Go Back   Subaru Legacy Forums > Technical Forums > Exterior/Aesthetic
Reload this Page HID Foglight Install
Page 1 of 4 1 23 > Last »
#1: 06-25-2009, 10:18 PM
 absolutsnwbrdr
absolutsnwbrdr's Avatar
Car: Outback 3.0R
Send a private message to absolutsnwbrdr Find all posts by absolutsnwbrdr Reply With Quote
There was a thread on here from 2007 that went into great great great detail about installing HID's into the foglights:
http://legacygt.com/forums/showpost....2&postcount=73
Its a great writeup that goes into incredible detail, but its a little too busy for me (and no pictures).
I think it can be explained in a more simple fashion.
So here's mine...
If you're trying HID's in the fogs, chances are you've already mastered the HID's in the headlights. Headlights were simple.... the only thing that was altered was that gray "dust cap." Well the fogs are similar, but they have a black "dust cap" that needs a little more modification. The headlights can easily be put back to stock halogen, whereas the fogs WILL NOT be able to return to stock.
What you will be modifying:
1. the black plastic fog light dust cap with plug
2. the short OEM fog light harness with white plug and gray plug
Those two things are all you would need to return to stock, so even if you did want to go back it would be as easy as getting new dust caps and short harnesses.
Lets begin..
I removed the front bumper to get to everything easier. This makes accessing the foglights and mounting ballasts much much easier.
Take that short wire harness that was connected to the black cap and hack the gray plug off.
Take the black plastic dust caps and cut the plug part off of it, leaving you with a nice opening. I used a drill, pliers, and the sidewalk (as sandpaper) to do this. I'm sure you have the proper tools, i.e. a dremel. Get the opening to be about the size of the back of the cap... see pics below.
Take the HID power wires out of the rubber grommet and cut the connectors off of it (as shown in the bottom right of the pic above)
Solder the hacked HID power wires to the short OEM harness that has the white plug (red to red, black to black)
Pull the HID wires and grommet through the hole in the black dust cap. Seal the grommet using silicone sealant or whatever. Also put some sealant in the holes in the grommet where the red and black power wires once were.
All this should yield you the following:
Pretty self explanatory from here...
H3 HID bulbs go in factory fog light housing,
put on black dust cap,
connect HID to ballast to factory plug,
mount ballasts,
put bumper back on,
enjoy!
note: plugs are all different, so they will only plug into exactly where they are supposed to go!! easy!!
oh and if you mess something up, its not my fault... mine work perfectly
This seems a lot more complicated than it actually is. Once you get the H3 HID kit and open the box, everything will make more sense.
ID:	135654   Click image for larger version
ID:	135655   Click image for larger version
Last edited by absolutsnwbrdr; 12-03-2012 at 06:04 PM.. Reason: re-insert pictures
The Following 4 Users Say Thank You to absolutsnwbrdr For This Useful Post:
BLACKeNeD (06-08-2012), Catalyst (02-22-2011), dustincredible (10-31-2012), PeterJMC (02-02-2011)
absolutsnwbrdr
Find More Posts by absolutsnwbrdr
#2: 06-25-2009, 10:21 PM
 absolutsnwbrdr
Car: Outback 3.0R
Everythings good to go!
Hope this walkthrough helps at least one person! If I wasnt clear enough about something, ask and I'll be happy to clarify!
absolutsnwbrdr
#3: 06-25-2009, 10:35 PM
 henryq89
henryq89's Avatar
Car: mi negrita ;)
Send a private message to henryq89 Find all posts by henryq89 Reply With Quote
thats cool
henryq89
Find More Posts by henryq89
#4: 06-26-2009, 10:43 AM
 Catalyst
Catalyst's Avatar
Title: The Zissou
Car: 2005 LGT 5MT - OS Stage 1
Send a private message to Catalyst Find all posts by Catalyst Reply With Quote
For functionality sake, would this actually be too bright for fogs?
