Reload this Page Help! Driver door handle removal (exterior)
#1: 10-03-2010, 07:20 PM
 doccrowley
doccrowley's Avatar
Title: Wagonmeister
Car: 06 RalliSpec'd GT Wgn 5EAT
Send a private message to doccrowley Find all posts by doccrowley Reply With Quote
Driver's door handle broke yesterday. Have to open door from inside now.
I need help figuring out how to remove the door handle so I can replace it. Anybody done this?
I got the door panel off, removed the bolt that retains the lock in the handle and removed the other bolt. Handle now has approx 1/8" play from car but won't release completely. Does the handle snap in place or have I missed another bolt that is keeping me tied up?
Help..... Also, is it easier to replace the handle if I remove the window?
Thanks for the help.
doccrowley
Find More Posts by doccrowley
#2: 10-09-2010, 05:18 PM
 doccrowley
doccrowley's Avatar
Title: Wagonmeister
Fixed! $29 for door handle, $15 rattle can of Regal Blue Pearl, $20 for paint shop friend to finish the new handle and I'm back on the road again.
Handle removal is quite easy if steps are followed in the proper order. 2 bolts to release the handle. Pull the lock cyclinder out of the way (inside and down). Handle snaps in place with 2 little tabs on the bottom. Pop the two tabs clear from the inside out. Tilt bottom of door handle up towards top of door from the outside. Handle will now clear the door without even having to remove the rod that connects to the door latch.
FYI: early production '06 door handles are different than the late '06 production models. Only your VIN# will determine which handle is appropriate for your car, according to the dealer.
Late '06 model door handles are built better than the early ones, and I decided to see if one would fit for me. VIOLA'! Fitment is the same, design is stronger for the updated late model '06 updated handle and the function is identical. Just make sure you use the new rod that comes with the new handle. Repeat, the rods are not interchangeable between the 2 door handles.
$60 bucks sure beats the $182 quoted by the dealer to R&R the door handle for me. Yikes!
doccrowley
#3: 01-18-2011, 04:27 PM
 wcbjr
wcbjr's Avatar
Title: Ooooo, pretty colors...
Car: 2006 Legacy GT
Send a private message to wcbjr Find all posts by wcbjr Reply With Quote
Did you have to remove the window to get access to the two bolts?
I forgot what I was supposed to remember.
wcbjr
Find More Posts by wcbjr
#4: 04-11-2011, 03:05 PM
 Uncle Sizzle
Send a private message to Uncle Sizzle Find all posts by Uncle Sizzle Reply With Quote
I know this is an older post, but can you explain how you got the second bolt out of the handle? The one is easy, but it appears that my window is blocking the second bolt... Do I need to completely remove the window?
How did you convert the handles over for so cheap? I can’t even find used ones for under $50…
Shout out to wcbjr! thx for the help getting my door open. something tells me we are battling the same problem.
Uncle Sizzle
Find More Posts by Uncle Sizzle
#5: 02-12-2012, 04:29 PM
Bolt problem
 Goldar
Send a private message to Goldar Find all posts by Goldar Reply With Quote
I just repaired my door handle after it broke and the missing step from this thread is to remove the front bolt with window up and then roll the window down to remove the second bolt. Hope that helps the next person to come along with this problem!
Goldar
Find More Posts by Goldar
#6: 07-29-2012, 11:49 AM
 GTN8
GTN8's Avatar
Car: 05 legacy gt sedan
Send a private message to GTN8 Find all posts by GTN8 Reply With Quote
Thanks. Saved me a headach
GTN8
Find More Posts by GTN8
#7: 07-29-2012, 12:41 PM
 SpeedNeeder
SpeedNeeder's Avatar
Car: 2005 LGT LTD 5MT, Garnet Red Pearl
Send a private message to SpeedNeeder Find all posts by SpeedNeeder Reply With Quote
How do I get a part number to order one online?
My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew)
SpeedNeeder
Find More Posts by SpeedNeeder
#8: 11-19-2012, 04:19 PM
 UTwrestler22
UTwrestler22's Avatar
Car: Stage 2 05 OBP LGT sedan
Send a private message to UTwrestler22 Find all posts by UTwrestler22 Reply With Quote
Doc, what do you mean by taking the rod also? I'm about to go to the junk yard so i don't think ill be able to be much of a chooser. 05-09 outback should fit as well right?
UTwrestler22
Find More Posts by UTwrestler22
#9: 11-19-2012, 05:16 PM
 doccrowley
doccrowley's Avatar
Title: Wagonmeister
There was a design change mid-year 2006 where your VIN is required to get you an exact match if you only replace the handle. There are plastic clips that attach rods to your door handle. (Driver's door handle has 2, one for lock mechanism, one for the handle to open the latch). I'm assuming that all other door handles only have one clip attached to a rod that pulls the latch when you lift the handle. (assumption because I've only dealt with the driver's door handle)
So, unclip the rod from the door latch, then pull the handle assembly with the rod for your application. Don't just grab the handle and leave the rod attached to the door. You likely won't have all that you need if you leave the rod behind in the donor car.
FYI: Also, I went to NCS (national coating supply--I think) on 33rd south and 2nd West to have them make up a matched rattle can of Subaru paint. It is color matched, 'cause you'll likely have to spray the handle to match your OBP. My NCS rattle can cost me $20 and did not match perfectly. One month of curing time later I needed to go over the handle with some good clear coat to make the handle match perfectly. ** Please wait 30 days of dry time for your spray can paint to cure before doing a final coat of clear **. There are solvents in the clear vs. solvents in the color that are going to battle if you clear that thing too soon! Ask me how I know......
doccrowley
#10: 11-19-2012, 06:00 PM
 UTwrestler22
Hahaha cool. Thanks doc. I have a way to sand all the paint off if i cant find a black one. Didn't get to go today. No time damnit.
UTwrestler22
Similar Threads
FS: IL Medicus Dual Hinge 460cc driver mens RH tjbev21 Member Classifieds :: Non-Car 2 08-21-2010 10:51 PM
Pointers on TGV installation / removal CasopoliS Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 31 11-30-2006 10:26 PM
Legacy crash tests on dateline NBC... inthedeck Fourth Generation Legacy (2005 - 2009) 84 07-31-2004 12:00 AM
