Go Back   Subaru Legacy Forums > Technical Forums > Performance/Dyno Numbers/Track Times
Reload this Page When to shift
Page 1 of 3 1 23 >
#1: 10-15-2012, 09:33 AM
When to shift
 lee07
lee07's Avatar
Send a private message to lee07 Find all posts by lee07 Reply With Quote
Taking it down the 1/4 this Sunday, 1st time
What rpm is best to launch and when is it best to shift into 2nd?
Was thinking 3500 for launch and around 4500 to shift into 2nd
2nd to 3rd and 3rd to 4th maybe 5500?
When does the time start? When the light turns green or when your tires move?
05, 5spd
lee07
Find More Posts by lee07
#2: 10-15-2012, 09:39 AM
 JermTheElf
JermTheElf's Avatar
Car: 2005 LGT LTD 5MT STG 2
Send a private message to JermTheElf Find all posts by JermTheElf Reply With Quote
Stock turbo?
JermTheElf
Find More Posts by JermTheElf
#3: 10-15-2012, 11:05 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
Never been to the strip, but I'm fairly certain 3500 for a launch is not high enough for a fast launch. Try more like 4500-5000. If you value your drivetrain, you shouldn't be dumping the clutch either. You should slip it.
And you're not supposed to be revving it up to a constant speed either. If you hold your engine speed at say... 4500, you are building absolutely no boost. However, if you're blipping the throttle instead and get it on the "upstroke" of the engine rev, you are giving the engine load and it will develop boost much quicker.
If you have launch control, that's a different story....
As for the other question about when the time starts, maybe you should Google the drag process and what the lights on the Christmas tree actually mean.
As far as when to shift, I believe you should be shifting at about 5500-6000 because the turbo will lose VERY rapidly after 6K. But 4500 I think is a bit too early.
Disclaimer: the above is just my 2 cents. Lots more experienced people will hopefully chime in. I defer to their experience. I'm also assuming you're on the stock turbo.
iNVAR
Find More Posts by iNVAR
#4: 10-15-2012, 11:15 AM
 lee07
lee07's Avatar
vf52, lwfw
lee07
#5: 10-15-2012, 12:15 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
lwfw? yeah, 3500 would most likely not be enough for a nice hard launch. also, vf52 you should be able to bring it up to 6K and shift around there. again, my opinion from what i know.
iNVAR
#6: 10-15-2012, 07:53 PM
 JermTheElf
JermTheElf's Avatar
You should get the launch control patch. But I've read first gear you usually want to shift around 5000, then second and third closer to 6000
JermTheElf
#7: 10-15-2012, 07:59 PM
 underground000
underground000's Avatar
Title: Bus Wanker!
Car: 08 LGT
Send a private message to underground000 Find all posts by underground000 Reply With Quote
right when the last yellow light lights up you go, it takes time to get everything going thats why....
when you do launch, rev it but dont hold it there cause youre just gonna heat soak the tmic, and when you do let go of the clutch. let go in a hurry do not release it all at once
do you have a boost gauge? if yes look where the boost starts tapering and shift when it begins to taper to stay in the power band
everything you'll get a hang of after a few passes
5eat downshift rev match
Powder coated wheels: completed
underground000
Find More Posts by underground000
#8: 10-17-2012, 02:24 AM
 NSFW
NSFW's Avatar
Title: Stage Free
Car: 6mtblackturbowagon
Send a private message to NSFW Find all posts by NSFW Reply With Quote
The timer starts when you leave, so don't worry too much about reaction time. It only matters for competitive racing.
Run 1st and 2nd all the way to redline. Run 3rd until you feel the power drop off - until just before you feel the power drop off, really. It will take some practice but it'll probably be around 6000 RPM. You'll run out of track before you need to shift out of 4th.
For launching, the key thing is not to bog - not to let the RPM drop too low. You do that by holding RPM high (3500, maybe 4000 RPM) and using clutch slip to get the car moving without pulling the RPM down too low. Or if you have a rear-biased diff, you can use wheelspin instead of clutch slip, but the stock LGT center diffs are all 50/50 split if I remember right.
When you shift, get back on the throttle before you release the clutch, so that the engine RPM comes up, and the engine is pulling you forward when the clutch grabs.
