Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page P0852 & P0037... frustration continues
#1: 08-14-2011, 03:50 PM
 moodraman
moodraman's Avatar
Car: 05 Pearl White LGT Wagon Lmt ~Stage 2
Send a private message to moodraman Find all posts by moodraman Reply With Quote
So... This is driving me NUTS!!! A while back I threw a P0037 and start getting HORRIBLE gas milage as well as my car ran like poop. my investigation looked like it was the rear02 sensor... so I ordered a used on off a member on the site... that solved my problem for about a month, until I threw another 0037 code...
I didn't have the time to deal with it so I just left it for a while...
Well recently I got my sh!t together and ordered an brand new rear 02 sensor figuring the used one was close to going bad. So today I did my brakes and went ahead and put on the new rear 02 sensor and reset the battery to clear any codes...
So I just fired it up... and now I have a new code... in addition to my same p0037.
P0852 - Neutral Switch Input Circuit High
P0037 - Rear O2 Sensor Heater Control Circuit Low
I couldn't find anywhere that the wiring looked bad... everything looked fine to me... this is driving me nuts... I want my car back!!!!
I have a stage 2ish car... Downpipe, uppipe VF52, upgraded Fuel Pump and Injectors, and a pro-tune.
Any ideas... I couldn't find much on the forums about the P0852 code.
moodraman
Find More Posts by moodraman
#2: 08-14-2011, 10:45 PM
 NSFW
NSFW's Avatar
Title: Stage Free
Car: 6mtblackturbowagon
Send a private message to NSFW Find all posts by NSFW Reply With Quote
I vaguely recall something about an issue with the neutral switch in 05s that had Subaru TSB for it, but I don't remember the details. Does that sound familiar to anyone?
Since the P0037 come back after replacing the sensor, I'm guessing your sensors are actually fine. Did you take a close look at all of the connectors between the sensor and the ECU? I know there's one that's a foot or two away from the sensor itself but I'm not sure if there are others.
Circuit Low" sounds to me like an open circuit. (There's also Circuit High, which I suspect means a short.) Can anyone confirm or dispute? If I'm right, disconnecting and reconnecting the connector a couple times might be all it takes to get some crud off of a dirty contact.
NSFW
Find More Posts by NSFW
#3: 08-14-2011, 10:46 PM
 NSFW
NSFW's Avatar
Title: Stage Free
BTW, another current thread about the 0852 code:
http://legacygt.com/forums/showthrea...es-168126.html
NSFW
#4: 08-17-2011, 10:52 AM
 moodraman
moodraman's Avatar
Thanks!
P0037 got cleared when I discovered it was unplugged closer to the engine!!
<<<<don't worry I made my wife smack me in the back of the head for this one>>>>
So I reset the ECU but about 15 min of driving and the 0852 came back.
moodraman
#5: 08-17-2011, 10:53 AM
 moodraman
moodraman's Avatar
uh... that's a link back to this same thread
moodraman
#6: 08-17-2011, 01:21 PM
 NSFW
NSFW's Avatar
Title: Stage Free
http://legacygt.com/forums/showthrea...-1-130464.html
D'oh!
NSFW
#7: 08-26-2011, 11:20 AM
 moodraman
moodraman's Avatar
anyone who've seen this? any home tuners out there ran into it?
moodraman
#8: 08-28-2011, 07:19 AM
 bmx045
Title: Banned
Car: 08 LGT, built motah
Find all posts by bmx045 Reply With Quote
I found it to be tune related for one reason or another, nothing mechanically was faulting, so I disabled that cel, all is well, cruise works fine...still....
bmx045
Find More Posts by bmx045
#9: 10-17-2011, 11:28 AM
 moodraman
moodraman's Avatar
still tossing this code... any new one's encountered this?
moodraman
#10: 10-15-2012, 07:38 PM
P0037
 wadi23
Send a private message to wadi23 Find all posts by wadi23 Reply With Quote
Originally Posted by moodraman View Post
Thanks!
HEY can you tell me where the connector that's closer to the engine is? the connector at the bottom of the car is fine
wadi23
Find More Posts by wadi23
