Reload this Page Car rumbles/vibrates while turning at slow speeds.
#1: 12-02-2012, 01:08 PM
 dfalk
Send a private message to dfalk Find all posts by dfalk Reply With Quote
When turning corners in my car at slow speeds the whole car will rumble/vibrate, almost feels like a tire is rubbing the wheel well but it is not. I only notice this when entering my driveway/parking spaces. It does it turning left/right and in forward/reverse.
I took it to the dealership and they told me it's being caused by my really bald tires and that one tire has more trend left than the other 3. So I took it in today and got 4 brand new tires and an alignment. The tire shop said everything else looked good and made no mention of this problem.
Does anyone have a clue as to whats causing this? It's starting to get really annoying and I don't want it to cause a major problem. The shops don't seem to care about it but I do.
dfalk
Find More Posts by dfalk
#2: 12-02-2012, 01:11 PM
 Serb Legacy GT
Car: '05 Legacy GT 5pd; 99 M3 cpe 5spd
Send a private message to Serb Legacy GT Find all posts by Serb Legacy GT Reply With Quote
That's odd that the shop wouldn't look into it more. Go to another shop. It's amazing that they would only look at the car and not go on a test drive to duplicate what you're hearing. Just the fact that they didn't test drive it makes me wonder how well did they look under the car.
Serb Legacy GT
Find More Posts by Serb Legacy GT
#3: 12-02-2012, 01:27 PM
 SEA#3
Send a private message to SEA#3 Find all posts by SEA#3 Reply With Quote
Standard or automatic? How many miles on the car? Model and year
SEA#3
Find More Posts by SEA#3
#4: 12-02-2012, 01:40 PM
 dfalk
Oops forgot to add all that stuff
'05 2.5i, auto, 65K
dfalk
#5: 12-02-2012, 03:46 PM
 laff79
laff79's Avatar
Title: Master of Custodial Arts
Car: '05 ABP Legacy GT
Send a private message to laff79 Find all posts by laff79 Reply With Quote
LCA bushings?
laff79
Find More Posts by laff79
#6: 12-03-2012, 01:36 AM
 SEA#3
more than likely it is the awd clutch pack in the trany . you said that you had one tire that was worn more than the others - this can cause the awd to work over time - you can check this by installing the FWD fuse in the fuse box under the hood and try the parking maneuver to see if it still vibrates-
SEA#3
#7: 12-03-2012, 06:24 PM
 dfalk
Never heard of this but I'll give it a try and let you know what I find out.
dfalk
#8: 12-04-2012, 02:32 AM
 adreyna
adreyna's Avatar
Car: 05 Subaru Legacy GT 5EAT
Send a private message to adreyna Find all posts by adreyna Reply With Quote
installing or removing?
adreyna
Find More Posts by adreyna
#9: 12-04-2012, 10:48 AM
 konkilr
Car: 05 LGT limited
Send a private message to konkilr Find all posts by konkilr Reply With Quote
Sounds like a torque bind. The 4 speed auto trannys get this issue sometimes. Rebuilding the transfer section of the transmission should solve this. Sometimes a trans flush can also remedy this.
Putting in the FWD fuse should reveal this issue. It should go away once installed.
jake
konkilr
Find More Posts by konkilr
#10: 12-04-2012, 12:00 PM
 ShrinerMonkey
ShrinerMonkey's Avatar
Car: 2006 Legacy 2.5i SE Wagon
Send a private message to ShrinerMonkey Find all posts by ShrinerMonkey Reply With Quote
Torque bind. My 2.5i 4EAT had the same issue. Did a complete change of the ATF to BG full synthetic and the problem was resolved.
ShrinerMonkey
Find More Posts by ShrinerMonkey
#11: 12-04-2012, 07:09 PM
 dfalk
I totally forgot to mention the dealership said I need to change my ATF since it was burnt. They wanted $170 to do it so I told them to go kick rocks.
Should I go to a shop and get a full flush or should I just drain it and refill? If I so that what kind of ATF should I use? I've been reading and there seems to be 101 different opinions on this. According to my manual it says to use:
IDEMITSU HP
Castrol Transmax J
Pennzoil J
Or if your vehicle has a 4 speed auto you can use Dexron III in addition to the recomended fluid types
After researching the Idemitsu is super expensive unless you order online, the Catrol and Pennzoil you can never find in stores, and to never use Dexron. What do you all think?
dfalk
#12: 12-05-2012, 08:44 AM
 ShrinerMonkey
A drain and fill only gets out about 1/3 of the fluid. It is a lot less work to do a "flush" using an exchange machine. You also don't waste any fluid like you would doing a multiple drain and fill method.
My local Subaru dealer uses a BG fluid exchange machine and I just used the default BG universal synthetic ATF. I think it cost around $100 to do the complete fluid exchange. The BG fluid is much cheaper than the Subaru HP+ fluid.
ShrinerMonkey
#13: 12-18-2012, 12:03 PM
 dfalk
FYI: So I went and had the dealership do a complete tranny flush and it fixed the problem. Total cost was $180.
dfalk
