Go Back   Subaru Legacy Forums > Technical Forums > Exterior/Aesthetic
Reload this Page Headlight Washer Mod?
#1: 01-24-2007, 10:15 AM
 mbcracken
mbcracken's Avatar
Car: 05 GT 5MT Leggy Wagon
Send a private message to mbcracken Find all posts by mbcracken Reply With Quote
Hi folks,
I'm looking for some help in putting together a mod to mount some headlight washers to my 05 LegGTLmt Wagon. What I've found so far is pretty much everywhere else in the world, Subby offers these washers. I also know that they have to be a separate pump that runs at much higher volume.
Anyone know where I can at least start to research this? I've googled the world and this site without any success.
Cheers,
Mike
mbcracken
Find More Posts by mbcracken
#2: 01-24-2007, 10:29 AM
 PeterJMC
PeterJMC's Avatar
Title: Lvl 63 Night Elf Dwarf Paladin
Car: '13 Toyota Prius: Drive Yo' Self Edition
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
Here is a link on how to retrofit one onto a VW.
http://www.bambergvr6.50megs.com/hella_washer.htm
Seems pretty simple, you just need to find a place to mount them on the bumper beam... or may have to modify the beam to accomodate the washer nozzel. Also, you'll have to figure out how to wire it up.
Here is another one I found... this is the one I was intending to post in the first place. Retro for one onto a Jetta.
http://forums.tdiclub.com/showthread.php?t=62150
I know these aren't of retros onto a Legacy, but it gives you a good idea of the type of work involved in getting one fitted onto the car.
'13 Prius: Drive Yo' Self Edition
PeterJMC
Find More Posts by PeterJMC
#3: 01-24-2007, 08:44 PM
 mbcracken
mbcracken's Avatar
Doesn't look too bad, just a bunch of little work.
I wonder if anyone off the Norht American Cont could get me some part numbers of the "stock" subby headlight washers (Europe or Australia)
Cheers,
Mike
mbcracken
#4: 01-28-2007, 11:00 PM
 A_Tang
A_Tang's Avatar
Car: '07 GT wagon
Send a private message to A_Tang Find all posts by A_Tang Reply With Quote
Both of those modifications use the self extending washer nozzles and are sort of specific to the VW bumpers.
Has anyone considered the nozzles on the BMWs or Range Rovers which are always exposed? They sort of look like these:
http://www.siemensvdo.com/products_s...er-nozzles.htm
http://www.siemensvdo.com/products_s...t-cleaning.htm
These appear to only require a hole to be drilled on the bumper cover instead of a larger rectangular hole which then needs a cover for when the nozzles are not deployed.
Those two links show nozzles which sit higher, but I've seen the BMW versions (http://www.kenrockwell.com/bmw/540headlights.htm)which are fairly low profile. Just curious as to whether anyone has looked into those.
A_Tang
Find More Posts by A_Tang
#5: 01-29-2007, 08:20 AM
 mbcracken
mbcracken's Avatar
I was previously trying to find the retractable (R2-D2) ones just for cool factor, but in reviewing the Subby bumpers it may be tough to make those fit. I had not thought about BMW & Range Rover nozzles, but I like how flush they are to the bumper. I'm also working with a local MOD shop for other ideas. I'll definitely update this thread once I have more info.
What I have learned so far is that I will need to add a second pump to produce the jet pressure needed to clear a headlamp without a wiper unit. The concern that I now am pondering is heated nozzles so they don't freeze in the winter.
Cheers,
Mike
mbcracken
#6: 01-29-2007, 09:45 AM
 ex-ma hole
Car: '05 GRP OBXT
Send a private message to ex-ma hole Find all posts by ex-ma hole Reply With Quote
FWIW-
I had these in my Audi. It was a nice feature to have, but I would blow through wiper fluid. They went off whenever the head lighs were on.
You may want to make sure that these are on a separate switch.
ex-ma hole
Find More Posts by ex-ma hole
#7: 01-29-2007, 09:58 AM
 PeterJMC
PeterJMC's Avatar
Cheers,
Mike
FYI - the washer bottle has a slot for a second nozzel. This second nozzel slot is for wagons (rear window). Since you have a wagon, you'll have to make a hole for a third, or find a location for a second reservoir.
Yes, keep us up-to-date on this... This would be cool to have.
