Go Back   Subaru Legacy Forums > Technical Forums > Transmissions
Reload this Page Future problems caused by excessive clutch chatter?
#1: 11-08-2012, 01:52 PM
 Nolmers06LGT
Nolmers06LGT's Avatar
Car: '06 LGT 5mt w/103k STG2 @18.25psi
Send a private message to Nolmers06LGT Find all posts by Nolmers06LGT Reply With Quote
After the traditional TOB failure, I decided to upgrade the clutch to the ACT HDSS kit, along with the ACT Streetlite FW. I'm about 3k into the new clutch, and I'm still seeing quite a bit of clutch chatter into 1st gear. It typically only happens in traffic, but I'm a little concerned about the long-term consequences of my entire engine/tranny shaking violently. Also, there is a new "clunk" that happens occasionally as the clutch is engaging. I'm speculating that it's my slave cylinder actuating, however I'm trying to rule out that my clutch is coming apart. Has anyone heard noises like this?
PS.. during the clutch swap I also installed the GroupN pitch stop, tranny mounts, crossmember bushings, and new shifter bushings around. I'm speculating that the sound could be a failed stock motor mount, but I'm not sure.
Any help would be greatly appreciated!!
Nolmers06LGT
Find More Posts by Nolmers06LGT
#2: 11-08-2012, 02:58 PM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
When the clutch chatters, put tranny in neutral, side step the clutch letting the pedal bang to the top.
That solved the issue with my Spec 2+. My Spec 2 clutch has never chattered in the 7000+ miles it's been in.
Max Capacity
