Reload this Page performance parts
#1: 01-24-2013, 05:16 AM
performance parts
 Bpalumbo159
Bpalumbo159's Avatar
Car: 2007 Subaru legacy 2.5i
Send a private message to Bpalumbo159 Find all posts by Bpalumbo159 Reply With Quote
Just wondering if anyone knew of a site besides ebay to find any performance parts for a 2007 legacy 2.5. And i know that people are gonna say well you should have got a gt , but i didnt so im workin with what i have. Any help would be nice. Thanks for all your help!
Bpalumbo159
Find More Posts by Bpalumbo159
#2: 01-24-2013, 05:19 AM
 Subieaction
Subieaction's Avatar
Car: 05 LGY GT LTD
Send a private message to Subieaction Find all posts by Subieaction Reply With Quote
ummmmmmmmmm................. the vendors
Subieaction
Find More Posts by Subieaction
#3: 01-24-2013, 05:19 AM
 bomberlegacy
bomberlegacy's Avatar
Title: pew pew
Car: 08 E85 Supercharged 2.5i
Send a private message to bomberlegacy Find all posts by bomberlegacy Reply With Quote
Any of the vendors on here, Google, search on here.
There isn't much you can do with a 2.5i unless you go turbo or supercharger. Or suspension upgrades.
Do you have E85 fuel in your area? If so, grab a used set of GT injectors from the classifieds and get a tune for e85. That's your best bet Imo.
Raptor SC 9psi | E85 & Deatschwerks | Rallisport UEL headers
Because racecar
Build Thread
bomberlegacy
Find More Posts by bomberlegacy
#4: 01-25-2013, 10:52 AM
 Bpalumbo159
bomber did ou super charge you car if so what did you have to change to make it work correctly. did you have to rebuild the motor to handle itor did you slap it on your stock car. i ve done crank pulley and p/s pulley which i noticed a difference in response. ive also puttein stechs on and front and rear strut tower bars.
Bpalumbo159
#5: 01-25-2013, 11:17 AM
 Max Capacity
Max Capacity's Avatar
on here...check out the vendor forum.
Max Capacity
#6: 01-25-2013, 12:40 PM
 bomberlegacy
Title: pew pew
Stock bottom end. It can handle 9-10psi fine.
Which ps pulley did you get?
Because racecar
Build Thread
bomberlegacy
#7: 01-25-2013, 08:54 PM
 Platinum_Racing
Platinum_Racing's Avatar
Car: 2005 LGT 5EAT
Send a private message to Platinum_Racing Find all posts by Platinum_Racing Reply With Quote
How does that 10:1 compression ratio fair with the supercharger? Is the E85 mandatory now? Just curious.
Platinum_Racing
Find More Posts by Platinum_Racing
#8: 01-25-2013, 08:58 PM
 bomberlegacy
Title: pew pew
Good so far but I don't have a bunch of miles on it yet. Others have had success. 10psi is about the max they recommend on the stock bottom end due to higher compression.
E85 not mandatory, but it'll help make some more power
Because racecar
Build Thread
bomberlegacy
#9: 01-26-2013, 07:32 AM
 frank_ster
frank_ster's Avatar
Title: MASTER OF THE BUCKARU
Car: 05 lgt 5EAT 3.8, buell 1125cr ,79 camaro
Send a private message to frank_ster Find all posts by frank_ster Reply With Quote
need driving around video of that car
Now that's thinking out of the boxer!
fyi all 05 legacy's have built in code reader
frank_ster
Find More Posts by frank_ster