The main thing is to drive it like you stole it. You won't get a decent time if you launch and shift like you do on the street. It's kind of painful at first.
The Following 2 Users Say Thank You to NSFW For This Useful Post:
GTTuner (10-17-2012), Turkeylord (10-17-2012)
NSFW
Find More Posts by NSFW
#9: 10-17-2012, 06:16 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner Reply With Quote
^^^^^^ This. I go to 7000 in first and 6500 in second, the 6 k every gear after. But I also have a bigger turbo that doesn't fall off until 6500 or so. First and second rev so fast I take advantage of the raised rev limiter.
GTTuner
Find More Posts by GTTuner
#10: 10-17-2012, 06:32 AM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
For launching, I parked in the stage lights and held with the handbrake. Bring the revs up, and let out the clutch until the car starts to grip. Once the light flashes off the last yellow (unless it's a pro-500 tree, where'd you go a little earlier), lower the handbrake, let up the clutch, and drop the hammer. It's a fine balance between clutch and throttle to get off the line, and everyone is different. It's a lot trickier to launch the 5MT cars than it is the tunnel-case 6MT. You actually have to have some degree of mechanical sympathy if you want to be able to drive the car home.
As for shifting, just what NSFW said. Shift just before/as power is peaking. 1st is too short to consider short-shifting it, though. The rest of the gears, shift by feel. You'll get the hang of it after a few passes.
BAC5.2
Find More Posts by BAC5.2
#11: 10-17-2012, 08:02 AM
 JermTheElf
JermTheElf's Avatar
There is a lot of great info here, thanks for the posts. I guess the logic is to beat on something that is meant to wear out (clutch) and don't put tons of strain on fixed components (axles, tranny, etc). With something like launch control what rpm do you usually set it at? You said 4000 but I've heard of 5000 which just seems too high
JermTheElf
#12: 10-17-2012, 06:47 PM
 NSFW
NSFW's Avatar
Title: Stage Free
LC RPM will vary. I agree that 5000 sounds high for the stock turbo but it might be low for a 35R. I've been experimenting with 4500 with my setup.
4000 sounds reasonable to me for the stock turbo. But, I didn't have LC yet when I was on the stock turbo, so that's just speculation.
Consider using launch control just as a simple rev limiter - don't go full throttle, just rev right up to it, so you don't build boost. Then go WOT as you release the clutch. You won't launch as hard as you would with boost, but you also won't be as likely to break stuff while you work on your clutch release. (LuckyBob gave me this idea.)
The Following User Says Thank You to NSFW For This Useful Post:
LuckyBob (10-25-2012)
NSFW
#13: 10-17-2012, 07:20 PM
 LosAngelesLGT
Title: Banned
Car: 05 LGT 5mt 371hp on 91oct & 06 OBXT Stg1
Find all posts by LosAngelesLGT Reply With Quote
Been to the track more than a few times on a bunch of setups. Dont rev out 2nd gear. First gear rev out. NO other gears with oem turbo. Stay in boost.
Shift ~5600-5800rpms. Launch instructions given sound good.
Dont listen to people giving instructions for "bigger" turbos.
LosAngelesLGT
Find More Posts by LosAngelesLGT
#14: 10-17-2012, 08:36 PM
 leggyman17
Send a private message to leggyman17 Find all posts by leggyman17 Reply With Quote
MAKE sure you check your oil...last time i dragged my stage 2 LGT i spun 2 bearings from overheating them... also do not reccommend 5w-30... try heavier oil
leggyman17
Find More Posts by leggyman17
#15: 10-17-2012, 09:48 PM
 Turkeylord
Turkeylord's Avatar
Title: Torque Requestor
Car: 05 ABP 5MT GT Wagon
Send a private message to Turkeylord Find all posts by Turkeylord Reply With Quote
Well I'll throw in my $.02
Your VF52 should be pretty similar to my 16g. I haven't really done enough passes to say this with any authority, but the one run I tried "short shifting" at 6k was significantly slower despite being a clean run. 6500 seemed slightly faster than 7k as expected.
I was launching at 4500 and had intentions to bump that up but abandoned them as I was already having traction problems.
Turkeylord
Find More Posts by Turkeylord
Page 1 of 3 1 23 >
