My first guess when I read this was the terminals. Next question, how old is the battery. If it older then 5 years, it's on it's last legs. Some have gone as far as 8 years, but I replaced mine at 5 to be safe.
You have in effect reset the ECU a few times now. It is re-learning. The idle should become normal in a short time.
