I bought one at local scrpayard for the engine to use in mine. only thing ill be using from it is long block
ALL ITEMS SHIP FROM IRELAND - IM NOT A US-BASED MEMBER
Couple of things of interest:
TD04HLA twinscroll headers $120:
front and rear anti roll bars( standard jdm thickness, rear only pictured 21mm)
Syms earthing kit - $40
ABS + battery covers: painted gloss carbon affect by previous owner - SOLD
Pair of dual avcs heads, drivers side needs 4 valves, still fully assembled, passenger side, disassembled needs 4 valves, casings etc are 100%
drivers side - $450 for both
Passenger side:
12mm jdm oil pump, came off working engine, not failure one, might be useful to someone that can modify it etc - $50
power folding mirrors switch - $40
jdm coin holder in this picture also - $30
intake manifold - $100
tgv deletes - $150
RHD speedo cluster, reading 85000kms - $140
jdm ecu - $150
Aluminium rear lateral links - $90
Aluminium rear trailing arms: can supply with a necessary mounting brackets for easier installation - $350
Unfortunately im based in Ireland, so shipping will add a bit to costs, but if your after anything off a early model 4th gen jdm legacy. let me know and ill check if its good. It took a hit from the front and slid on its side.
Only pictures i have now
Ill get a few pics up when i get a chance and bits start coming off it. Anyone interested in anything let me know and ill let you know if its available etc.
