Reload this Page Boost Leak at TGV Plate??
#1: 09-27-2012, 06:08 PM
 Bugeye2GT
Bugeye2GT's Avatar
Car: 09 QSM LGT
Send a private message to Bugeye2GT Find all posts by Bugeye2GT Reply With Quote
Hey All, I'm in the process of getting E-tuned by Shamar and he told me the data log indicated a boost leak. I used a smoke machine to test the intake tract by capping off the intake hose and applying smoke through the BPV diaphragm hose. I found a leak in a very unusual spot.
On the right head (passenger side), the TGV assembly has what looks like a block off plate of some kind on the end closest to the turbo. At first I thought it might be the inlet hose leaking but it definitely seems to be coming from the bottom edge of this plate. Is there some kind of gasket or O-ring under this plate that may be leaking? I didn't see any cracks or anything in the housing. The TGV's are factory AFAIK.
I need to get this fixed ASAP hopefully without having to pull the manifold. Any help would be greatly appreciated. I've enclosed some pics. The plate is in the middle of the pic and is secured by two phillips head screws. The black hose to the left is the turbo inlet. Thanks
Name:	Boost leak block off plate 1.jpg
Name:	Boost leak Block off plate 2.jpg
BTW the grey stuff on there is some gasket maker that I put on to hopefully seal it but I wiped off because I didn't have time to let it dry. I'm going to reapply it tomorrow morning and let it dry while I'm at work.
Bugeye2GT
Find More Posts by Bugeye2GT
#2: 09-27-2012, 06:20 PM
 CapnJack
CapnJack's Avatar
Car: 2007 Legacy GT Stage 2, 2008 Legacy 3.0R
Send a private message to CapnJack Find all posts by CapnJack Reply With Quote
http://legacygt.com/forums/showthrea...rs-192275.html
CapnJack
Find More Posts by CapnJack
#3: 09-27-2012, 06:28 PM
 Bugeye2GT
Bugeye2GT's Avatar
Car: 09 QSM LGT
That's it exactly! Thanks. Damn, looks like I'll be pulling the mani on Saturday if the gasket maker doesn't work tomorrow.
Bugeye2GT
#4: 09-27-2012, 07:04 PM
 Bugeye2GT
Bugeye2GT's Avatar
Car: 09 QSM LGT
Has anybody resealed one of these yet? I'm wondering if I can get away with applying some JB weld along the edge of the plate without removing the TGV's.
Bugeye2GT
#5: 10-05-2012, 06:15 PM
 Bugeye2GT
Bugeye2GT's Avatar
Car: 09 QSM LGT
Just as a follow up......
I used some JB Weld to seal the plate without removing the manifold. Removing the engine cover and turbo heat shield allowed me to get a clear shot to apply the JB with a screwdriver, coolant hose pick and a mirror on an extendable rod. I used JB weld because it had the highest listed temperature resistance of the epoxy like glues.
The new logs are in and so far so good. No more boost leak! I'll continue to monitor it, but hopefully the JB will hold up in the long run.
Bugeye2GT
