Dan O Posted June 16, 2012 Share Posted June 16, 2012 I changed pads, lines and fluid a couple of years ago. I have flushed fluid several times since also. My problem is a complete spongy feel when I first apply the brakes, but goes away with a quick release and second pump of the pedal. I am getting sick of braking this thing like a NASCAR driver at Watkins Glen. I want it to be firm on the first press not after a couple of pumps. I've bled this thing so many times by foot and now with a power bleeder, I know there is no air in the lines. Could my master cylinder be damaged? Any help would be appreciated. Link to comment Share on other sites More sharing options...
angeltalin Posted June 16, 2012 Share Posted June 16, 2012 Welcome to driving a legacy.... Put in an STI master cylinder is what a couple guys have done paired with ss lines and good pads you can't go wrong I'm doing this very soon StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
Windy Road Posted June 16, 2012 Share Posted June 16, 2012 Deff put the Sti booster and cylinder in the car. My pedal is rock hard, I still have the 2-3mm dead spot up top but that's cause how they made it from the factory 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 +1 for sti bb/mc. It is possible your bb could be worn, but unlikely. Probably just lgt brakes as usual. Link to comment Share on other sites More sharing options...
