Go Back   Subaru Legacy Forums > Technical Forums > Suspension/Brakes
Reload this Page Cutting rear shock bolt
#1: 10-09-2012, 08:09 AM
 Shotokan1509
Shotokan1509's Avatar
Car: 05LGT & 06Mustang GT
Send a private message to Shotokan1509 Find all posts by Shotokan1509 Reply With Quote
Trying to install Koni's, rear per a lot of threads here is stuck good.
I have whole bag of tricks to try... but has anyone just cut the bolt? Is it threaded through knuckle or I can just hammer it out after cut? Bolt is already gunked up a bit, wondering do I just "cut" to the chase instead of fighting it replace it. Anyone got a part number?
Shotokan1509
Find More Posts by Shotokan1509
#2: 10-09-2012, 08:24 AM
 dingbang
dingbang's Avatar
Car: '06 lgt cornfed vf39 w/ewg
Send a private message to dingbang Find all posts by dingbang Reply With Quote
It's straight through in the knuckle, so once cut, you can hammer it out.
You try a box end with a jack pushing it up? I had to break all the tricks out of the bag for that puppy. I remembered this morning that I used a jack hold a box end on the inside while I worked it with a breaker bar.
dingbang
Find More Posts by dingbang
#3: 10-09-2012, 08:31 AM
 dingbang
dingbang's Avatar
901000177 - Bolt
900335056 - Inside Washer
Nut--no idea on the P/N
dingbang
#4: 10-09-2012, 10:38 AM
 AZP Installs
AZP Installs's Avatar
Title: Vendor II
Car: 05 LGT->11 STi & 12 JagXJ & 04 Armada
Send a private message to AZP Installs Find all posts by AZP Installs Reply With Quote
Cut it or if on a lift a 6' breaker bar.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
AZP Installs
Find More Posts by AZP Installs
#5: 10-09-2012, 01:41 PM
 Shotokan1509
Great, ya no lift but if I can get it higher on stands I might be able to get just enough breaker bar. That, some more PB, some heat, some swearing and a BFH.. or cut.
Shotokan1509
#6: 10-09-2012, 06:51 PM
 dingbang
dingbang's Avatar
You'll eventually get it. I think it took me the better part of two hours with swearing, smoke breaks, 3 beers, staring down the bolt, etc to break both sides loose...not to mention the multiple ways I tried to break em loose
dingbang
#7: 10-09-2012, 07:58 PM
 Shotokan1509
Got 'em just needed more height for breaker bar inside towards rear of car. Now need to reinstall them, need to get perfect alignment to knock them in
Shotokan1509
#8: 10-14-2012, 03:53 PM
Third world solutions for rear shock R&R
 unobtainium
unobtainium's Avatar
Car: '93 Legacy L AWD; '05 Legacy GT
Send a private message to unobtainium Find all posts by unobtainium Reply With Quote
Just did this. There is an instruction in the manual about using the pantograph jack to unload the rear suspension and it seems weird but it works.
http://dl.dropbox.com/u/89180639/sub...G_0463%202.JPG
You have to pull the rear link downward, lifting up on the shock just pushes the whole car up in the air. This looks worse than it is, it's stable.
When you want to tighten the big bolt:
http://dl.dropbox.com/u/89180639/subaru/IMG_0468%202.JPG
Finally a cheap device for removing and installing the shock/strut end nut is Oregon tool #57-008 and it's meant for maintaining chain saws. It cost $5.99 at my local Ace hardware.
http://dl.dropbox.com/u/89180639/sub...G_0460%202.JPG
unobtainium
Find More Posts by unobtainium
#9: 10-14-2012, 03:56 PM
 unobtainium
second link should be: http://dl.dropbox.com/u/89180639/sub...G_0466%202.JPG
unobtainium
#10: 10-15-2012, 08:40 AM
 xero287
xero287's Avatar
Car: 2011 OBP WRX wit all teh shiz
Send a private message to xero287 Find all posts by xero287 Reply With Quote
Why is this so hard for everyone?
The Following User Says Thank You to xero287 For This Useful Post:
Nrw (10-15-2012)
xero287
Find More Posts by xero287
#11: 10-15-2012, 08:54 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Because rusty bolts and no fancy impact thor-hammer?
BarManBean
Find More Posts by BarManBean
#12: 10-15-2012, 08:11 PM
 xero287
xero287's Avatar
I did mine back when I had basic hand tools.
This is how I did it:
1. Remove wheel
2. Use scissor jack to compress shock
3. Use ratchet to undo bolt
3.5. If bolt does not come loose by hand then simply use your leg(s) to push the ratchet
4. Bolt is loose, pull bolt out
5. Lower scissor jack back down
6. Ask yourself, why did everyone on LGT.com have so much trouble with this???
xero287
#13: 10-16-2012, 09:02 AM
 ragman
ragman's Avatar
Car: '05 LGT Wagon Limited 5EAT BNR EVO16G
Send a private message to ragman Find all posts by ragman Reply With Quote
Because this step rarely happens without breaking rackets/extensions/etc!
ragman
Find More Posts by ragman
#14: 10-16-2012, 09:21 AM
 xero287
xero287's Avatar
Are you kidding me? I used my beater benchtop ratchet with a short socket on it and just pulled. My car was from NH and lived through many salt winters as well.
What is benchtop you ask? Most people don't know simply because of how crappy they are.
If anything, why not just put your jack under the ratchet and begin lifting. I highly doubt the bolt could withstand 1-3 tons of force.
xero287
#15: 10-16-2012, 11:07 AM
 Nrw
Nrw's Avatar
Car: 05 LGT BrenTuned
Send a private message to Nrw Find all posts by Nrw Reply With Quote
Just eat your Wheaties before hand and pull on the damn thing
The Following User Says Thank You to Nrw For This Useful Post:
xero287 (10-16-2012)
Nrw
Find More Posts by Nrw
