Reload this Page Trany info
#1: 11-08-2012, 09:05 AM
Trany info
 G Man
G Man's Avatar
Car: 95 Legacy ls sedan, 97 ford ranger
Send a private message to G Man Find all posts by G Man Reply With Quote
Need to know what the difference is betwene a Tz102 and a TZ103.
G Man
Find More Posts by G Man
#2: 11-08-2012, 11:41 AM
 johnegg
johnegg's Avatar
Car: 98 obw, 97 GT w/ ej22, '01 H6 VDC
Send a private message to johnegg Find all posts by johnegg Reply With Quote
different trans, different years, different wiring harness, they will not swap!!!
which do you need a TZ102Z.... (these are 95 - 98) or a TZ103Z... ?
what car are you working with?
the TZ102ZAAAA trans can be swapped with any ej22 (2.2L) auto trans 95 - 98, from a legacy, L, Brighton, or impreza (lower end cars.) you can not use a trans from a ej25 engine car, outback, GT, LSi, forester, or WRX.
there will be lots to choose from, www.car-part.com . you will have to search each year individually.
johnegg
Find More Posts by johnegg
#3: 11-08-2012, 12:04 PM
 G Man
G Man's Avatar
The TZ102 is in a 95 legacy and the TZ103 is in a 98 forester.
G Man
#4: 11-08-2012, 01:21 PM
 johnegg
johnegg's Avatar
ok, i was a little bit wrong and a little bit right.
i thought it was from the 00 - 04 model years. those are different and will not swap.
but the forester, 96 - 99, has a 4.44 final drive ratio which is different than the 95 legacy, 4.11 final drive ratio.
so the trans will bolt in, plug in and run, but you would need to swap in the matching rear diff to make it work correctly.
you can us any trans 95 - 98 that starts with TZ102Z... where the next character is a LETTER.
you can not us a trans that starts with TZ102Z2....... this indicates a 4.44 ratio . and these are found in the outbacks and GTs.
johnegg
#5: 11-08-2012, 07:24 PM
 G Man
G Man's Avatar
Ok so the TZ103 is the same exept for the finel drive.
Also I have a junk forester for parts.
G Man
#6: 11-09-2012, 05:46 AM
 johnegg
johnegg's Avatar
if you use the forester trans and rear diff:
the speedo will be off since the tires are a different size than the forester tires.
you can install GT (97) size tires with no headaches, but forester or outback size will not fit.
the car will be sportier, ''quicker'', than before. and slightly less fuel efficient due to the more powerful ratio and the smaller wheels.
swap in the forester struts and wheels and all will be good. back to normal. outback rear struts would be slightly taller and prevent a ''saggy'' rear look.
good luck.
johnegg
#7: 11-09-2012, 09:38 AM
 G Man
G Man's Avatar
Are the they the same length.
Dont feel like having a drive shaft made.
G Man
#8: 11-09-2012, 09:51 AM
 subikid90
subikid90's Avatar
Title: EJ22T
Car: 97 LGT & 98 LGT
Send a private message to subikid90 Find all posts by subikid90 Reply With Quote
Yes they are the same length, assuming you are talking about the trans case. No need for a custom driveshaft
-Subikid90
1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR
1998 Legacy GT Limited waiting for EJ22T hybrid swap
subikid90
Find More Posts by subikid90
#9: 11-09-2012, 10:21 AM
 G Man
G Man's Avatar
Good, and thanks to both of you.
G Man
