Reload this Page Sourcing a caliper for an "early" '05
#1: 05-11-2011, 09:09 AM
 EZSnow
Car: 05 LGT Wagon 5EAT
Send a private message to EZSnow Find all posts by EZSnow Reply With Quote
My wife has an 05 LGT Wagon. Left front caliper piston is stuck. I was hoping it was just the slide pins, but no dice- it needs a new caliper. Stealer wants $315 for one and can't get it for a week, napa charged me $125 for the wrong one (part # 22 01323L) which I got home to find that the bracket was too small for my rotor, and the caliper was too small to fit in my (bigger, stock) bracket. Sweet.
When I was on with the dealer, after taking my VIN, he told me that my LGT was an "early" build '05, and that it required a different caliper than the late-05 and following cars, and that my caliper was used from 03-05.
My local napa says he THINKS the #22 10325L should fit, but the closest one is in dallas. (I'm in minneapolis) I get to pay the UPS charges to find out if it matches my car.
what gives?!? are these cars THAT hard to find calipers for??
EZSnow
Find More Posts by EZSnow
#2: 05-11-2011, 09:16 AM
 sleeper8406
sleeper8406's Avatar
Title: Contributing V.P.
Car: 08 Toyota Tacoma
Send a private message to sleeper8406 Find all posts by sleeper8406 Reply With Quote
Contact MSprank here on the forum. I had this issue with mine not too long ago. He will help you out.
sleeper8406
Find More Posts by sleeper8406
#3: 05-11-2011, 09:26 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
Any auto parts store should be able to get one. Some WXR pieces may fit. I know the rear brake pads are the same a 99 2.5RS.
Max Capacity
#4: 05-11-2011, 09:39 AM
 EZSnow
ANY auto parts store? Like O'Reilly? Carquest? Napa? Wish I'd thought of that!
...oh wait. I did.
I know I'm a noob here, but I'm not an idiot.
I'll try MSprank- thanks, sleeper!
EZSnow
#5: 05-11-2011, 09:53 AM
 Max Capacity
Title: Gearhead
May be a google search will help. Some there for $56.00 & $75.00
http://www.google.com/search?hl=en&s...&aqi=&aql=&oq=
Boy, that was hard
Some guy's talk about Rock Auto as a good place too.
Max Capacity
#6: 05-11-2011, 10:24 AM
 EZSnow
again, I'm a noob, you have a high post count, so I don't meant to be contentious, but..
Seriously? "brake caliper 2005 subaru"? did you even read my original post?
"early 2005 legacy gt stuck brake caliper"? I googled that.
EZSnow
#7: 05-11-2011, 04:03 PM
 Osei
Osei's Avatar
Car: 04 Legacy NA (rip), 07 2.5i, 96 Outback
Send a private message to Osei Find all posts by Osei Reply With Quote
Msprank shall help.
In the meantime, the 04GT had an 11.4 rotor, the 05 was 12.3. Measure yours and you'll know which model you have.
Search is your friend. Not only google, but on this forum as well.
to start www.cars101.com
O.
Osei
Find More Posts by Osei
#8: 05-11-2011, 04:29 PM
 Max Capacity
Title: Gearhead
I bought my 2005 GT wagon in late Jun 2004. The car has 11.8" rotors on the front, if I remember right. I have not had to find a caliper yet. But I can't believe they are that hard to come by.
Most of us buy a rebuilt caliper when we have issues with them. If you want just the piston and the seal, they may be a bit harder to come by.
Your post says your looking for a caliper. I must have missed something. Sorry.
When I do a search on NAPA's site for a 2005 Subaru Legacy GT Wagon for the left front caliper I get a p/n CAL SE3900A Caliper w/hardware- left front, remfd
or CAL SE3900 same thing less the bracket.
Napa's site is a pita to use and find a price on.
Finally, napa at my lcoal store wants 175.29 including the 55.00 core for the CAL SE 3900A. They want 5.00 less for the other one.
A diferent store 12 miles away wants a 1.29 less for the same part.
Just found one on Auto Zone's site p/n C6041 same basic price.
Oh I see the 12.3 is the correct size. I now remember that.
When I bought slotter front rotors for my 05 I didn't have any problem with size.
I really can't believe it's that hard to find these.
Max Capacity
#9: 05-11-2011, 05:21 PM
 EZSnow
According to M Sprank via PM:
Originally Posted by M Sprank
You are very unlucky. you have one of a handful of cars labeled 2005 that have the wrong front brakes. Subaru realized very quickly and made a 2005.5 model that incorporated the correct brakes and a few ecu tweaks. Honestly only a handful of cars were delivered the way you have it.
This sucks. I would be very weary of auto parts stores as they will have no experience with this and will most likely keep giving you 2005.5 and up brakes. Might be easier to order the brakes from an earlier car rather than your LGT.
But, dealer will get you the right part.
My OEM catalog says my normal sale price for a 2005 OEM front caliper is (omitted) delivered to you.
