Go Back   Subaru Legacy Forums > Technical Forums > Suspension/Brakes
Reload this Page help needed: dust boot removal
#1: 02-19-2013, 09:49 PM
 washingtonOBXT
Car: 2005 Outback Xt limited
Send a private message to washingtonOBXT Find all posts by washingtonOBXT Reply With Quote
im changing out my struts and springs for king springs with 04 kybs in the rear, i got the spring and top hat off, but how do i get the dust boot off? a picture is attatched to illustrate what mine looks like. also, i did not see a rubber bushing that many struts have, is this because the bump stop is on the frame of the car?
washingtonOBXT
Find More Posts by washingtonOBXT
#2: 02-20-2013, 07:55 AM
 washingtonOBXT
im doing this this afternoon so i need to figure it out, any help would be much apreciated
washingtonOBXT
#3: 02-20-2013, 08:35 AM
 Rester5350
Rester5350's Avatar
Car: 06 OBXT 5EAT Stage 2
Send a private message to Rester5350 Find all posts by Rester5350 Reply With Quote
I used a thin flathead screwdriver to brake the grime loose and pulled it off. I also think that I started from the inside of the boot. Good luck.
Rester5350
Find More Posts by Rester5350
#4: 02-20-2013, 03:50 PM
 Dbl_D718
Dbl_D718's Avatar
Car: 2007 spec.B
Send a private message to Dbl_D718 Find all posts by Dbl_D718 Reply With Quote
It just pulls off, but it'll be stuck on there pretty good. I didn't need any tools to get them off though; just pulled/pushed until it came off...wasn't too hard.
MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII
Dbl_D718
Find More Posts by Dbl_D718
#5: 02-20-2013, 04:36 PM
 mwiener2
mwiener2's Avatar
Title: Trunk Monkey Chief
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
pull harder
My Mods List
(Updated 2/7/13)
2005 Outback FMT
Spec Yaris
The Following User Says Thank You to mwiener2 For This Useful Post:
Zero1 (02-24-2013)
mwiener2
Find More Posts by mwiener2
#6: 02-20-2013, 05:18 PM
 Underdog
Underdog's Avatar
Title: Wrench for Hire
Car: The Crimson Dynamo
Send a private message to Underdog Find all posts by Underdog Reply With Quote
If you really get stuck you can use channel locks to grab a third of the boot at a time and pinch it slightly to loosen the rust between the boot and the shaft.
10% Off DeatschWerks and Injector Dynamics!
Underdog
Find More Posts by Underdog
#7: 02-20-2013, 05:25 PM
 Rester5350
Rester5350's Avatar
If you play with it enough it will come!
Rester5350
#8: 02-24-2013, 04:18 PM
 Rester5350
Rester5350's Avatar
How did everything work out for you?
Rester5350
