Reload this Page Cel.
#1: 11-11-2012, 07:17 PM
Cel.
 DOHCEJ22E1
DOHCEJ22E1's Avatar
Title: Contributing V.P.
Car: 1998 Subaru Legacy GT-L powered by EJ22D
Send a private message to DOHCEJ22E1 Find all posts by DOHCEJ22E1 Reply With Quote
I'm thinking the IACV is messed up in some way.
How do I know? I don't since I don't have my scanner today.
However, when the car is in park, the idle jumps between 1500rpm to 2500rpm constantly like the way bad IACV on Hondas do & when I am driving it, it stays at exactly 1500 rpm without my foot on the pedal.
I have to actually force the car to stop by braking a little harder than usual.
Any suggestions on this?
DOHCEJ22E1
Find More Posts by DOHCEJ22E1
#2: 11-11-2012, 07:24 PM
 Kennyfvholla
Kennyfvholla's Avatar
Car: 99 OBL, 04 Accord EX 6MT coupe
Send a private message to Kennyfvholla Find all posts by Kennyfvholla Reply With Quote
I'm guessing the RPM hovers at a little higher than idle when the car is stopped and in gear?
Look at the throttle body when the motor is running and car is stopped. It should look like a bit of throttle is being applied.
Did anything happen before this issue? What codes are popping up? There could be another issues that's causing the IAC to "giving it a bit of gas" or it could be a throttle body issue or it could some other issue.
What does the throttle body look like when the motor is shut off compared to when its running? What happens as soon as you start the car?
Kennyfvholla
Find More Posts by Kennyfvholla
#3: 11-11-2012, 07:58 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
As soon as I start the car, the rpms shoot straight up to 2500 rpm & then back down to 1500, then begins & back & forth bounce between those rpm points.
There was a pinging event but I stopped that by re-adjusting the knock sensor & replacing the vacuum lines to the intake & fuel regulator about 3 days ago.
I borrowed my neighbor's scanner since mine is 4 towns away & since the scanner I used was simple, it only gave my a code w/no explanation. PO1507.
I've looked online & I've found that this can be one or many issues. I'm going to tackle this as soon as I can because if at all possible, I'd like to prevent damage.
DOHCEJ22E1
#4: 11-11-2012, 08:07 PM
 Kennyfvholla
What does the throttle look like with the motor on compared to off?
Chek and clean the IAC
Check the TPS
Check the intake for any sort of vacuum leaks
The Following User Says Thank You to Kennyfvholla For This Useful Post:
DOHCEJ22E1 (11-11-2012)
Kennyfvholla
#5: 11-11-2012, 09:04 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
I will check everything out tomorrow & come back to this.
DOHCEJ22E1
#6: 11-11-2012, 09:46 PM
 Stang70Fastback
Stang70Fastback's Avatar
Car: 1998 Subaru Legacy Outback Limited
Send a private message to Stang70Fastback Find all posts by Stang70Fastback Reply With Quote
IAC does sound like the culprit. However it could even be something as silly as a bad coolant temperature sensor.
Stang70Fastback
Find More Posts by Stang70Fastback
#7: 11-11-2012, 10:39 PM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
Go to Autozone and get the codes scanned for free
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#8: 11-12-2012, 12:02 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
Got my scanner back & plugged it in. PO1507 with Idle Air Malfunction, & about 6 different descriptions detailing the Idle Air Control Valve issue. I took apart the whole assembly & it is caked full of what I believe is sludge. I'm cleaning out everything & repositioning all of the wiring. Hopefully, that should bring it back to normal.
DOHCEJ22E1
#9: 11-12-2012, 01:17 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
Cleaned the IACV & re-adjusted the TPS. Now it runs normal. Thanks for the suggestions! They worked well
DOHCEJ22E1
