05-14-2012, 01:01 PM
HVAC Fart/Whine under heavy boost
Car: 2010 LGT & 2009 FXT
I know the HVAC turns off the compressor or whatever under heavy boost so it doesn't sap power. Today my HVAC (like front defrost area) started making a tight sounding fart noise when this happens. Going to take it to the dealer tomorrow and see what they say but figured I'd ask the experts here first. I went ahead and made a quick vid so you can hear it.
http://youtu.be/sU8W0hw7CPQ
05-14-2012, 01:11 PM
Car: '12 LGT 289whp/348wtq, '12 OB CVT
Sounds like that one coupling on the throttle body or intercooler that's known to blow off at higher boost levels. It's easy to remove. No need to go to the dealer.
05-14-2012, 01:15 PM
05-14-2012, 01:20 PM
Didn't realize that's what it sounded like. Thanks, will check it out.
05-14-2012, 02:51 PM
Just pulled the IC and confirmed the coupling. Removed it from both ends.
05-14-2012, 03:26 PM
Car is back together. Time to pick up my daughter from daycare. We will soon see if i got everything back on tight.
05-14-2012, 05:20 PM
Ahhh, much better.
05-14-2012, 05:32 PM
Good to hear. I've been waiting for mine to blow off
05-14-2012, 06:08 PM
Car: 10 LGT Stage1; 94 Pontiac Firehawk #251
I took mine off a couple weeks ago when I had the IC off. Definitely a weak link. Takes < 10 minutes to remove.
05-15-2012, 02:40 PM
Title: The Vinyl Supplier
Car: Stage 3 06 spec.B #132
My brother is having this issue with his 2012 LGT, we are going to fix it tonight. Did you guys just remove that piece inside the TB hose?
05-15-2012, 02:55 PM
Title: Whut, who me?
Car: It runs 12's
Yes, rip that silly rubber piece off the end, clamp it down good.
The Following User Says Thank You to GTTuner For This Useful Post:
05-15-2012, 05:20 PM
Will do, thank ya sir!
05-15-2012, 06:04 PM
Yup pulled it from both ends of the piping.
05-17-2012, 09:04 AM
Car: 07 OB XT
Does this also reference to the 05-09?
My car sounds similar to that video. Yet I lose no power. I only hear it in boost.
06-29-2012, 02:22 AM
Car: 2010 SWP LGT
Just did this today, minus a couple of chunks from my fingers. Took me a bit of time trying to put it back together, probably a good thing to take a picture or remember how the hose goes back on.
