Reload this Page Whiteline LCA bushings for DD?
Page 1 of 4 1 23 > Last »
#1: 10-04-2012, 11:10 AM
 Chicago
Car: 09' 2.5i SE
Send a private message to Chicago Find all posts by Chicago Reply With Quote
Hey guys,
I've been having some troubles with my suspension, and based on how it drives, the advice from others on the forum, and stories from others with similar problems, it looks like I have broken Endlinks and/or LCA bushings. Since Endlinks are cheap, I picked up a set of Rallitek HD to upgrade a bit. When I install those, I am going to inspect the bushings as well. Before I get into that, I've been doing some research on the subject, and I need some advice. I am a somewhat agressive driver when the car is handling normal, but unfortunately, a majority of my driving is the commute to work (1 hr both ways). I already have 58k miles on a 2009. That said, this car will never see a track of any sorts, especially since I don't have the turbo. I still want to have some fun driving, but will installing polyurethane bushings (i.e. Whiteline), make it a rougher ride for mainly a DD? I'd like to upgrade, but don't want to sacrifice the ride at the same time. These are basically my options (for driver and passenger):
1) Whiteline front LCA bushings: ~$165 + labor
2) OE replacement bushings: ~$46 + labor
3) OE replacement LCA w/ bushings and ball joints: ~$356, and I can install myself.
I'm hesitant to try to remove/press the bushings myself, as I am not very experienced with things of this nature, and I don't have any mechanic friends.
Thoughts?
Chicago
Find More Posts by Chicago
#2: 10-04-2012, 11:13 AM
 Chicago
Car: 09' 2.5i SE
Also, I am on a budget, so forking out $300+ is not easy. At the same time, I hear horror stories about these bushings, and if upgrading means I won't have to replace them often, that is a bonus given that I plan on driving this car into the ground.
Chicago
#3: 10-04-2012, 11:14 AM
 a93x
a93x's Avatar
Title: Contributing V.P.
Car: 06 LGT Racekor
Send a private message to a93x Find all posts by a93x Reply With Quote
Just put on the whiteline LCA bushings a few weeks ago, love them so far. I would def recommend. I watched my mechanic friend do mine and I would for sure say to have someone do it for you. There quite the ***** to get out of the car, and then to get the or bushings out of the arm.
a93x
Find More Posts by a93x
#4: 10-04-2012, 11:17 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Go with the up grade bushings,
Pay the man to do the job
You should not need ball joints, ever in most of these cars.
I have whitelins and AVO in my LCA, been there for many years. No difference in the ride.
Max Capacity
#5: 10-04-2012, 05:05 PM
 adreyna
adreyna's Avatar
Car: 05 Subaru Legacy GT 5EAT
Send a private message to adreyna Find all posts by adreyna Reply With Quote
yea Im in the process of getting stuff together to do mine. I got a good deal from BostonMortorSports here on the forum, $158 shipped for whitelines. Thinking of having my friend do them for me since I recently had shoulder surgery, and I don't have money to fork out for the install.
adreyna
Find More Posts by adreyna
#6: 10-05-2012, 09:34 AM
 boxkita
boxkita's Avatar
Car: 05 Legacy GT wagon Stg doghouse
Send a private message to boxkita Find all posts by boxkita Reply With Quote
I run a full set of whiteline bits (setup for the track) on what has become a daily driver (28 miles of stop-go traffic). Other than the beating I take on downtown streets (lowered with very little suspension travel), I have had no problems. In fact, having the upgraded bushings seems to help when a quick burst is needed to squeeze into a space.
Changing your springs/shocks will have a far greater effect on your comfort, than the LCA bushings.
Build my car
Buy it ready to go
Boxkita Track days
boxkita
Find More Posts by boxkita
#7: 10-05-2012, 09:37 AM
 Yamifanatic
Send a private message to Yamifanatic Find all posts by Yamifanatic Reply With Quote
do the bushings i have them in my sti which i DD, honestly it just firms up everything and takes out the slop.
Yamifanatic
Find More Posts by Yamifanatic
#8: 10-05-2012, 12:41 PM
 adreyna
adreyna's Avatar
boxkita you should help me install mine!
adreyna
#9: 10-05-2012, 02:19 PM
 robitrice
Car: Driveway Ornament
Send a private message to robitrice Find all posts by robitrice Reply With Quote
i love whiteline, i got them and they are fine for dd use.
robitrice
Find More Posts by robitrice
#10: 10-05-2012, 02:21 PM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Car: 2013 NC3 CLUB, 05 OB 3.0R
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
+1 to all this.
4-Time NNJR ESP Season Champion -15 ESP
3rd Place in 09' Pax Championship/Driver of the Year
2012 Northeast Divisional Champion in ESP
whitetiger
Find More Posts by whitetiger
#11: 10-05-2012, 02:59 PM
 boxkita
boxkita's Avatar
We would be a pair, I'm clueless and you're helpless. Actually, I need to swap my brakes this weekend. Bring your car down and we can work it together. I'm willing to learn new stuff (I did this once on my '70 Challenger)
Build my car
Buy it ready to go
Boxkita Track days
boxkita
#12: 10-05-2012, 11:13 PM
 turbomacharged
turbomacharged's Avatar
Car: 05 Legacy GT Limited Sedan
Send a private message to turbomacharged Find all posts by turbomacharged Reply With Quote
adreyna, was that $158 for all four (2 sets, rear bushings and inner bushings) from Boston? Curious because my car has been saying its time and may as well do it all at once.
turbomacharged
Find More Posts by turbomacharged
#13: 10-06-2012, 04:23 AM
 adreyna
adreyna's Avatar
^Yup! Got them delivered today! I just need to get some tools together! Yea pm BostonMotorSports. I got WL yellow kc334 and w0506
adreyna
#14: 10-06-2012, 11:16 AM
 AZP Installs
AZP Installs's Avatar
Title: Vendor II
Car: 05 LGT->11 STi & 12 JagXJ & 04 Armada
Send a private message to AZP Installs Find all posts by AZP Installs Reply With Quote
We also carry and have installed a ton of the rear and inner WL bushings. We are also an authorized whiteline performance center, which means if they do fail later on, whiteline will stand behind them, those purchased from Internet Walmart companies/non authorized dealers may be questioned at warranty time.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs
Find More Posts by AZP Installs
#15: 10-06-2012, 12:26 PM
 lingling1337
lingling1337's Avatar
Car: 06 Sedan BNR16G/Cryotune
Send a private message to lingling1337 Find all posts by lingling1337 Reply With Quote
I like my Gp. N front and Whiteline rear bushings for dd, no increase in NVH.
EDIT: Pulling and re-installing the LCAs isn't too hard, I'd just pay to have someone press the bushings. If you aren't comfortable with that though, I would say pay someone to install rather than buying a whole new LCA assembly. My shop quoted an hour a side to replace the bushings, so $170 in labor.
lingling1337
Find More Posts by lingling1337
