I think I overloaded the cig/12v port last night by putting both radar detector and a dashcam on a Y splitter.. usually had no problems but for some reason when I plugged them in while the car had electricity running (radio was on, engine was not) the dash and all other electronics cut out for a split second then came back on, now my Cig lighter won't work, AC/console won't work, and side mirrors won't respond to any of buttons.
The lights (green/illuminate) around the lighter and AC still work.
1994 Brighton 220 Legacy JDM.
I've had a quick look at the fuse box, but I can't make sense of it.
Cheers.
edit - bit of clarity. The reason I took the 12v splitter out and plugged in again as I think the wires were loose, the socket was wriggling around a bit, I took the dash apart and tightened it back up and checked the wires, don't believe anything is shorting.
