Reload this Page Winter Wheels - Help me decide
View Poll Results: Stock OR CSA Mullins this winter??
Stockers yo! 12 85.71%
CSA Mullins guy! 2 14.29%
I dunno man 0 0%
Voters: 14. You may not vote on this poll
#1: 09-11-2012, 08:43 PM
 EssTeeAai
EssTeeAai's Avatar
Car: '05 LGT sedan & '06 2.5i wagon
Send a private message to EssTeeAai Find all posts by EssTeeAai Reply With Quote
Alright, so long story short; I own a 2.5i wagon now. So my LGT sedan will be stored for the winter. The wagon is a Special Edition, so it came with 17's.
I'm trying to decide which wheels I'm gonna be using on the wagon this winter.
1. Stock (GT/Special Edition) 17's that are on it now (17x7???)
OR
2. My CSA Mullins 17's that I used to use on my sedan (17x7)
STOCK VS. CSA
- One stock wheel is easier to replace than an aftermarket wheel if anything happens or if it gets damaged +1
- Mullins wheels are "bare" right now, so I won't have to dismount tires prior to mounting winters +1
- I weighed the CSA wheel at 22.2lbs. Research shows that stock Legacy 17's weight 20.5lbs. Correct me if I'm wrong, but heavier wheels are better for winter applications. +1
What do you guys think?
PS. Pretend that cost is not an issue, which winter tires would you get that are good in the snow, but don't suck on dry pavement? (Car is mostly driven in the city, with weekly (ski) trips up north).
Cheers! :wave:
EssTeeAai
Find More Posts by EssTeeAai
#2: 09-11-2012, 08:45 PM
 EssTeeAai
EssTeeAai's Avatar
Also, can anyone do a quick Photshop of the CSA wheels on the wagon?
EssTeeAai
#3: 09-11-2012, 08:58 PM
 InnocentGuns
InnocentGuns's Avatar
Car: 05 L/GT,99 tib, 99 gmc, 06 M109r,
Send a private message to InnocentGuns Find all posts by InnocentGuns Reply With Quote
Heavier wheels are never better. -1
personally i like nokian's for purely winter tires. with blizzaks in a trailing 2nd.
thinner width (1st number) is better for snow.
InnocentGuns
Find More Posts by InnocentGuns
#4: 09-11-2012, 09:10 PM
 Karumba
Karumba's Avatar
Title: 514
Car: 08 2.5i Wagon LTD
Send a private message to Karumba Find all posts by Karumba Reply With Quote
Are your OEM wheels your summer wheels as well or do you have something else for the summer?
If so.. I might suggest option 3. Sell your CSA rims, pick up a set of 16" steelies to put winter rubber on. (unless you've upgraded brakes and cannot clear with them.. but doesn't look the part)
or if oems are your summer wheels as well, I'd lean and say keep them as is and put winter tires on the other set. Cheaper in the long run with two full sets (especially if you can jack and change your own tires) - my oems are summers, my winter (Nokian Hakka 5) are on steelies (16")
Karumba
Find More Posts by Karumba
#5: 09-11-2012, 09:12 PM
 InnocentGuns
^ +1
InnocentGuns
#6: 09-11-2012, 11:03 PM
 Drift Motion
Drift Motion's Avatar
Car: RMS13 --> 05 Turbo Camry
Send a private message to Drift Motion Find all posts by Drift Motion Reply With Quote
the two wheels looks essentially the same...LOL
The Following User Says Thank You to Drift Motion For This Useful Post:
BarManBean (09-12-2012)
Drift Motion
Find More Posts by Drift Motion
#7: 09-12-2012, 06:52 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
My winter wheels look just like my summer wheels because I have two sets of OEM wheels for both cars.
I loved the Michelin Pilot Alpins PA2's I think they were back in the day, but hated the price. They felt as good as my summer only's.
I got Blazzacks LM25's in July for $114 off tirerack.com This will be their 3rd winter coming up.
I get snows in the stock size. I don't go one size down.
Max Capacity
#8: 09-12-2012, 08:11 AM
 EssTeeAai
EssTeeAai's Avatar
What's the stock size for the GT wheels? 215/45/17 ? That's what I have on right now.
But... That sticker on the inside of the door says 205/50/17
Plus, I think that 17x7 wheels are wide enough to run 225/45/17. But a lot of people preach against wider tires for the winter.
EssTeeAai
#9: 09-12-2012, 10:49 AM
 Karumba
Karumba's Avatar
Title: 514
Correct in all accounts,
GT rolled out with 215/45/17
2.5i rolled out with 205/50/17
and you need not run a wider winter tire for better traction. In this case, less is more.
Karumba
#10: 09-12-2012, 11:01 AM
 Max Capacity
Title: Gearhead
I figured I drive more on dry roads in the winter then on snow covered roads, that's why I don't down size the tires.
It's a trade off, but that's my choice. In my feeble little mind, it's worth it.
Max Capacity
#11: 09-12-2012, 11:34 AM
 Drift Motion
Drift Motion
#12: 09-12-2012, 02:30 PM
 Karumba
Karumba's Avatar
Title: 514
Thinking you broke some of the encoding for the .gif Drift Motion ... maybe it is just me, but doesn't cycle through and barely stays at the beginning with the photoshop.
Karumba
#13: 09-12-2012, 02:33 PM
 Drift Motion
I think i forgot to put it on repeat...lol
Drift Motion
#14: 09-12-2012, 09:32 PM
 EssTeeAai
EssTeeAai's Avatar
Awesome! Thanks Drift Motion
EssTeeAai
#15: 09-12-2012, 09:38 PM
 EssTeeAai
EssTeeAai's Avatar
Originally Posted by Karumba View Post
...and you need not run a wider winter tire for better traction. In this case, less is more.
I agree with this, but I don't quite understand the physics behind it. Someone care to elaborate how skinny tires are better in the snow?
From first-hand experience; I once ran 235 wide tires in the winter. The car felt "shifty" in deep snow, since the tires no longer "cut" through the snow nor fit in the grooves already made by other vehicles. So it wasn't stable at highway speeds, it was kind of wobbly (which is no big deal for most people who know how to drive, but I can see how this would scare the average commuter).
However, as far as traction goes; doesn't more surface area tire contact with the road = more traction?
EssTeeAai