Catalyst
Find More Posts by Catalyst
#5: 06-26-2009, 10:57 AM
 Darkness of Death
Darkness of Death's Avatar
Title: Black Magician
Car: 11 second B Spec
Send a private message to Darkness of Death Find all posts by Darkness of Death Reply With Quote
if you have HID's for low beams you dont really notice any difference on non HID fog lights. i'm sure this would help out on vision...though i am not for certain either as i dont have HID fogs on
Darkness of Death
Find More Posts by Darkness of Death
#6: 06-26-2009, 11:02 AM
 trackhore
trackhore's Avatar
Car: LGT
Send a private message to trackhore Find all posts by trackhore Reply With Quote
Yes. It completely defeats the purpose of a foglight and is a cosmetic upgrade done to satisfy the owner's personal tastes.
trackhore
Find More Posts by trackhore
#7: 06-26-2009, 11:31 AM
 absolutsnwbrdr
Car: Outback 3.0R
the light output from the fogs alone is tremendous, but a lot of the light is wasted
because fogs arent made to project 100' in front of you (they arent driving lights). if either of the 5000k fog hids go bad, i will be keeping them hid, but probably going with 3000k. i'm happy with it for now though! looks awesome at night!
absolutsnwbrdr
#8: 06-26-2009, 11:34 AM
 absolutsnwbrdr
Car: Outback 3.0R
after i finished them last night, i went for a short drive but only had my cell phone on me so i couldnt get good pictures. maybe i'll take my nice digital out tonight and get some good pics that show the output from fogs only, lows only, and fogs + lows.
absolutsnwbrdr
#9: 06-26-2009, 11:37 AM
 absolutsnwbrdr
Car: Outback 3.0R
btw... dont know if you've noticed, but our fogs arent that functional to begin with
absolutsnwbrdr
#10: 06-26-2009, 11:43 AM
 trackhore
trackhore's Avatar
Car: LGT
Meaning what?
trackhore
#11: 06-26-2009, 11:46 AM
 absolutsnwbrdr
Car: Outback 3.0R
as halogens they dont put out a whole lot of light on the road to begin with
absolutsnwbrdr
#12: 06-26-2009, 11:53 AM
 trackhore
trackhore's Avatar
Car: LGT
As fog lights, they aren't really designed to. Their intended purpose is project yellow colored light to the low and immediate road in front of the car in an effort to reduce the amount of light reflected back by the moisture in the air; which is what happens to driving, low, and high beams.
trackhore
#13: 06-26-2009, 08:09 PM
 Catalyst
Catalyst's Avatar
Title: The Zissou
I know I notice a difference when I have them on in shitty conditions for sure.
Buy yea, +1 for more pics
Catalyst
#14: 06-27-2009, 08:16 AM
 f1anatic
f1anatic's Avatar
Title: Das Cruise Meister
Car: Legacy GT spec C & Forester XP
Send a private message to f1anatic Find all posts by f1anatic Reply With Quote
Actually I have my fog lights adjusted "upwards" and even with my HIDs (55 Watt, 4200 K - which are the whitest) I can tell the fog lights. It gives me more peripheral vision and project maybe about 5-7 meters in front of the car. It is not just a subtle difference. I have the non-HID Narva 55 watt (H3 I believe) bulbs.
f1anatic
Visit f1anatic's homepage!
Find More Posts by f1anatic
#15: 06-27-2009, 09:13 AM
 diamondgraymetallic21
diamondgraymetallic21's Avatar
Title: Homebrew Vendor
Car: 07' Legacy GT
Send a private message to diamondgraymetallic21 Find all posts by diamondgraymetallic21 Reply With Quote
I love this picture, looks like you backed over a curb and your front bumper and grill fell off!
I know that isn't the point, but it made me laugh.
Find More Posts by diamondgraymetallic21
Similar Threads
Service Specials! AMAZING PRICES! OutbackAuto Pacific Northwest 463 Yesterday 04:41 PM
VOLT HID *Japanese* slim kit!!! 6000K XENON EXPERT xenon expert Group Buy Forum 80 12-02-2010 03:19 PM
KWD HID 07 Install Problems natoli4 Fourth Generation Legacy (2005 - 2009) 21 09-15-2008 08:31 PM
Foglight Film Install Nonvteclegacy Exterior/Aesthetic 3 04-19-2006 05:03 PM
