Reload this Page Tire rotation
#1: 10-17-2012, 02:07 PM
Tire rotation
 computersoc
Car: 2012 Subaru Legacy 2.5i Premium
Send a private message to computersoc Find all posts by computersoc Reply With Quote
Dealer charges $47 plus tax for tire rotation. This seems steep, isn't it? They say that regular chain shops (Goodyear, PepBoys, etc) can't do it because they can't reset the tire pressure code or something like that. Sounds like a line of bull. What are your thoughts?
computersoc
Find More Posts by computersoc
#2: 10-17-2012, 02:09 PM
 Slider
Slider's Avatar
Car: '10 LGT
Send a private message to Slider Find all posts by Slider Reply With Quote
Take it to Discount and have them do it. You don't need to use your dealer for tires or TPMS.
Slider
Find More Posts by Slider
#3: 10-17-2012, 02:11 PM
 computersoc
What is Discount?
What *should* a tire rotation cost?
computersoc
#4: 10-17-2012, 02:14 PM
 TheOneDoubleN
TheOneDoubleN's Avatar
Title: Crash Test Dummy
Car: '08 535xi Sport Wagon
Send a private message to TheOneDoubleN Find all posts by TheOneDoubleN Reply With Quote
Discount tire center is what he was referring to, but anywhere can do a tire rotation.
Rotating has nothing to do with tpms. Even changing tires entirely has nothing to do with TPMS. The only time you would need to worry about TPMS is if you were changing wheels, since the TPMS sensors are inside the valve stems in the wheels.
Dealer is feeding you bullshit, and $50 is way too much for a tire rotation. $20 or around there is more reasonable.
TheOneDoubleN
Find More Posts by TheOneDoubleN
#5: 10-17-2012, 02:17 PM
 acumenhokie
acumenhokie's Avatar
Car: 2010 LGT & 2009 FXT
Send a private message to acumenhokie Find all posts by acumenhokie Reply With Quote
I got my tires rotated two months ago at my mechanic/tuner. It was $17.99 labor and $6 parts (wheel weights).
acumenhokie
Find More Posts by acumenhokie
#6: 10-17-2012, 02:32 PM
 computersoc
Do the tires have to be re-balanced? Car has 16,000 miles on it. Bought it new in January. Last rotation was around 8000 that the dealer did for free.
computersoc
#7: 10-17-2012, 02:34 PM
 Drift Motion
Drift Motion's Avatar
Car: RMS13 --> 05 Turbo Camry
just jack up the car, swap the wheels...not that hard...
rebalancing is not necessary, but good to have
if you bought tires from Discount Tires/America's Tire, they'll rotate/rebalance the wheels for you for free
The Following 2 Users Say Thank You to Drift Motion For This Useful Post:
Ellesedil (10-19-2012), Rutchard (10-17-2012)
Drift Motion
#8: 10-17-2012, 03:40 PM
 minuccims
minuccims's Avatar
Send a private message to minuccims Find all posts by minuccims Reply With Quote
You can rotate tires with your spare tire, car's jack, and 2x4s for under some tires if you don't have all the stuff.
minuccims
Find More Posts by minuccims
#9: 10-17-2012, 04:01 PM
 TheOneDoubleN
Eh, some people aren't comfortable with removing and installing wheels, that's understandable.
Rebalancing is never necessary unless you're having some unusual vibration which would indicate that the wheel is out of balance.
TheOneDoubleN
#10: 10-18-2012, 06:33 AM
 10legacy
Car: 2010 2.5i premium 6spd.
Send a private message to 10legacy Find all posts by 10legacy Reply With Quote
most places around here charge $15 to $20 a tire rotation is pretty easy and shouldn't cost nearly as much as the dealer is charging. My dealer charges about $25 if you get an oil change which isn't too bad.
10legacy
Find More Posts by 10legacy
#11: 10-19-2012, 10:55 AM
 Fraugher
Send a private message to Fraugher Find all posts by Fraugher Reply With Quote
I have a Honda that has individual indentification for all 4 wheels, so a rotation requires flashing the TPMS. Obviously mine is not professional advice, but the Legacy does not care what position the TPMS monitors are in, otherwise your TPMS light would come on when you rotate... if it doesn't you are golden. And BTW, any decent shop has the hardware to flash your TPMS.
Fraugher
Find More Posts by Fraugher
#12: 10-19-2012, 11:07 AM
 TitoBandito
Send a private message to TitoBandito Find all posts by TitoBandito Reply With Quote
$20 is probably about average for a tire rotation. Your TPMS sensors do track which corner they sit on but will not throw a light after a rotate.
However if a code is thrown for a sensor error (i.e. sensor no seen by tpms module) and the sensors where no initialized after the rotate they will show as being in their old locations possible making the technician's life harder
That being said, $47 dollars is way too much for a rotate and you cannot tax labor, which is all a rotate is.
TitoBandito
Find More Posts by TitoBandito
#13: 10-19-2012, 02:38 PM
 computersoc
PepBoys said they'll do it for $9.99. Appointment for next week.
computersoc
#14: 10-20-2012, 02:29 PM
 abody
abody's Avatar
Car: 2011 legacy 2.5 prem, 70 cutlass
Send a private message to abody Find all posts by abody Reply With Quote
had a coupon for 9.99 at the subaru dealer, couldn't pass that up 2 weeks ago, they have subaru among several other makes there.always have coupons
abody
Find More Posts by abody
#15: 10-21-2012, 06:02 AM
 Almatti
Car: 2010 Subaru Legacy 2.5i Premium
Send a private message to Almatti Find all posts by Almatti Reply With Quote
computersoc: Mavis Discount Tire is one discount center. Try a combo deal - Oil/filter change with tire rotation. Many Subaru Dealers or Discount Chains will do it with special pricing. Just beware of the "you need to do this too" advise (brakes pads & rotors, other fluid changes [if they really are not due], wheels alignments [that's a popular PUSH on when you do rotations at certain mileage]. How many miles on your car?
Almatti
Find More Posts by Almatti
