Reload this Page A different trailer hitch option
Page 1 of 6 1 23 > Last »
#1: 03-28-2013, 05:17 AM
 frank_ster
frank_ster's Avatar
Title: MASTER OF THE BUCKARU
Car: 05 lgt 5EAT 3.8, buell 1125cr ,79 camaro
Send a private message to frank_ster Find all posts by frank_ster Reply With Quote
So i have had a few people asking about this model of hitch
and yes i can make for about 140$ but i want to make more than 1! since i'll have to spend time making drawings.
so laser cut plates 44 ksi steel,
2" cross tube 1/4" wall.
will come with stainless steel bolts and washers. can be painted zinc plated (yellow or white ) or unfinished depending your desire
bolts on the exact same way with the same or thicker steel for construction as other brand hitches. but not drag on the ground.
the bumper cover would need a slight cut in the middle on the horizontal surface.
Now that's thinking out of the boxer!
fyi all 05 legacy's have built in code reader
The Following User Says Thank You to frank_ster For This Useful Post:
GTEASER (04-15-2013)
frank_ster
Find More Posts by frank_ster
#2: 03-28-2013, 07:23 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Would this also fit an outback?
BarManBean
Find More Posts by BarManBean
#3: 03-28-2013, 08:02 AM
 boxkita
boxkita's Avatar
Car: 05 Legacy GT wagon Stg doghouse
Send a private message to boxkita Find all posts by boxkita Reply With Quote
^^^ what he said. If it fits an outback, it ought to fit a lgt wagon. Do you have a rating on the hitch? still trying to figure out if I can tow the race car. :-)
Build my car
Buy it ready to go
Boxkita Track days
boxkita
Find More Posts by boxkita
#4: 03-28-2013, 09:23 AM
 frank_ster
frank_ster's Avatar
yes it will fit legacy wagon and out back wagon . i'll test fit it on my 05 wagon to make sure ..
frank_ster
#5: 03-28-2013, 06:07 PM
 frank_ster
frank_ster's Avatar
well you can tow what ever you want.. but if you get a ticket or pulled off the road is another story. i'm not sure how your local dot would go about checking. typically they would go by what the car manufacturer says.
my self i want to pull my bobcat loader around its 3500 lbs + acessorys. + trailer i do it but it doesn't "look right" so i want to get a enclosed trailer with 2 axels very low to the ground with brakes so it doesn't appear to be a big load.
I think 99% of cops pull over things that look unsafe. will they pull you over and weigh your load and check your hitch tag ? i have never even herd of that.
frank_ster
#6: 03-28-2013, 11:18 PM
 RabidWombat
Car: 09 DGM LGT Stage 0, 08 DGM Impreza
Send a private message to RabidWombat Find all posts by RabidWombat Reply With Quote
How does it attach to the tow hook?
RabidWombat
Find More Posts by RabidWombat
#7: 03-29-2013, 05:32 AM
 frank_ster
frank_ster's Avatar
^ haha yea i was tiring to remember that also.
looks like the hitch will sit behind it and have a loop that you can drop a bolt through.
frank_ster
#8: 03-29-2013, 10:59 PM
 slushboxgt
slushboxgt's Avatar
Car: (s) Don't go there... ;)
Send a private message to slushboxgt Find all posts by slushboxgt Reply With Quote
Looks like mine will probably be the next one you do Frank, any chance of black powdercoat?
I'm thinking rust prevention so it keeps looking nice here in la belle province with all the road salt...
Paul
PS. Why not just remove the tow loop? Don't need it with a hitch anyway, right?
slushboxgt
Find More Posts by slushboxgt
#9: 03-29-2013, 11:56 PM
 RabidWombat
The tow loop is directly in-line with the load and also a main attachment point to the car frame. That's why most hitches uses it as a main attachment point. With a large load, it minimizes torque applied to the rail bolts. I suspect its probably the most critical of the attachment points.
RabidWombat
#10: 03-30-2013, 12:01 AM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
Paul
The hitch mounts using the tow-loop.
If you are going to custom make one, why not consider making one like the AUDM version?
http://www.crago.net/subaru/towbar/
The non-North American cars are rated (flat-hitch) for almost 4,000lb!
BAC5.2
Find More Posts by BAC5.2
#11: 03-30-2013, 12:12 AM
 slushboxgt
slushboxgt's Avatar
The Aussie one is too complicated for my needs, but why not just remove the tow loop and use that as an anchor point for the custom receiver?
Paul
slushboxgt
#12: 03-30-2013, 09:13 AM
 frank_ster
frank_ster's Avatar
But yes I would defiantly tie into the tow hook
Can make the hitch as strong as you want but doesn't mean the officer won't give you a ticket ! They probably have a generic book saying a family sedan can only pull so much. Typically in North America the rule of thumb is the load shouldn't be heavyier than the vehicle pulling in a standard bumber trailer arrangement. 5th wheels can take more
In Europe I have seen small cars pull two horses on a decent size trailer. But in Europe there is a speed limit of about 90 km or 55 mph for any trailer
frank_ster
#13: 03-30-2013, 09:26 AM
 BAC5.2
BAC5.2's Avatar
In the US, the "thumb" allows the towing vehicle to be no less than 80% of the load (if equipped with trailer brakes).
If you made one like the AUDM hitch, I'd probably go for it.
The Following User Says Thank You to BAC5.2 For This Useful Post:
bochinam (04-02-2013)
BAC5.2
#14: 03-30-2013, 10:40 AM
 slushboxgt
slushboxgt's Avatar
Just snapped these pics of the tow loop, I see that it spot welded to the bottom of the spare tire tub/rear cross member.
I would guess that you probably cut the loop off to get the receiver up in front of it right Frank? You could also probably run a piece of flat stock from the back of the receiver to anchor in that spot, but it hardly seem necessary with that monster hitch that you built...
I would think that the Reese/Hidden Hitch/Draw-Tite version attaches to the bottom loop only because of their V shape design, that way they can hang the whole assembly below the tire well, full bolt-on, and don't have to remove or cut the bumper cover...
A compromise at best though, the down side (pun intended) is that it's way to low to the ground and too far rearward so it scrapes, looks ugly, and most hate having it on their car.
Paul
slushboxgt
#15: 03-30-2013, 02:46 PM
 frank_ster
frank_ster's Avatar
oh? ok .. i would actually do a combination of both
frank_ster
