Reload this Page Excessive oil consumption??
#1: 01-23-2012, 09:13 PM
 SUBILGTFTW20052124
Car: 2013 Legacy 2.5i
Send a private message to SUBILGTFTW20052124 Find all posts by SUBILGTFTW20052124 Reply With Quote
My baby LGT has 70,000 miles and has been consuming about a quart of oil every tank of gas. Not sure what is going on....the dealership said it was my piston rings and they needed replaced, but I have also heard that it is my turbo that is the problem...? Can anyone help me solve this crisis? I am spending way too much money on oil and I am using 10-40 because I consume so much..
SUBILGTFTW20052124
Find More Posts by SUBILGTFTW20052124
#2: 01-23-2012, 11:04 PM
 goneskiian
goneskiian's Avatar
Title: On my bike...
Car: '05 GT Ltd. Wagon in Silver
Send a private message to goneskiian Find all posts by goneskiian Reply With Quote
You need to do some investigating as it could be either of those you mentioned or something else entirely.
Have you had a leak down test? Have you pulled the intercooler to see if it's got oil in it?
There are a number of threads on oil consumption here. You could read those for more ideas.
Cheers!
goneskiian
Find More Posts by goneskiian
#3: 01-23-2012, 11:13 PM
 snowdrift86
Car: 05 RGB LGT Limited
Send a private message to snowdrift86 Find all posts by snowdrift86 Reply With Quote
Sounds like either your turbo or ring land failure. Until you do a leak down test or pull the the downpipe/intake you won't know
snowdrift86
Find More Posts by snowdrift86
#4: 01-24-2012, 09:15 AM
 SUBILGTFTW20052124
Yes, I have pulled my inter cooler and there is a bit of oil in it. Not a huge amount though...where are the other oil threads I can look at?
SUBILGTFTW20052124
#5: 01-24-2012, 12:27 PM
 Max Capacity
Max Capacity's Avatar
Just hang out here for few day's they will pop up.
I'm using a qt every 700 - 1000 miles or more, the car runs great, I just keep checking and top it off as needed.
Max Capacity
#6: 06-30-2012, 11:45 PM
 SPeC.B_MaZTer
Car: 2k8 Spec.B StageII
Send a private message to SPeC.B_MaZTer Find all posts by SPeC.B_MaZTer Reply With Quote
I seem to be having a very similar issue. Did you perform a leakdown test? What was causing your oil consumption>?
SPeC.B_MaZTer
Find More Posts by SPeC.B_MaZTer
#7: 07-01-2012, 06:55 AM
 Max Capacity
I did not. I figured why spend the money, I knew the tmic was dry so it was internal engine. So I just bought a new EJ257 short block and had my heads rebuilt.
Max Capacity
