Reload this Page Clutch Master Cylinder Died....Again
#1: 11-22-2012, 08:52 PM
 whitelightning
whitelightning's Avatar
Car: 05 LGT 5MT
Send a private message to whitelightning Find all posts by whitelightning Reply With Quote
Holy sh!t someone tell me why I'm replacing my cmc again!!! This is the 5th or 6th time. Originally I replaced it with a part from car quest when I couldn't get my new clutch setup to work. I changed to an ACT HD 6 puck and since I have had them fail frequently. Like 6 weeks at a time. I changed the car quest one out as warranty, switched to an advance auto after, replaced under warranty, tried an autozone, replaced under warranty. I have changed the slave out also just to be safe. All have had the forward seal tear/deteriorate. I'm lost. Is my pp too hard on em? Is the OEM the best route? Is there another option? Should I burn the car and call progressive?
whitelightning
Find More Posts by whitelightning
#2: 11-22-2012, 10:15 PM
 ibr_adam09
ibr_adam09's Avatar
Car: 05 ABP Limited stg 3
Send a private message to ibr_adam09 Find all posts by ibr_adam09 Reply With Quote
Why did you get a 6 pluck clutch ?. Are u making 500 hp ?
ibr_adam09
Find More Posts by ibr_adam09
#3: 11-22-2012, 10:20 PM
 whitelightning
Car: 05 LGT 5MT
Got a deal. I'm only stage 2. Just outta money fighting with a spec clutch and ended up getting the whole act setup for a good price.
whitelightning
#4: 11-22-2012, 10:27 PM
 V8Bait
V8Bait's Avatar
Send a private message to V8Bait Find all posts by V8Bait Reply With Quote
For our cars I would use OEM. They seem to last a really long time since im at 101k on mine.
I have used cheap CMC's on my Mazda miata and they went within a couple months so you get what you pay for.
V8Bait
Find More Posts by V8Bait
#5: 11-22-2012, 10:31 PM
 whitelightning
Car: 05 LGT 5MT
Well they started cheap at car quest. Expensive everywhere else. Is there like a secret trick to bleeding em that I don't know or something?
whitelightning
#6: 11-23-2012, 12:22 AM
 K2e2vin
Car: '05 LGT Wagon, '92 Accord , '88 Civic
Send a private message to K2e2vin Find all posts by K2e2vin Reply With Quote
If it's working just fine after you installed it, bleeding isn't the problem. May have to do with the quality of the part and what fluid you're using.
K2e2vin
Find More Posts by K2e2vin
#7: 11-23-2012, 05:43 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
PM BAC5.2 he's the expert on this area.
I thought you knew that. Good Luck.
If I recall your Spec problems ended up being a bad TOB, right ?
Max Capacity
#8: 11-23-2012, 09:40 AM
 whitelightning
Car: 05 LGT 5MT
Never actually figured out the spec issue. I just never got it to work. I used different fluid and brands every time. I guess order the oem... see what happens. I guess we are getting a snow storm tonight. I always miss the fun
whitelightning
#9: 11-28-2012, 01:10 PM
 whitelightning
Car: 05 LGT 5MT
Will a wrx or sti cmc work/match up?
whitelightning
#10: 11-28-2012, 01:22 PM
 Max Capacity
Title: Gearhead
I believe some of them are the pull type not push type like our's.
PM BAC5.2 he'd know for sure. Or m sprank, or Mike at AZPinstalls.com
Max Capacity
