Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page need help its urgent and my cars jacked
Closed Thread
Page 1 of 19 1 2311 > Last »
#1: 10-06-2012, 10:54 PM
 UTwrestler22
UTwrestler22's Avatar
Car: Stage 2 05 OBP LGT sedan
Send a private message to UTwrestler22 Find all posts by UTwrestler22
Alright i know that everyone gets anal about using the search but one i dont know what to search, two its urgent, three i need straight answers, four theres a couple things.
1st, i just got done with installing a new clutch and my car runs like shit. It wont hold rpms and revs by itself. And when i get to a certain rpm's it just cuts off and loses power big time. Now im stage 2 and ran my car without tje intercooler on to test the clutch. Also, it smokes bad. Did my tube get messed up? Do i have a leak?
2nd, when i took my car off the jacks after a week, i tried to open the back door from the outside but it just made a breaking noise and opened halfway and now wont open from the outside but will from the inside.
UTwrestler22
Find More Posts by UTwrestler22
#2: 10-06-2012, 11:45 PM
 MiniStiGuy
MiniStiGuy's Avatar
Title: Master of the Karts
Car: 2005 ABP Ltd SDN, 2005 SWP Ltd WGN
Send a private message to MiniStiGuy Find all posts by MiniStiGuy
Well if you are running your car without an intercooler you have a huge boost leak which is probably throwing off a whole slew of sensors on the car which is why it runs like crap.
Your back door not opening from the outside but from the inside sounds like you somehow disconnected the cable for the handle which was probably the noise you heard. Take the door panel off and have a look to see if the cables are still connected.
OEM HID's Rx330 Retro FTW!!!
Jimi Hendrix Medley
MiniStiGuy
Find More Posts by MiniStiGuy
#3: 10-07-2012, 12:19 AM
 UTwrestler22
Well right but now im running it w/ the intercooler on and its doing it and it felt like something broke
UTwrestler22
#4: 10-07-2012, 06:53 PM
 MiniStiGuy
MiniStiGuy's Avatar
1. Make sure you have no boost leaks.
2. Make sure the MAF is clean.
3. Reset the ECU by disconnecting the negative battery terminal and press the brakes a few times to ensure there is no power left in the lines. Wait like 15 seconds then reconnect the battery.
4. Start the car and let it idle to warm up.
5. Drive the car around for 5-10 miles normally.
If you have a laptop you can buy a vagcom cable and install romraider and get some logs for us. Or if you have an Access Port you can do some logging and attach the logs up to the site for us to review for you.
Jimi Hendrix Medley
MiniStiGuy
#5: 10-07-2012, 06:59 PM
 UTwrestler22
Will the logs show a leak?
UTwrestler22
#6: 10-07-2012, 07:01 PM
 MiniStiGuy
MiniStiGuy's Avatar
Yes an experienced tuner will be able to tell.
Jimi Hendrix Medley
MiniStiGuy
#7: 10-07-2012, 07:42 PM
 UTwrestler22
Ok. Will a performance shop have a vag com?
UTwrestler22
#8: 10-07-2012, 08:47 PM
 Harbs
Car: MY05 Liberty GT 2.0T
Send a private message to Harbs Find all posts by Harbs
Kinda sounds like you forgot to plug in the MAF sensor.
Harbs
Find More Posts by Harbs
#9: 10-07-2012, 10:18 PM
 UTwrestler22
Nope maf is in. I think its a boost leak
UTwrestler22
#10: 10-07-2012, 11:57 PM
 NSFW
NSFW's Avatar
Title: Stage Free
Car: 6mtblackturbowagon
Send a private message to NSFW Find all posts by NSFW
Also double-check your grounds, if you un-did any.
My guess is vac/boost leak, though.
NSFW
Find More Posts by NSFW
#11: 10-08-2012, 12:01 AM
 UTwrestler22
Grounds do that shit?!
UTwrestler22
#12: 10-08-2012, 05:32 AM
 MiniStiGuy
MiniStiGuy's Avatar
Grounds could cause all kinds of issues including what you describe. If you didn't undo any of them though then they should all be on still.
Jimi Hendrix Medley
MiniStiGuy
#13: 10-08-2012, 06:01 AM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
Car: 2009 SWP Grandma XT-B (5MT)
Send a private message to BAC5.2 Find all posts by BAC5.2
Why would you run the car without the intercooler?
You should probably take your car to a shop from now on...
The Following User Says Thank You to BAC5.2 For This Useful Post:
ripemeat (10-11-2012)
BAC5.2
Find More Posts by BAC5.2
#14: 10-08-2012, 07:15 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR
Seriously OP, why the hell would you do that? It takes 5 minutes to put the intercooler back on.... Here are a few reasons why it's an extremely bad idea:
1) Something can get sucked into your turbo and trash it
2) Something can get sucked into your intake and trash your engine
3) Your MAF sensor is sitting there with no airflow while your intake is wide open and your engine is sucking in air. Your ECU has no idea WTF to do. I seriously don't even know how it would react to this.
And that's just at idle. You said you wanted to test the clutch, I can't even imagine what the ECU would do with an essentially 0 airflow reading while you actually apply throttle.
Reset your ECU and see what happens.
iNVAR
Find More Posts by iNVAR
#15: 10-08-2012, 07:25 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner
There is a ground on the top of the trans housing people usually forget to disconnect and end up breaking it off when the trans is removed.
The Following User Says Thank You to GTTuner For This Useful Post:
MiniStiGuy (10-08-2012)
GTTuner
Find More Posts by GTTuner
Closed Thread
