quote
does anyone have an audio or video clip of this? i heard something similar one day and want to know if i heard the same thing.
shaneomac1602
Visit shaneomac1602's homepage!
Find More Posts by shaneomac1602
#10: 02-26-2011, 12:18 PM
 ArcyBuru
Car: 2005 Subaru Legacy Wagon 2.5i (MT)
Send a private message to ArcyBuru Find all posts by ArcyBuru Reply With Quote
Although I'm new to the Subaru community, the owner I just got my Legacy wagon from said he had something that sounds very similar to what's going on with yours. He had the dealer fix it with new tensioners and belts. If I recall he said one of the belts was loose or something along those lines.
ArcyBuru
Find More Posts by ArcyBuru
#11: 02-26-2011, 04:33 PM
 CMull123
CMull123's Avatar
Title: BOOM!
Car: 2005 Legacy GT 5MT
Send a private message to CMull123 Find all posts by CMull123 Reply With Quote
If what you're describing is what it sounds like, definitely the starter.
You say it's when you start up and immediately goes away. Immediate as when you turn the key? If it were belts, they'll generally start to screech a few seconds after startup when cold and go away a few seconds after and may return quickly if you turn your wheel to full lock or very close, as in backing out of a parking space or something similar.
If it's your starter, like mine is, the sound starts right as your engine fires. What mine sounds like is the armature, the part that turns the flywheel, stays extended for a very small amount of time after the engine is already running, usually about 1/2 second, and grinds on the flywheel teeth.
My mechanic offered me a starter with lifetime warranty installed for about $250 and I thought that was pretty steep, so $1000 for sumthin you didn't need is WAY worse. I'd ask to talk to the Service Manager and see if they can help you out, since they gave you really shitty service and didn't even wanna hear the problem before telling you it'd be a grand to fix it.
If being polite doesn't work, then start being a dick. Remember, the squeaky wheel gets the grease.
CMull123
Find More Posts by CMull123
#12: 03-15-2011, 11:33 AM
 KC05Leg
KC05Leg's Avatar
Car: '05 SWP LGT Limited - 5EAT
Send a private message to KC05Leg Find all posts by KC05Leg Reply With Quote
I had the same issue this winter. Spray a small amount of WD-40 into the pully on the AC Compressor. You will see where the belt moves, so spray into the cracks directly next to the belt, w/o spraying the belt. Fixed it instantaniously for me.
KC05Leg
Visit KC05Leg's homepage!
Find More Posts by KC05Leg
#13: 11-12-2012, 07:31 AM
 Ostrowrx
Ostrowrx's Avatar
Car: 2010 Legacy GT Limited
Send a private message to Ostrowrx Find all posts by Ostrowrx Reply With Quote
Dont use wd-40 on your belts it will only last a few days, They make a belt dressing found at any auto parts store for your belts. This is clearly a starter issue and wont help anyways!
Ostrowrx
Find More Posts by Ostrowrx
#14: 11-12-2012, 07:35 AM
 derooi_07
derooi_07's Avatar
Car: 2005 LGT Limited 5EAT
Send a private message to derooi_07 Find all posts by derooi_07 Reply With Quote
Have the same issue. Only when its very cold tho.
derooi_07
Find More Posts by derooi_07
#15: 11-12-2012, 09:31 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
It's the starter, we all know this is a issue with these cars.
Replace it with a rebuilt unit or pull it, grease the shaft and put it back in.
Max Capacity
Similar Threads
New Clutch = Bad sound? shuttersub Fourth Generation Legacy (2005 - 2009) 4 10-10-2010 12:30 AM
sound stage quastion: how to avoid midbass and bass cancellation? markc0220k Interior/Audio 15 09-17-2010 01:02 AM
Wierd Air sound under full throttle RODMAN Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 3 11-03-2009 03:33 PM
Unknown knocking sound... SlightlyEvil Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 10 01-07-2008 11:56 AM
