Hey guys, so this is my first legacy but third subaru. I'm 22 and work at the dealership (doesn't mean I can get discounts for people lol). Subies are my favorite by far but also have an old turbo 280zx with fresh performance built motor. Well anyways the legacy is an 05 lgt which was my fathers car. He bought it brand new and I am now second owner since a truck demolished my Rs for me. I have helped him fix and mod this car so not one of those bought it not built it things haha.
Here's a little mod list with more on the way later on:
Engine:
Cobb Access Port
PnP'd headers with grimmspeed hi flow crossover pipe
perrin catless up pipe
vf40 turbo (16.7psi for now. tuning on this turbo to 18psi)
catless downpipe
FMS cat back
SPT intake with shield
Perrin 3" Turbo inlet
Perrin Top Mount intercooler with Perrin BPV
Venair silicone throttle body hose
Samco radiator hoses
Koyo radiator
Grimmspeed TGV deletes
Grimmspeed 3port ebcs
Crawford Performance air/oil separator
Perrin fuel rails
Fuel lab AFPR
Deatschwerks 65c fuel pump
LC-1 wideband
Suspension:
Ordered 3/8/13 - Cusco rear sway bar, whiteline lateral lock kit for rsb
Cobb lowering springs
perrin front control arm bushings
SPT upgraded dog bone
SPT upgraded trans mount (Need to install)
SPT upgraded crossmember bushings (Need to install)
Kartboy solid endlinks front and rear
Perrin 22mm front sway bar with energy suspension bushings with upgraded brackets and whiteline lateral lock kit.
AVO rear sway bar reinforcement brackets (need to install)
17x8 + 43 rota torques with 245/45/17 nitto invo tires with red mutegi extended forged steel lugs
Drivetrain:
Stage 2 exedy clutch with lightweight flywheel
Perrin front shifter bushings (need to install)
SPT rear shifter bushing (need to install)
stock 5 speed with 4.11 gear set (rear lsd)
Other:Ordered 3/8/13 - Grimmspeed thermal coated turbo heat shield
SPT STI center dash gauges (oil pressure, boost, oil temp)
STI shift knob
Subtle solutions belt cover
SPT oil cap
SPT battery tie down
06 STI front lip
Modified headlights (blacked out inner housing and got rid of orange reflectors)
Hella supertones powder coated white
Modified stock grill ( cut wings off and stripped chrome and painted black with mesh background)
07 legacy gt radio swap (aux output)
Here's a few pics of the car and my old Rs:
