Go Back   Subaru Legacy Forums > General Forums > New Member Introductions
Reload this Page 1986 Subaru LEONE STi TURBO
Page 1 of 8 1 23 > Last »
#1: 12-12-2012, 04:52 PM
 nico i wrx u
nico i wrx u's Avatar
Car: 1986 Subaru LEONE STi TURBO
Send a private message to nico i wrx u Find all posts by nico i wrx u Reply With Quote
1986 Subaru GL-10 Turbo AKA Leone (italiano)
we start of with a stock 1986 Subaru GL-10 FWD TURBO orig 28,000kms 17398.miles. weight is 910kg 2002lb car !!
the parts car for awd and 5x100 86 xt6
so what we have hear is to add the 4WD system into one of these cars, those are 20MM sway bars, above the sway bars is what holds the diff, about that is a mix and match of old and new to hold the STi 6mt, above that is a updated version of control arms to hold the 5x100 knuckle.
rear axle XT6 for the R180 3.900, there is a trick to these where i mix the outer with the new style inners to run a R180. or i could just stay light weight and put a R160 in it.
cusco motor tranny mnt
ARP head studs, Cam & Crank sensor new oem
Spare EJ22T Built @ SUBARU TECNICO INTERNATIONAL
just got a little eye candy from Jon at full race coming soon !!
Well got half the brakes sorted out for the project
so got a little oem new parts in today xt6 wheel bearings, xt6 steering tie rod, mustache bar bushings, and new diff support. also have 2006 wrx 2pot rear backing plates, but i sent them out to a friend's machine shop to make a ring for the centering ring
new turbo set up full race twin scroll
nico i wrx u
Find More Posts by nico i wrx u
#2: 12-13-2012, 08:55 PM
 nico i wrx u
so parts list is
VER 8 Sti complete
Vi-PEC V88
EXEDY ?? dont know yet maybe multi plate to hold the power
SPARCO seats: maybe, kind of want it stock but need support lol
Rims: gc8 and volk jdm if i can find them
Tire's : RACE SLICK lol for evey day haha !!
new rotor pads that wont stop this much power to weight lol
my rear control arms, that me and my dad had to make a tool becuase no one on the plant has one lol
little thermal coat so then i can wrap them
got some tubes to make my wastegate pipes longer away from everything
Little powder coat action
Got my 2006 wrx backing plates all fixed up so they can fit on the hub the xt6 hubs as instructed from Suberdave !
So I went and picked up a Jdm spec c version 8 (maybe type RA?) motor swap Ej207DW7ER TY856WB6JA for heads and tranny diff and way ever else I need to twist my leone in to pretzel lol
Also I was driving to see the boys at Nvauto and I seen a gc impreza on top of another car scrap yard ! so I found the rims I wanted for a steal 250. So I sent them out to the sand blasters to get ready for the powder coating. I'm thinking world rally blue color for the rims
started stripping for what i need
EJ22T built bottom end, JDM EJ207 STi Version 8 Type RA heads all oem !
finished wrapping my headers and turbo
and got my PURPLE KUSH rims back from the powder coaters, two more sets to do with other crazy colours
nico i wrx u
#3: 12-13-2012, 09:03 PM
 nico i wrx u
test fit my full race twin scroll kit
also so i just got this hood in what should i put on it ? what type of vents ? side ones or scoop it or cut it and make vents up the middle
some thing like this and a scoop ?
also got the sti key to work, i went to home depot cut the key and it worked perfect
Exedy twin plate HD is ready for the power
HSD coilovers are here with extra rear mounts
Tial BJ VALVE
The Subaru Gods said Let there be ROCK ! AC/DC DC/AC DCCD control !!!
factory gl-10 flares
well well well look what has the same shape as the gl-10 !!! do i see 245 45 16 in the future ?
also a sneak peek at my military grade aviation 1 plug engine harness plug which connects my subaru tecnico international built EJ22T motor to the V88 ViPEC ECU. Custom made by Franz diebold @ diebold autosport
nico i wrx u
#4: 12-13-2012, 09:06 PM
 nico i wrx u
well no room for a FMIC kit so next best thing !! AWIC..... i got a hole spare tire room for this set up, its even nice and light weight.
the rad which will be mounted like this cut weld the cap off
bosch pump and cap
well my PRODCCD is in ! thanks Jeff @ PRODCCD for helping me out !! amazing high quality product cant wait to put it to good use
some whiteline race tranny mount bushings with a cusco tranny mount. this cross brace is a mix of old 1986 subaru XT6 with center section new school to make the STi 6mt fit.
all ready to go !
water cooler intercooler rad ready to go, core was pressure test also no leaks !!
well i had to get this not a super fan of gold rims but its a subaru thing and i had to ! some thing like 13lbs is a must on a light weight Leone Turbo monster !
JDM GC8 STi RAY'S TE37 5x100 16x7 ET53
well this was Franz's idea on welding the cap set up and my Tial Bov set right on the AWIC and it turned out F amazing
nico i wrx u
#5: 12-13-2012, 09:08 PM
 nico i wrx u
and push lock hose PARKER and fittings PARKER which cost more then the hole awic set up LOL
also this came in my new calsonic OEM 1986 subaru gl-10 turbo radiator 5mt version.
real JDM LOL
my STi clutch slave & 4 Port brake master all OEM factory brand new Subaru.
well my spal made in italy fans came in
mounted ready to drop in.
a special treat the front OEM Subaru front skirt for my car brand new ! slice the wind !
had to put it on just did it
it has started ! tomorrow drop motor tranny in start work on other things.
new clutch set up and brake cyl.. pedals in also
nico i wrx u
#6: 12-13-2012, 09:09 PM
 nico i wrx u
motor tranny full race in and fits perfect with out doing anything. just need to make a tranny brace its a little different but piece of cake !
i was thinking it was going to be a tight fit ! there is lots of room might put a bigger rad if the oem stock one pops !
full race twin scroll fits perfect
moved the power steering lines out a little ! all better now
clutch all ready
full race fits nice !!
