I was installing my Leptronix aux-in and while removing the head unit, I ended up scratching bits of it on the shifter
The scratch on the plastic window isn't deep at all.. you can barely feel it when you run your finger over it.
The scratch on the grey trim however is much deeper!
Can I use 2000grit sand paper? Get it a wet and lightly smooth them out and follow up with some plastic polish?!
I tried using Mother scratch remover and that didn't do anything.. maybe some harder rubbing compound?
