Go Back   Subaru Legacy Forums > Technical Forums > Tuning
Reload this Page Acessport
#1: 02-15-2013, 05:44 PM
Acessport
 slvr08lgt
Send a private message to slvr08lgt Find all posts by slvr08lgt Reply With Quote
Hey fellow tuners..the other day when I flashed the stage 2 tune I noticed there was a map called low wastage and did a little reading on cobbs website about it. I couldn't real understand exactly what it is or does. The way it was explained was if your at a low rpm and go wot and sometimes it causes you to over boost and this fixes that problem. If any of you experienced tuners could help out and explain it a little better and if that low waste gate map is sill a stage 2 93 oct map, it is listed under the stage 2 maps...thanks in advance
slvr08lgt
Find More Posts by slvr08lgt
#2: 02-16-2013, 11:48 AM
 slvr08lgt
Bump..No one knows anything about this
slvr08lgt
#3: 02-16-2013, 05:48 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
Read this to understand what wastegate is first and you'll have a much better understanding of why you may need a low or high wastegate map.... Although Cobb really should call it a low WGDC or high WGDC map to be perfectly correct, since the map they label as "low wastegate" actually uses more of the WG.
WGDC = WasteGate Duty Cycle. The more WGDC there is, the more closed your wastegate door is, and thus the less your wastegate is being utilized.
If someone says, "you need to wastegate more" that means you need less WGDC, and vice versa.
http://www.cobbtuning.com/Technical-...es-s/70674.htm
After you read that, what I said above will make sense.
iNVAR
Find More Posts by iNVAR
#4: 02-16-2013, 07:02 PM
 slvr08lgt
Ok so a lot of it made sense..I take it as if you are over boosting slightly everyonce in a while you should use the low wastegate map? Is that correct/ that's the way I'm taking t from reading that article
slvr08lgt
#5: 02-16-2013, 07:29 PM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Yes, that's correct. If you're having a problem with overboosting, less WGDC is what you need, which the Cobb "low wastegate" map (named incorrectly IMHO) should help with.
I've also posted in your other thread too with some input. You should post a log up of your overboost condition. Also, has the weather been significantly cooler lately? That will usually cause a larger boost spike than normal and if a map isn't adjusted well for that, you'll hit the boost cutoff.
iNVAR
#6: 02-17-2013, 05:35 AM
 slvr08lgt
I haven't had a chance to log yet. I over boosted 3 times but only to 18 psi and I was at a lot rpm and floored it when it happened. Other ten those times everything seems to be good
slvr08lgt
#7: 02-17-2013, 05:36 AM
 slvr08lgt
If you use that low wgdc map is it still about the same power and torque output as the stg 2 93 oct map or 91
slvr08lgt
#8: 02-17-2013, 05:39 AM
 Indiglow
Title: Banned
Find all posts by Indiglow Reply With Quote
if you're not throwing a cel for wastegate performance then don't worry about it.
Indiglow
Find More Posts by Indiglow
#9: 02-17-2013, 08:33 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
^-- What he said. You're not "overboosting" per se. You're spiking, which is perfectly normal. If you're throwing the CEL and hit fuel cut (you'll know it, your car will feel like Godzilla put his foot down on it), then you should look into it more.
iNVAR
#10: 02-17-2013, 12:12 PM
 slvr08lgt
Sounds good..thank you everyone for clearing that up
slvr08lgt