STi 6mt fits perfect just need to make a brace and its good
new style pedal box in and ready need to make a gas pedal, and a bracket way up top.
nico i wrx u
#7: 12-14-2012, 03:16 PM
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
Fun project - should keep posting (10) and get those wheels up for sale again Nico!
spec.B #163 Build Thread with Pictures
Get CryoTuned!
LGT.com 2006 spec.B Registry Mapped
.:Catalyst:.
Find More Posts by .:Catalyst:.
#8: 12-14-2012, 05:53 PM
 nico i wrx u
well this just worked out perfect ! its like subaru new i was going to stick a water pump for my AWIC set up.
Bosch 044 fuel pump, need some angle fitting and done.
rear mustache bar is ready to hold the R180 just need to make a bracket for the front of the diff and done.
well this is the tie rod problem taken care of, its simple and works perfect like !
top is xt6 legacy impreza
middle gl-10 turbo
last is whiteline new style
what you do is chop the end off so you can toe in the car like factory !
light weight knuckles ! top secret so the competition dont know !
4pot ready for action ! brembos maybe in the future but who cares really when your going to be this light and fast lol
rear just started so sunday all done.
the rear suspension is all old school up top and coilover down town, ill show how i did it very easy to do and keeps all the oem rubbers for when i pick up the ladys and its a nice soft ride !
HeLLaFLuSH for all you pimping OG's out there !....... these wheels are just to roll it out the shop on monday ! i like to go HELLaFAST LOL.
bed time
well rear is all done suspension knuckles and rims tires
nico i wrx u
#9: 12-14-2012, 08:18 PM
 wurkenman
wurkenman's Avatar
Title: Contributing V.P.
Car: 05 LGT(mine), 07 Legacy 2.5I (wife's)
Send a private message to wurkenman Find all posts by wurkenman Reply With Quote
Looks like it will be a fun toy.
If you woke up today, you have another chance to do it right.
I have the typing ability of a epileptic in a strobe lit room typing with boxing gloves.
wurkenman
Find More Posts by wurkenman
#10: 12-14-2012, 08:49 PM
 PeterJMC
PeterJMC's Avatar
Title: Lvl 63 Night Elf Dwarf Paladin
Car: '10 Toyota Prius: Racecar Edition
Send a private message to PeterJMC Find all posts by PeterJMC Reply With Quote
Great first post! Welcome to the site. I'm looking forward to the progress of your project.
'10 Prius: Racecar Edition
PeterJMC
Find More Posts by PeterJMC
#11: 12-15-2012, 06:47 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
Holy smokes! That is awesome! Thanks for posting your project up.
monkeyposeur
Find More Posts by monkeyposeur
#12: 12-15-2012, 07:44 PM
 lee07
lee07's Avatar
Send a private message to lee07 Find all posts by lee07 Reply With Quote
Wow, Total sleeper. How much already in parts? 4k?
lee07
Find More Posts by lee07
#13: 12-15-2012, 07:56 PM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
Car: 2009 SWP Grandma XT-B (5MT)
Send a private message to BAC5.2 Find all posts by BAC5.2 Reply With Quote
Wow! Nico is not a name I've heard for many years. I hope everything is going well, and I can't wait to see this thing come together.
The Following User Says Thank You to BAC5.2 For This Useful Post:
thefultonhow (12-16-2012)
BAC5.2
Find More Posts by BAC5.2
#14: 12-15-2012, 10:06 PM
 nico i wrx u
Omg is that Phil legacy central days !! Man I'm good same old nothing new but this old Subaru I picked up and decide to build it.
How you been man ? No more real real legacy turbo :•) ?
Lol ya a bit under cover, but price is very very high in
Thanks man it's moving along nicely now
Thank you ! I joined along time ago but never real came on. The Subaru world sure has exploded into allot of people now.
and my amazing light weight battery came in and its in my winter beater to keep it warm for when the Leone is done
my old school momo hub found in germany !!!
flowmaster hush muffler !! only thing that can fit on this little car !
this is what my tip will look like after i weld it all up. but with a foot of pipe in the middle of the two.
my pipe 3' 304 polished
support for the front lip, oem subaru
put them on
Franz crazy at work on my wiring, this is only half the paper work on my stuff.
and the pin porn for the wiring he is doing for my hole car !
r180 read for service !
my brand new Bosch 044, these fittings are from the UK for the ford cosworth ! who would have guessed the Leone had the same set up !!
nico i wrx u
#15: 12-15-2012, 10:07 PM
 nico i wrx u
my hsd front camber plates came in ! thank you JRP for letting me do what i had to do to get my suspension all sorted out !!.
the front is a bit to low, which will come up after corner balance and aliment get worked out. i wouldnt want the honda crowd thinking i want to race lol.
i didnt want to add this but i need a bigger opening or else i could not use 2nd 4th 6th or R gear !.. so STi plate with boot, just waiting for the bolts to come in now.
AWIC pipes and other bits which is moving along nice and smooth. couple back order stuff which is killing me ! summer is all most done.
clutch line made fluid and bled, ready to go
this picture is just crazy all in its self !!! it makes me not even want to drive this car and put it away for another 26years !!!!
Franz Diebold wiring Diebold Autosport ! its just so beautiful i am speechless !! thank you Franz.
shifter plate is all done bolts in.
my LC1 is ready to auto tune and get me going till Franz comes and really dials it in
and the diff is mounted in ready to go
the bracket my father made extra strong so the diff dont end up down the street LOL
nico i wrx u
