Go Back   Subaru Legacy Forums > Model Specific Forums > Third Generation Legacy (1999 - 2004)
Reload this Page low brake pedal
#1: 10-03-2012, 03:34 PM
low brake pedal
 greenmech
Car: 2000 Subaru Legacy GT
Send a private message to greenmech Find all posts by greenmech Reply With Quote
I have a 2000 Legacy GT, I ve had a low brake pedal for a while and had the car looked at twice but they couldnt find anything wrong. I starting working on the brakes about a week ago when I realized that only my front calipers were working. First I replaced the master brake cylinder ( I bench bled it before installing it), also the new master brake cylinder is for a Brighton, will that still work in a GT?. Next, I replaced all four rotors, new brake pads, and rebuilt the rear calipers. Today I bled the brake system starting at the right rear wheel, then left rear, right front, and left front. During this process I filled up the master cylinder reservoir four times yet I still have a low brake pedal. Maybe a new booster? Thanks
greenmech
Find More Posts by greenmech
#2: 10-03-2012, 03:53 PM
 octain11
octain11's Avatar
Title: Word to yo matha
Car: RallyRat
Send a private message to octain11 Find all posts by octain11 Reply With Quote
check the brake lines
trust me, i am a jr model rocket scientist in training
octain11
Find More Posts by octain11
#3: 10-03-2012, 05:58 PM
 greenmech
Okay I ll try that, but, wouldnt the brake lines be working if I was able to breed all four calipers?
greenmech
#4: 10-03-2012, 05:59 PM
 greenmech
sorry "bleed" not breed
greenmech
#5: 10-03-2012, 06:01 PM
 octain11
octain11's Avatar
Car: RallyRat
ya, but you never know if they are damaged or not, always good to check everything,i find alot of times its usually the small things that cause the issue, it can be the booster though
octain11
#6: 10-03-2012, 06:05 PM
 greenmech
Okay I ll check the brake lines. I thought it might be the booster too, but when I have engine off and press the brake pedal it feels like there is pressure, then when I turn the engine on the brake pedal goes down to the floor almost.
greenmech
#7: 10-03-2012, 06:20 PM
 greenmech
So having a Brighton model master brake cylinder in a GT model is okay?
greenmech
#8: 10-03-2012, 06:25 PM
 octain11
octain11's Avatar
Car: RallyRat
hmmm, might be a problem since the brighton use rear drum brakes. i would do a google search on that, or trial and error, thats how ya learn
octain11
#9: 10-03-2012, 06:29 PM
 greenmech
I ve been google searching it for the last two nights thats why I decided to join a forum. But I think you just answered it. Thanks
greenmech
#10: 10-04-2012, 09:13 AM
 rougeben83
Car: 2003 Legacy L "Special" :D
Send a private message to rougeben83 Find all posts by rougeben83 Reply With Quote
According to rockauto.com, the catalog lists the brighton MC to be a smaller diameter than the other models with rear discs.
RAYBESTOS Part # MC390467 More Info Professional Grade; Bore Size=1 1/16" Number of Ports=2
Rear Disc Brakes
RAYBESTOS Part # MC390468 More Info Professional Grade; Bore Size=1" Number of Ports=2
Rear Drum Brakes
rougeben83
Find More Posts by rougeben83
#11: 10-04-2012, 01:45 PM
 greenmech
Yeah, I replaced the master cylinder with the correct model, and rebled everything and the problem still exsists. A friend is bringing over a power bleeder, I hope that helps but I am running out of ideas.
greenmech
#12: 10-05-2012, 05:28 AM
 ehsnils
ehsnils's Avatar
Title: Kafka was an optimist.
Send a private message to ehsnils Find all posts by ehsnils Reply With Quote
I hope that you did take care to lubricate the guiding pins for the calipers, but considering that you did replace the pads it shouldn't be the problem.
Bleeding brakes can be tough on some cars, and if you have an ABS unit you may need to bleed it separately and not just at the calipers. Make sure you rinse any spill with water well after bleeding.
Try my OBD Application Current Version 1.5.612.
ehsnils
Find More Posts by ehsnils
#13: 10-09-2012, 06:04 PM
 greenmech
Thanks for all your suggestions, it turns out I just had the calipers upside down, Thanks
greenmech
#14: 10-11-2012, 02:14 AM
 ehsnils
ehsnils's Avatar
Wut?
Did you mix up right and left side?
I didn't know that it even was possible otherwise.
ehsnils
#15: 10-11-2012, 04:31 AM
 octain11
octain11's Avatar
Car: RallyRat
Originally Posted by ehsnils View Post
Wut?
exactly what i thought, unless you have 4 or 6 pots they might look some what similar on opposite sides......
octain11
