Reload this Page Clutch Issues
#1: 10-28-2012, 10:19 PM
Clutch Issues
 duffrey93
Send a private message to duffrey93 Find all posts by duffrey93 Reply With Quote
Hello I'm having some clutch issues with my 1998 Legacy 2.5GT. Basically the clutch pedal just snaps to the ground and I have to pull it back up. Neither the slave nor the master cylinder appeared to be leaking and there was plenty of fluid. And when the car is on and parked I cannot get it into gear but, when it is off it will go into gear.
So from what I have read and from talking to some people I figured it was either the slave or the master cylinder. So I went ahead and changed them both and bled the the system but that did not help. I feel like I can get some pressure in the pedal now after pumping it but it is still pretty soft and I still cant get it into gear.
The one other bit of info is the clutch fork seems to have a little play in it. It moves front to back very easily about an inch and it moves up and down about 1/4". Ive never have checked it before so i dont know whether this is normal.
So I cant figure out whats going on. I was hoping it was something with the hydraulics but now I am thinking it is something internal.
Does anyone know whats going on?
Thanks!
duffrey93
Find More Posts by duffrey93
#2: 10-28-2012, 11:53 PM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
Its probably the clutch fork. I recently broke mine at the pivot point and had a similar issue.
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#3: 10-30-2012, 03:04 PM
 C I Smooth
C I Smooth's Avatar
Car: 1997 2.5 Legacy GT 5MT
Send a private message to C I Smooth Find all posts by C I Smooth Reply With Quote
Yeah I'm with brok.
The clutch fork should have little to no play in it.
You might also want to check out your throw out bearing if that's the case
C I Smooth
Find More Posts by C I Smooth
#4: 10-30-2012, 10:18 PM
 broknindarkagain
For what its worth, I bought a new clutch fork and the 3 associated clips from the dealer for roughly $30, so they aren't too expensive.
-broknindarkagain
COME AND TAKE IT
broknindarkagain
#5: 10-30-2012, 11:00 PM
 duffrey93
Thanks for the help guys. I like the cost of the parts, im just worried about the cost of labor. I would love to do it myself I just dont have the time or resources.
Ill have to search for a good cheap shop around the Seattle area.
duffrey93
#6: 11-16-2012, 04:23 PM
 duffrey93
Alright, I just wanted to close the loop on this thread. The clutch fork did break and along with that, the pilot bearing and shaft were super worn out as well.
And since everything was open, I went ahead and replaced the clutch too.
It wasn't cheap getting it all fixed but, it had to be done.
Thanks for all the help!
duffrey93
