Go Back   Subaru Legacy Forums > Technical Forums > Wheels/Tires
Reload this Page HELP!!! Broken lug nut..
Page 1 of 8 1 23 > Last »
#1: 06-14-2012, 06:36 PM
(update) HELP!!! Broken lug nut
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
Send a private message to SpecBGuy Find all posts by SpecBGuy Reply With Quote
so today i finally decided to grease up my brake calipers from all the noise. the place i got my alignment from over torqued my lugs i got 4 off but the last one just broke in half while i was trying to loosen it.
anyone know if a shop can take this off or diy?
thanks
ID:	120157   Click image for larger version
ID:	120158   Click image for larger version
SpecBGuy
Find More Posts by SpecBGuy
#2: 06-14-2012, 06:38 PM
 NWSPECB
NWSPECB's Avatar
Title: ------------------------
Car: Spinach Powered Ship
Send a private message to NWSPECB Find all posts by NWSPECB Reply With Quote
I would put them all back on and drive to the shop that did your alignment and make them deal with it.
NWSPECB
Find More Posts by NWSPECB
#3: 06-14-2012, 06:47 PM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
yes i would love to but its been 6+month since i went to the shop so i doubt they will take the blame or deal with it.
SpecBGuy
#4: 06-14-2012, 06:52 PM
 NWSPECB
NWSPECB's Avatar
Oooohhh. I was thinking this was a recent thing. As in like a last weekend thing or something.
Well I have no idea how you could get that thing out of there. I would still take it to a shop and at least see what they think.
NWSPECB
#5: 06-14-2012, 06:53 PM
 meier motor sports
meier motor sports's Avatar
Title: nice phone
Car: back in the wagon
Send a private message to meier motor sports Find all posts by meier motor sports Reply With Quote
gona be a pain in the ass. try to rotate it off with a hammer and chissel. or try drilling out the stud with a drill bit. drill slow and be paitant use lots of lube and prevent heat and burning up the bit.
meier motor sports
Find More Posts by meier motor sports
#6: 06-14-2012, 06:57 PM
 meier motor sports
Title: nice phone
can try this tip as well. depends on whats left
Removing a stripped security wheelnut - YouTube
meier motor sports
#7: 06-14-2012, 07:02 PM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
i dont want to use a hammer and a chisel since i might damage the studs but i did think about using a drill bit or some kind of filing. its going to take for ever. im thinking getting a powered hand saw but im not even sure if that will fit through the tiny space.
how much does it cost to replace the stud?
SpecBGuy
#8: 06-14-2012, 07:04 PM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
i have less then half of the lug left so this is out.
im just wondering how a shop would take this off
SpecBGuy
#9: 06-14-2012, 07:55 PM
 No DRFT
No DRFT's Avatar
Title: Buy a shotgun
Send a private message to No DRFT Find all posts by No DRFT Reply With Quote
I think that would be the only feasible way of getting it out. There's actually sockets that you can buy that has reversed grooves inside, that'll grip onto the lug nut. It's used for stripped bolt heads.
Try sears or advance auto and auto zone.
No DRFT
Find More Posts by No DRFT
#10: 06-14-2012, 07:57 PM
 NWSPECB
NWSPECB's Avatar
I could be wrong but I really doubt one of those types of sockets will work. The ones I have, and others I have seen, are usually pretty thick-walled sockets and most likely will not fit between the lug nut and the wheel. Worth looking into though to at least see if a set might work.
The Following User Says Thank You to NWSPECB For This Useful Post:
nomis13 (06-16-2012)
NWSPECB
#11: 06-14-2012, 08:19 PM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
17mm sockets fit perfectly with the lugs i have so if i lose my lug key i could use it. for this broken one it barely has anything to grip so it doesnt work. i might try hammer in 16mm and try it but again i dont think it has enough lug left.
fckkkkkkkkkkkkkkkkkkk
SpecBGuy
#12: 06-14-2012, 09:03 PM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
would this work?
http://youtu.be/xn11s1SmAPY
SpecBGuy
#13: 06-14-2012, 10:25 PM
 No DRFT
No DRFT's Avatar
You better not do that shit.
You'll possibly ruin the studs and grind out the lug holes. Plus it's not safe.
Chisel that shit out
No DRFT
#14: 06-15-2012, 12:15 AM
 SpecBGuy
SpecBGuy's Avatar
Car: 08 Spec.B
haha it was just a thought but i know i wasnt going to do that. how much do new studs run?
SpecBGuy
#15: 06-15-2012, 12:48 AM
 NWSPECB
NWSPECB's Avatar
Couple bucks a stud typically.
In the Portland, OR area? Head over to Camas and visit us at Caps N' Taps Bottle Shop and Taproom! Opening early May!
NWSPECB
