ScoobySnax Posted October 5, 2012 Share Posted October 5, 2012 So I have a 2005 Legacy GT with an SPT intake and Cobb AP. Every once in a while the boost drops and it runs sluggish. Now I started to monitor the boost and it was 8.8lbs tonight. Now it will usually go back to normal when I reflash it but I dont feel I should be having to reflash every week. Does anyone have any idea or any experience with this. Sorry if it has been posted before, I have been searching for the past 30min today and many times in the past. Oh yea, I got the AP back in May 2012 and this started happening around late Aug 2012 Link to comment Share on other sites More sharing options...
chaz517 Posted October 5, 2012 Share Posted October 5, 2012 Does limp mode kill boost like this? That could be it Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 5, 2012 Author Share Posted October 5, 2012 what is limp mode Link to comment Share on other sites More sharing options...
Nrw Posted October 5, 2012 Share Posted October 5, 2012 boost leak test Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 5, 2012 Author Share Posted October 5, 2012 I dont think its a boost leak because it goes back to normal when I reflash it again Link to comment Share on other sites More sharing options...
chaz517 Posted October 5, 2012 Share Posted October 5, 2012 Limp mode is pretty much when the car senses something isnt running right and reduces power to prevent damage. Flashing the ecu every week to fix it probably is not a good idea, but again not sure if thats what is going on w ur car right now. Check all your hoses just so u can cross that off ur list Link to comment Share on other sites More sharing options...
EJ25subie05 Posted October 5, 2012 Share Posted October 5, 2012 sounds like a boost leak to me. are you tuned for that intake? my intake caused me more problems then i knew what to do with and took it off and set it on my table ever since. waiting for a pro tune Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 5, 2012 Author Share Posted October 5, 2012 hmm, do you think I should divorce the AP to see if it helps until I get it pro tuned Link to comment Share on other sites More sharing options...
EJ25subie05 Posted October 5, 2012 Share Posted October 5, 2012 you didn't say anything about a dp or anything so I'm assuming your only on stage 1? put your stock intake back on, and if the mods you have allow you to go back to stock then divorce the AP and see if the problem still occurs. are you using your AP to monitor boost or a gauge? Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 5, 2012 Author Share Posted October 5, 2012 yea, just stage 1 for now. I was using the boost controller on the AP. I think im gonna take your advice and go back to completely stock tomorrow. I hope it works. Do you think I should reflash to correct it then divorce it??? Link to comment Share on other sites More sharing options...
cryo Posted October 5, 2012 Share Posted October 5, 2012 Normally the ap alone should not cause these issues. It may be something mechanical causing the ignition advance multiplier to drop thus wastegate boost. Pull up your live monitors and look at dynamic advance multiplier or DAM while you are seeing the 8.8 psi issue. Is it less than 1.0? Its hard to say without some logs but stg 1 is normally pretty strait forward. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Berzerklo Posted October 5, 2012 Share Posted October 5, 2012 Those SPT intakes are notorious for messing with your MAF readings. Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 5, 2012 Author Share Posted October 5, 2012 I took off the AP for now and putting the stock intake back on this weekend. If everything goes well then Im gonna try the AP again in 2 weeks. I hope I will have good news by then. Thanks Dave, Im gonna post the data when I try again in 2 weeks cuz I didnt see your post before I took it out. I really appreciate all the quick responses. This is my first Subaru and first time using forums for help. The Subie family is really a great family. Link to comment Share on other sites More sharing options...
cryo Posted October 8, 2012 Share Posted October 8, 2012 There are great members on this forum, its the best online community i have had the pleasure of being a part of. Keep us updated. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
cryo Posted October 18, 2012 Share Posted October 18, 2012 Any updates? Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 19, 2012 Author Share Posted October 19, 2012 So I have had the AP off for 2 weeks and no issues. I had to work all last weekend and weather was kinda shitty with no garage the first weekend. Hope to put my stock intake back on this weekend while hooking the AP back up. Link to comment Share on other sites More sharing options...
iNVAR Posted October 20, 2012 Share Posted October 20, 2012 as a previous poster said, check the dam. if your dam is dropping, find out what the reason is. do not reflash. that is 1) unnecessary. an ecu reset does the same thing 2) masking the problem that the dam drop is trying to help with. your car is likely pulling timing for some reason and that's why dam is dropping. Link to comment Share on other sites More sharing options...
robinlsb Posted October 20, 2012 Share Posted October 20, 2012 The SPT intake is a POS. It runs hotter than the stock air box, screws up the MAF, and god knows what else. Cobb did a comparison test between the stock box and the SPT. Look it up on Cobb's web site. The SPT was worse than stock in all areas. Hot intake air will reduce boost and timing to prevent detonation. I suspect that is your problem. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
YourConfused Posted October 20, 2012 Share Posted October 20, 2012 I am not even close to knowing as much about tuning parameters as Dave, but I do know that the SPT intake is not a good design. It induces turbulence at the MAF which causes irregular readings AFIK. Also, as I understand it, COBB does not have their stage 1 or 2 maps tuned for a aftermarket intake of any sort. I may be wrong about anything I stated above, so just look into what I said and see for yourself if you find any truth in it. As far as a boost leak goes, well who knows? It may be so or not, but in either case you could benefit yourself by looking for a leak and as a byproduct, familiarize yourself with the motor's induction side. It could be a win/win. You gotta start the learning process some where, so just pick something, learn it, and move on. This way you will get to know your car and also eliminate variables in the process. Good luck with it all. Link to comment Share on other sites More sharing options...
ScoobySnax Posted October 26, 2012 Author Share Posted October 26, 2012 Forgive me for my ignorance, but what is a dam? I took off the intake today and married the AP again. I put about 75 miles on it just driving around and so far so good. Some people have asked me to log some of my data but not exactly sure how to or which data to log exactly. There are so many options on the AP. Link to comment Share on other sites More sharing options...
Flipapotimus Posted October 26, 2012 Share Posted October 26, 2012 Forgive me for my ignorance, but what is a dam? I took off the intake today and married the AP again. I put about 75 miles on it just driving around and so far so good. Some people have asked me to log some of my data but not exactly sure how to or which data to log exactly. There are so many options on the AP. COBB video on Data Logging here http://www.youtube.com/watch?feature=player_embedded&v=IlHP4gFiVrY Also here is the COBB link to other tutorial videos about the AP, they are at the bottom of the page. http://www.cobbtuning.com/AccessPORT-Support-s/40200.htm Link to comment Share on other sites More sharing options...
