Reload this Page Preping for a new turbo install (NOT another blown turbo thread)
#1: 02-07-2013, 04:10 PM
 -Samurai-
-Samurai-'s Avatar
Car: '05 Subaru Legacy GT Limited
Send a private message to -Samurai- Find all posts by -Samurai- Reply With Quote
So I've received my new turbo today after ordering it due to A LOT of bearing play when installing my new Perrin up-pipe. I didnt find much info on how to install a new turbo properly (not after one blows)
So these are the things I've gathered together for the install:
1. Fresh oil and filter
2. Grimmspeed exhaust gaskets for the up and down pipes (already in due to the up-pipe install so they are guaranteed still good as I put them in 3 days ago)
3. Before bolting in the turbo, prime the bearing by pouring fresh oil in the bearing location. Is it fine to pour in through the return line? And continue to manually spin the shaft gently to get all internals lubed
4. A little extra coolant seeing how I will lose some when removing the bad turbo.
5. Remove turbo banjo filter and DISCARD lol
Anything I am missing or should know about? Thanks guys!
-Samurai-
Find More Posts by -Samurai-
#2: 02-07-2013, 04:29 PM
 wurkenman
wurkenman's Avatar
Title: Contributing V.P.
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
Sounds like you have it covered. Might as well check the banjo bolt filters while you are there and remove them if present.
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
wurkenman
Find More Posts by wurkenman
#3: 02-07-2013, 04:36 PM
 -Samurai-
-Samurai-'s Avatar
How could I forget this haha Yes ALSO remove the turbo banjo as well. cant forget. Im gonna edit my post to cover it! haha
-Samurai-
#4: 02-07-2013, 05:01 PM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
oil return hose.
I like to bolt the turbo to the up pipe.
I figured that out after I cut the inlet tube trying to line up the studs, oil return hose and inlet tube.
WHen I did the short block, I bought a new inlet tube and 5 bolts that hold the up pipe bracket to the block.
I think you've seen the picture.
Max Capacity
#5: 02-07-2013, 05:07 PM
 -Samurai-
-Samurai-'s Avatar
Originally Posted by Max Capacity View Post
oil return hose.
Yeah Im just gonna use the studs on the up. They are brand new and Im going to put some anti seize on them as well. I dont plan on removing the turbo again if I even own the car for another turbo to go out without the filter causing it. It was never blown, just bad. So not worried about metal shrapnel in the oil either lol. But yes the way you have done it looks like an awesome idea for people that do a lot of work on their cars for sure!
-Samurai-
#6: 02-07-2013, 07:31 PM
 Oregon OBXT
Send a private message to Oregon OBXT Find all posts by Oregon OBXT Reply With Quote
The only other thing I might suggest is getting a 2x Grimmspeed manifold to uppipe gasket. The turbo mounts to the uppipe and the combined forces of engine, UP, and DP bolting can overwhelm the 2-bolt manifold to UP gasket. That and your Perrin UP flange is much more stiff than OEM. If you do replace it, loosen up all manifold bolts, tighten the UP first and then the others.
Oh, and while you're down there, might as well remove the cross pipe and replace that weeping oil cooler o-ring and get those stains off your driveway. ;-)
Oregon OBXT
Find More Posts by Oregon OBXT
#7: 02-07-2013, 10:21 PM
 -Samurai-
-Samurai-'s Avatar
I do have new Grimmspeed exhaust gaskets on the car haha, Literally put them in last week. I have no oil stains on the driveway haha, maybe mine doesnt leak yet?
Also is there some kind of break in period for the new turbo? Or should it just be good to boost after being primed?
-Samurai-
#8: 02-07-2013, 11:42 PM
 -Samurai-
-Samurai-'s Avatar
How do you properly prime a turbo? By pulling the IGN (Ignition) fuse and turning the engine over a few times? Or is there a safer way? And also whats the best way to check there is oil pressure properly getting through the inlet tube?
-Samurai-
#9: 02-08-2013, 05:39 AM
 Max Capacity
Title: Gearhead
I put a little oil in the oil feed, spun the wheel a little, put it on the car and started the engine.
It will get oil pressure faster that way.
Just I did with the new short block, put it, fired up the engine. Oil light went out just like it always does.
Max Capacity