If you send me your vin# I can make absolutely sure I have the 2005 part and not the 2005.5 part. But I believe I have what you need for a bit less than your local dealer.
Thanks.
A quick check with the tape shows 12.3 to be about right. The caliper/bracket assembly I got from napa was for a smaller diameter- as well as thinner- rotor.
Thanks for running down those part numbers, Max- I appreciate it. Those are different than the ones they gave me- I'll look into them tomorrow. There's a brake parts warehouse in Minneapolis that thinks they have the right one coming in tomorrow or Friday, so I'm going to check that out too. Regardless, I'll make sure to bring this to conclusion. Nothing worse than searching, finding a thread that covers the same topic but has no final answer!!
EZSnow
#10: 05-11-2011, 05:59 PM
 Fat Charlie
Fat Charlie's Avatar
Car: 05 GT. Wagon. 5MT.
Send a private message to Fat Charlie Find all posts by Fat Charlie Reply With Quote
I went through the caliper issue in Feb. The Napa listing was a complete dud and I had to put the old brakes back on and drive to the dealership to get theirs. Napa can't claim it's a build date issue.
I got SS SS7983X pads, perfect match.
I got UP 880361 rotors, perfect match.
I got ATM 2201323L LF caliper, a dud.
The OE part numbers cross in Napa's system to those numbers, but it just ain't so. If you directly cross the OE pad and rotor numbers, you'd hope that directly crossing the caliper number would get you a caliper that fits around said pads and rotor, but it won't. A build date issue is one thing, but a part number cross is something entirely different.
And yes, mine's early too. I bought it in Feb 05. PM me your VIN and I'll see if I can come up with another number somewhere.
Fat Charlie
Find More Posts by Fat Charlie
#11: 05-12-2011, 04:48 AM
Can you rebuild?
 mdd
mdd's Avatar
Title: .:[~]:.
Car: 05 LGT 5EAT
Send a private message to mdd Find all posts by mdd Reply With Quote
I had frozen pistons on both of my front calipers recently. I rebuilt the calipers using some instructions I found on .org. The procedure is well laid out and easy to follow. The rebuilt calipers function perfectly. This option may save you some headaches....
mdd
Find More Posts by mdd
#12: 05-12-2011, 05:31 AM
 Max Capacity
Title: Gearhead
Wow, I haven't rebuilt a capiler since 1974. I had 2 out of 4 pistons freeze up on my 1970 Duster 340. I worked at a service station at the time and rebuilt the caliper while I was working. It was pretty easy once I pulled the old pistons out.
Just clean up the bore with some light sand paper if needed, not even sure I had too. Replace the boots and slide the piston into the boots and bores. Is it still the same?
Max Capacity
#13: 05-12-2011, 09:32 AM
 vr4Legacy
vr4Legacy's Avatar
Car: '06 Elantra (his) /'11 Outback (hers)
Send a private message to vr4Legacy Find all posts by vr4Legacy Reply With Quote
+1 Thank You!!
This doesn't pertain to me, but I agree. It's agrevating to hear SEARCH, SEARCH, SEARCH! So you do, then you find countless threads that start asking about a problem and either gets derailed, or just ends.
GL finding the correct caliper. I'm sure someone will find this thread in the future and be glad you replied back with your solution.
vr4Legacy
Find More Posts by vr4Legacy
#14: 05-12-2011, 10:47 AM
That's about right.
 mdd
mdd's Avatar
Title: .:[~]:.
Car: 05 LGT 5EAT
I used compressed air to push the pistons out with a block of wood to absorb the impact. I didn't bother with sandpaper on the bores as there was not any staining.I cleaned up the pistons, and removed the old slide pin grease. Since I had them all apart, I took them to a local guy I know and had them powdercoated while they were apart (only $50 ftw). The only tricky part was positioning the boots correctly (which the .org post I mentioned above does a good job of showing how to do this). The rebuilt calipers work really well, and look really good. Hopefully I won't have to mess with anything but slide pin grease and pads for the rest of the time I have the car. The rebuild kit I bought didn't include the sile pin boots, so i just reused the old ones.
mdd
#15: 05-12-2011, 11:41 AM
 EZSnow
Is yours also an early car? (mine is a 06/04 build date) What application did you buy a rebuild kit for?
EZSnow
Similar Threads
Cooling Fan Relay Issue now a recall campaign Opie Warranty Issues & Problems 367 04-03-2013 02:24 PM
Noisy fan Fishbulb Third Generation Subaru Outback (2004 – 2009) 5 12-09-2009 08:03 AM
Brembo Caliper Thread Stripped/Seized PeterJMC Suspension/Brakes 21 03-07-2009 05:29 PM
COBB (Stoptech) Front and Rear Install Thread praedet Suspension/Brakes 94 05-16-2007 08:39 AM
Cooling Fan Relay Service Program WVB-12 Jon [in CT] Warranty Issues & Problems 0 02-22-2007 04:09 PM
