10-06-2012, 01:13 PM
Rebuilt engine installed..but now misfiring?
Just got my engine totally rebuilt. Installed it last night and i have a constant misfire in cylinders 1 and 3 (right side bank) Checked coils, not the problem. Spark plugs are new ( NGK iriduim 1 step colder) gapped to .030. coils are getting spark and injectors are getting signals (checked with noid light)
Is it normal for a rebuilt engine to misfire ?
only ran it for about 20 minutes..
help!
10-06-2012, 01:23 PM
No it's not normal.
Can you swap plugs and see if the misfire moves.
I can't remember what I gaped my plugs at. But I don't think it was that small.
10-06-2012, 01:26 PM
didnt swap the plugs...their new so its not like their fouled out or anything
10-06-2012, 01:28 PM
Title: Kafka was an optimist.
It's not normal, and the first thing I would check is that the cam timing is correct since that's a common part for those cylinders.
And do a compression test to verify that nothing is wrong.
Other causes may be the manifold gaskets on that side and fuel feed. Also check that the TGV:s works as they should (if you have them).
10-06-2012, 01:29 PM
timing looks ok (all the marks line up accordingly
wouldnt i have a TGV fault if they werent working?
10-06-2012, 01:31 PM
I think he's saying you may have a leak in one of the gaskets or seals.
But that would present its self as a vacuum leak, right ?
10-06-2012, 01:35 PM
i dont think theirs a vacuum leak... while its running i sprayed brake cleaner over all the joints (intake manifold, TGV's TBhose, vacuum lines ,etc) and no noticable difference in RPM
10-06-2012, 01:37 PM
also im on my EFI logics map tune wise...should i go back to the stock map or does that make a difference?
10-06-2012, 01:46 PM
It has to be something simple.
Make sure all connectors are installed tightly.
Step back, deep breath, get a bite to eat, look everything over.
10-06-2012, 01:48 PM
thats what i keep saying lol
i left the car. il do something about it tomarrow just trying to go over everything in my head.
idk what it could be
10-06-2012, 01:49 PM
headed out for the evening my self.
Good Luck
