Reload this Page Top bolts on tower bar?
#1: 10-09-2012, 09:37 AM
 passionincar
passionincar's Avatar
Car: 2006 Spec-B
Send a private message to passionincar Find all posts by passionincar Reply With Quote
Hi,
I just got a front tower bar from R-REV Sports... it fits fine...
but i am afraid about the top bolts not going in all the way.
please see pics below... is this FINE?
Thanks
HAri
ID:	130968   Click image for larger version
ID:	130969   Click image for larger version
ID:	130971   Click image for larger version
passionincar
Find More Posts by passionincar
#2: 10-09-2012, 09:48 AM
 Windy Road
Windy Road's Avatar
Title: I brick ECU's
Car: Stage 2.95 Grandpa Cruiser with Navi
Send a private message to Windy Road Find all posts by Windy Road Reply With Quote
There should be more threads in those nuts. My guess would be something is blocking the top hat of the shock from seating all the way up in the tower.
Windy Road
Find More Posts by Windy Road
#3: 10-09-2012, 09:51 AM
 ShadowImg
ShadowImg's Avatar
Car: 09 OBP Spec.B, 01 SRP 2.5RS
Send a private message to ShadowImg Find all posts by ShadowImg Reply With Quote
I wouldn't consider that fine. Also those nuts should be replaced, they're lock nuts and look like they've seen better days.
ShadowImg
Find More Posts by ShadowImg
#4: 10-09-2012, 10:05 AM
 passionincar
Car: 2006 Spec-B
Actually there is a round metal piece welded below the bar bolt holes. i see it is to support the bolts.
the nuts and bolts looked fine... i didn't see any rust... just dirt and oxidation.
i tried fitting it... but didn't like the way it seated... so took it off... just debating on whether its really worth it.
passionincar
#5: 10-09-2012, 10:15 AM
 .blackgt.
.blackgt.'s Avatar
Car: hovercraft-SOLD camper-all sexed up
Send a private message to .blackgt. Find all posts by .blackgt. Reply With Quote
You can grind those tabs down, but it is a spec b.
Do you normally reuse parts that are dirty and oxidized?
Also, you might want to look up the meaning of oxidized and rust. They are one in the same my friend.
Carry on!
.blackgt.
Find More Posts by .blackgt.
#6: 10-09-2012, 10:32 AM
 passionincar
Car: 2006 Spec-B
sorry about the rust... i have seen worse on the bottom end... as i said it looks just dirty to me... anyway let me get some new nuts...
i am just going to return/sell it... looks like its not worth the price to put it on.
passionincar
#7: 10-09-2012, 10:41 AM
 ShadowImg
ShadowImg's Avatar
The nuts are actually supposed to be replaced every time they're removed. I normally just clean them and put a dab of loctite. If the threads look worn (which is what I was referring to), I replace them.
ShadowImg
#8: 10-09-2012, 11:15 AM
 passionincar
Car: 2006 Spec-B
yes the thread was looking fine.
i am going to see if i can remove the small metal support piece at the bottom.
passionincar
