Reload this Page Seal inside valve cover
#1: 01-10-2013, 08:25 PM
 relative4
relative4's Avatar
Send a private message to relative4 Find all posts by relative4 Reply With Quote
I just replaced the valve cover gasket (and spark plug well seals) on my '05 Legacy GT. The job went well, and as I was cleaning up my mess while idling the car, I found a little circular seal, about 30mm in diameter, on the floor by where I cleaned up the valve cover. I'm afraid this is the seal for the variable valve timing return line. The car idled fine for 20 minutes, but I never revved it. I'm afraid that if I rev up the engine and the valve timing control solenoid opens up, the oil will fill up the camshaft/valve space and I'll have serious problems. Is anyone familiar with this seal? I can't find it anywhere in the manuals. The inside diameter is 28mm, and the outside diameter is 35mm.
Help! Thanks!
relative4
Find More Posts by relative4
#2: 01-10-2013, 11:19 PM
 MAP
MAP's Avatar
Car: 05 Legacy GT, 5EAT
Send a private message to MAP Find all posts by MAP Reply With Quote
You say seal, is that a metal washer?
Did you change the oil or change spark plugs at the same time?
That looks like it may be the diameter of the oil drain plug... is it the crush washer?
The oil control solenoid doesnt need to be removed to change the valve cover and doesnt use a metal washer, it has a rubber o-ring.
MAP
Find More Posts by MAP
#3: 01-11-2013, 03:26 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
My first guess is a spark plug crush washer.
Can you get a picture of the side of it, does it look like it has two layers ?
Also aren't the crush washers for banjo type bolts copper ?
I'm also bad with mm to inches. Is 28mm just over a 1/2" ?
If it's bigger then that, I'd guess oil drain plug washer like MAP said.
Thinking about it, isn't 2.5cm = 1 inch ? The oil drain plug is 20mm so something with a ID of 28mm is going to fit on it.
Max Capacity
#4: 01-16-2013, 03:56 PM
 relative4
relative4's Avatar
Um, yeah, it was the seal from a little oil can. Forgot I filled that in the same place I cleaned the valve cover. Sorry.
On a different note, the valve cover job didn't go as well as I thought. Leaking badly up front. Dammit. Doing the clutch in a few weeks, see if I can do a better job with the exhaust removed.
I suck.
relative4