PeterJMC
#8: 01-29-2007, 10:30 AM
 mbcracken
mbcracken's Avatar
Originally Posted by ex-ma hole View Post
FWIW-
I too had them on my Audi and is now providing the motivation for this project. I seem to remember on my Audi the headlight washer would only kick on if I had the washer lever for more then X (3-5?) seconds. This would offer a small way to run out of fluid really fast.
It also looks like BMW has a feature that only washes the headlights on every 5th windshield washing & the headlights would also have to be on.
I did find this handy BMW schematic and parts needed for the very basic (non-telescopic) headlamp washers.
Click
Looks pretty simple which I need to do to make this work with the Subby bumper and keep it low cost.
Cheers,
Mike
mbcracken
#9: 01-29-2007, 11:26 AM
 A_Tang
A_Tang's Avatar
Car: '07 GT wagon
Nice, i was about to post the same link to the RealOEM site. I figure those parts can be had at a salvage yard for a fraction of the price. I don't imagine those parts seeing much wear and tear.
As for heated nozzles, I never have had that happen to me on my windshield washer nozzles, and I've been living in the northeast all my life, including a four year stint in CT. I use either the Prestone or RainX brand washer fluids and I've felt that they possess enough anti-freeze compounds in them to prevent freezing, even at highway speeds.
I think when I actually get to doing this project, i'll have a "kill switch" wired in so that I can shut down the headlamp washing pump when its not needed.
Click
Cheers,
Mike
A_Tang
#10: 01-29-2007, 11:28 AM
 unclemat
Title: Twinscroll troll
Car: 05 LGT wagon 11MT
Send a private message to unclemat Find all posts by unclemat Reply With Quote
FWIW:
OEM EDM Subaru headlight washers turn on after holding the windshield spray button for 1 second and only when the headlights are on.
Manual:
http://www.subaru.pl/oferta/pdf/qrg/legacy-outback.pdf
Check my for sale threads: rear axles, other stock parts
unclemat
Find More Posts by unclemat
#11: 01-29-2007, 11:38 AM
 mbcracken
mbcracken's Avatar
Originally Posted by unclemat View Post
FWIW:
Manual:
If you say so...
mbcracken
#12: 06-18-2008, 09:03 AM
 A_Tang
A_Tang's Avatar
Car: '07 GT wagon
Any of you guys made any headway on this?
A_Tang
#13: 06-18-2008, 09:45 AM
 SBT
SBT's Avatar
Title: Site Majordomo
Rank: Admin
Car: SWP 05 LGTLW 5MT waiting on an S402
Send a private message to SBT Find all posts by SBT Reply With Quote
Subscribing - keep us posted on your progress.
SBT
So many mods, so little time
SBT
Find More Posts by SBT
#14: 06-19-2008, 06:11 PM
 mbcracken
mbcracken's Avatar
No progress yet. I tried to get a hold of some of the Subaru telescoping washers they sell in Europe. I sent out a couple emails to a English dealership, but never saw a reply. I really want the pop-up ones and was going tosee if I could keep psuedo OEM.
To be honest, I spend more time wrenching my bicycles then my car.
Cheers,
Mike
mbcracken
#15: 06-19-2008, 06:23 PM
 03LegacyWgn
03LegacyWgn's Avatar
Title: Looking for Suspension..
Car: 2003 BH, 93 civic Si coupe
Send a private message to 03LegacyWgn Find all posts by 03LegacyWgn Reply With Quote
what about the volvo set ups? i know the XC and some of the other models have the washers on them.
03 BH
Mods: Group A Alt & Crank Pullys and end links,
CIA, JDM L7 Grille, JDM HID lights, JDM rear tails
Stromung CBE, KYB GR2's W/ H&R springs.
03LegacyWgn
Visit 03LegacyWgn's homepage!
Find More Posts by 03LegacyWgn
Similar Threads
clear headlight mod (56k RIP) thatericguy Exterior/Aesthetic 48 03-16-2013 06:53 PM
Headlight washer... mbcracken New Zealand, Australia & Southeast Asia 3 02-08-2007 07:54 PM
Headlight Mod JayMitch2.5i Fourth Generation Legacy (2005 - 2009) 35 01-29-2007 09:42 PM
My custom headlight mod warnoldscu Exterior/Aesthetic 5 04-30-2006 06:19 PM
Another headlight mod OCDetails Exterior/Aesthetic 11 03-16-2005 09:37 PM
