Go Back   Subaru Legacy Forums > Technical Forums > Intake and Exhaust
Reload this Page Up pipe removal problem
#1: 11-11-2012, 03:42 PM
 EconCoder
EconCoder's Avatar
Car: 05 LGT VF52 Stage 1.5 & 12 Outback 3.6R
Send a private message to EconCoder Find all posts by EconCoder Reply With Quote
I'm trying to get my stock 05 up pipe removed, but it is now stuck between the block and the shield over the right front wheel linkages.
Can anyone offer suggestions on how to get it out the rest of the way? Maybe lifting the block, but how?
EconCoder
Find More Posts by EconCoder
#2: 11-11-2012, 03:54 PM
 captainobvious
captainobvious's Avatar
Car: 05 Legacy 2.5 GT Limited stage2
Send a private message to captainobvious Find all posts by captainobvious Reply With Quote
While you may or may not have this up pipe. this helped me.
GrimmSpeed Up Pipe Install - YouTube
captainobvious
Find More Posts by captainobvious
#3: 11-11-2012, 03:55 PM
 Dujo
Dujo's Avatar
Car: 1 of 99 2005 ABP/Tpe LGT Ltd 5MT Wagon
Send a private message to Dujo Find all posts by Dujo Reply With Quote
No problem. Yes, lift the block.
Loosen the passenger side motor mount bolt. Do not remove it all the way. Just loosen it to the end of the bolt. Get your oem jack and a block of wood and lift on the oil pan. Believe it or not, you only need about an extra quarter inch or so of clearance. This will get it done.
After you put in the new one, don't forget to lower the jack and retorque that bolt. Good luck. Make sure you didn't knock out the half moon cam seals knocking the uppipe around in there.
I have no idea what I am talking about.
Dujo
Find More Posts by Dujo
#4: 11-11-2012, 04:11 PM
 EconCoder
EconCoder's Avatar
My dad and I disconnected the motor mount at the block and then lifted, but appeared to just lift the car not the block. Should we have unscrewed the motor mount at the frame instead?
EconCoder
#5: 11-11-2012, 04:18 PM
 thefultonhow
thefultonhow's Avatar
Car: 07 Spec.B BNR16G, TurboXS tuned
Send a private message to thefultonhow Find all posts by thefultonhow Reply With Quote
You probably only disconnected one of the two motor mount bolts. Yes, you should take the nut off that holds the motor mount to the crossmember instead.
The Following 2 Users Say Thank You to thefultonhow For This Useful Post:
Dujo (11-11-2012), EconCoder (11-11-2012)
thefultonhow
Find More Posts by thefultonhow
#6: 11-11-2012, 04:21 PM
 Dujo
Dujo's Avatar
^ Sorry that was ambiguous. Yes. From the crossmember.
Dujo
#7: 11-11-2012, 04:53 PM
 EconCoder
EconCoder's Avatar
Ah! I was wondering. I'll give that a shot.
EconCoder
#8: 11-11-2012, 05:22 PM
 EconCoder
EconCoder's Avatar
Happen to know where I can find the torque rating for those bolts?
EconCoder
#9: 11-11-2012, 05:46 PM
 EconCoder
EconCoder's Avatar
So, here are some pictures. In one of the pictures you can see the two bolts we loosened. After loosening them, we tried to move the block and just the car moved.
Any thoughts?
Name:	Photo Nov 10, 5 53 58 PM.jpg
ID:	133700   Click image for larger version
Name:	Photo Nov 11, 4 40 43 PM.jpg
EconCoder
#10: 11-11-2012, 06:36 PM
 EconCoder
EconCoder's Avatar
And we got it! Thanks for the help.
EconCoder
#11: 11-11-2012, 07:26 PM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
I was able to just to jack on the motor without unbolting it to get mine out. But looks like you figured it out already!
Nrw
Find More Posts by Nrw
