Reload this Page Dead battery, now won't jump
#1: 10-04-2012, 07:53 AM
 LegacyLtd
LegacyLtd's Avatar
Send a private message to LegacyLtd Find all posts by LegacyLtd Reply With Quote
Last night my wife let the battery die in our 2005 Legacy GT Ltd (5EAT) and this morning I was fortunate enough to find it in such a state before work. I tried to use a jump box, but when I return to the ignition, I get mad clicking from the starter when I attempt to turn the key. I tried a few different things, battery connection, checking the voltage on the box, everything is fine. What I read was that having a dead battery, or replacing a battery, can wreak havoc w/ both the ECU and the security system, which my car has. What I was wondering was if anyone else has encountered this problem, and what they did to solve it. I read that if I disconnected my battery and turned the key to the on-position before replacing the terminal might give me some luck, but all that did was result in a rapid beeping from the dashboard. I tried sorting through vacation pics, but all I have is from 2004, and even then I had no luck.
LegacyLtd
Find More Posts by LegacyLtd
#2: 10-04-2012, 08:04 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Have you cleaned the battery terminals ?
Are you sure the jump box is working ?
It's time you put a new battery in the car that is that old any way's.
Just removethe old one, clean the terminals, install the new one, I grease the terminals afterth einstall to keep them dry, then start the car.
It really is that simple.
I replaced mine at 5 y/o. with a Maxx everstart from Walmart.
Max Capacity
#3: 10-04-2012, 08:04 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Car: 2013 NC3 CLUB, 05 OB 3.0R
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
is your jump box well charged? a voltage check alone does not necessarily indicate whether it's good or not. only a draw test cant determine if it still can supply enough cranking amps to get your car going.
4-Time NNJR ESP Season Champion -15 ESP
3rd Place in 09' Pax Championship/Driver of the Year
2012 Northeast Divisional Champion in ESP
whitetiger
Find More Posts by whitetiger
#4: 10-04-2012, 08:20 AM
 LegacyLtd
LegacyLtd's Avatar
Well, I tried 2 different jump boxes (father-in-law works for a certain mobile lock service), both are confirmed good. Terminals are clean and battery was replaced when I bought the car 11 months ago. When I run the jump-box to the battery and start as a relay, I have plenty of juice going to the starter, but the starter just clicks. Is it possible this is something to do with the immobilizer/security system?
LegacyLtd
#5: 10-04-2012, 08:26 AM
 cypher0117
cypher0117's Avatar
Title: Need more fast!
Send a private message to cypher0117 Find all posts by cypher0117 Reply With Quote
hit your starter a few times with something hard (but don't damage it). could be your starter solenoid isn't fully engaging. OR you could just remove the starter and get it tested at a local auto parts store.
cypher0117
Find More Posts by cypher0117
#6: 10-04-2012, 08:43 AM
 LegacyLtd
LegacyLtd's Avatar
That is my next step, however I have to wait until after I get off work, so I'll post an update in the afternoon.
LegacyLtd
#7: 10-04-2012, 08:54 AM
 whitetiger
whitetiger's Avatar
Title: IDGAF
the immobilizer does not prevent starter operation, it only stops ignition. so you can crank the engine, but not get the engine going. if battery source is good, then you may have a frozen starter solenoid. whack it with a hammer.
whitetiger
#8: 10-04-2012, 08:57 AM
 Matt166
Send a private message to Matt166 Find all posts by Matt166 Reply With Quote
I had similar problems in my old car, non subaru.
Did you check the voltage from the positive terminal on the starter (not the wire from ignition? If that's good and you hear the solenoid click when you turn the key, its probably a bad starter. I am not sure if there is a safe way to test this voltage while someone turns the key, but if there is, if the voltage drops dramatically you have bad connection/battery, if it doesn't drop at all but the solenoid engages, your starter is toast.
FWIW starters on these cars are way easier than my old RSX, you had to remove the whole friggin intake manifold to do it, most independents were quoting $750, crazy. I did it myself. The starter on my LGT looks a breeze in comparison.
Matt166
Find More Posts by Matt166
#9: 10-04-2012, 10:07 AM
 Max Capacity
Title: Gearhead
RSX, that's a K-series, on a B-series starters were easy.
OP, you may want to pick a rebuilt starter from the auto parts store on the way home.
Max Capacity
#10: 10-04-2012, 01:34 PM
 LegacyLtd
LegacyLtd's Avatar
Occam's razor wins again. New jump box borrowed from a friend worked just fine. Thanks for the help, though.
LegacyLtd
#11: 10-04-2012, 01:43 PM
 Wheelbuilder_25
Car: Black 97 Outback or Silver 09 Legacy SE
Send a private message to Wheelbuilder_25 Find all posts by Wheelbuilder_25 Reply With Quote
I know you've got it resolved, but thought I should share another way batteries can go bad. How about a dead short ? My Wife's old Chevy Venture had it's battery die that way in a parking lot. I show up to jump it and my car stalls as soon as I connect up. Had me wondering. I got a new battery, slapped it in and all was well with the van. Sometimes there are deposits that build up in the bottom of the battery cells that cause this.
Aaron
(who only has battery problems when its -10 and someone else's car)
Wheelbuilder_25
Find More Posts by Wheelbuilder_25
