Reload this Page Polyurethane sway bar bushings?
Page 1 of 6 1 23 > Last »
#1: 03-13-2012, 07:14 PM
 sschmelcke
sschmelcke's Avatar
Car: 2010 Legacy 3.6r limited
Send a private message to sschmelcke Find all posts by sschmelcke Reply With Quote
Since the 3.6 is probably never going to get a good front sway bar replacement does anyone know a good place to buy some poly bushings? Im guessing it's 24mm bar but that's another wild guess.
sschmelcke
Find More Posts by sschmelcke
#2: 03-13-2012, 07:23 PM
 sschmelcke
sschmelcke's Avatar
It seems as though energy suspension has some nice options. Anyone have experience with them?
sschmelcke
#3: 03-14-2012, 06:40 AM
 acumenhokie
acumenhokie's Avatar
Car: 2010 LGT & 2009 FXT
Send a private message to acumenhokie Find all posts by acumenhokie Reply With Quote
The 3.6r runs a different sway bar setup then the GT?
Might want to contact Turn in Concepts or Whiteline and see if they can recommend some that fit (one of those "parts from other cars that fit the 5th gen" thing).
http://turninconcepts.com/
http://www.whiteline.com.au/
acumenhokie
Find More Posts by acumenhokie
#4: 03-14-2012, 07:07 AM
 sschmelcke
sschmelcke's Avatar
Everyone and their mother keeps telling me its different. Whiteline told me they could not source a 3.6 to test fit a bar and Myles from RCE says its completely different. I emailed energysuspension to ask them since I cant seem to get a solid answer on the exact diameter of the bar. It may come down to taking it off and measuring it. Basically with a 25mm rear sway and sway bar braces I really need to tighten up the front end a bit.
sschmelcke
#5: 03-14-2012, 10:06 AM
 nadracer
nadracer's Avatar
Car: 2010 Legacy Limited 3.6R w/knucklehead
Send a private message to nadracer Find all posts by nadracer Reply With Quote
I've ordered a few different sizes of sway bar bushings and I find the biggest issue is getting a set that either will
1. Work in the stock brackets
2. Work with the supplied brackets.
Most of the time these things don't fit no matter which version of the size you choose.
nadracer
Find More Posts by nadracer
#6: 03-14-2012, 12:57 PM
 dew2far
dew2far's Avatar
Car: '11 Legacy 3.6R
Send a private message to dew2far Find all posts by dew2far Reply With Quote
I concur. I've tried Energy Suspension bushings in the front and because the bottom of the bushing is not contoured the way the frame is, it eventually slips in the bracket. I upgraded to AVO bushings in the rear since they are identical to OE except in a harder durometer material. No problems there and it makes a nice improvement. As far as I can tell AVO doesn't make a fitment for the front diameter though.
dew2far
Find More Posts by dew2far
#7: 03-14-2012, 01:24 PM
 nadracer
nadracer's Avatar
I think we need professional help
nadracer
#8: 03-14-2012, 01:38 PM
 sschmelcke
sschmelcke's Avatar
You actually tried the bushings in the front on the 3.6 or another car?
sschmelcke
#9: 03-14-2012, 01:56 PM
 sschmelcke
sschmelcke's Avatar
I'm thinking now that Whiteline sells front bar bushings that match oem specs. It's for 22mm front bar
sschmelcke
#10: 03-14-2012, 07:16 PM
 dew2far
dew2far's Avatar
Front on my 3.6. Stock FSB. I did it with both factory and aftermarket brackets. The issue is with the shape of the frame. It is angled and the aftermarket bushings don't seat real well. Whiteline does make bushings in the right diameter so that's my next step.
dew2far
#11: 03-14-2012, 07:39 PM
 minuccims
minuccims's Avatar
Car: 2010 LGT Stage II, 2007 Outback 2.5i
Send a private message to minuccims Find all posts by minuccims Reply With Quote
top one is for the 3.6R, bottom is 2.5. Same bushings, same endlinks
minuccims
Find More Posts by minuccims
#12: 03-15-2012, 04:33 AM
 sschmelcke
sschmelcke's Avatar
i was thinking of doing the same exact thing. what size did you get for bushings?
sschmelcke
#13: 03-15-2012, 04:34 AM
 sschmelcke
sschmelcke's Avatar
Awesome thanks. Now If I can just find out the size. Do you have the parts manual? I have the full service manual. Ive been looking for the parts manual.
sschmelcke
#14: 03-15-2012, 06:43 AM
 acumenhokie
do you have the parts manual? I have the full service manual. Ive been looking for the parts manual.
this ^^^^
acumenhokie
#15: 03-15-2012, 07:10 AM
 sschmelcke
sschmelcke's Avatar
im willing to dropbox share the service manual if anyone is interested
sschmelcke
