Reload this Page Turbo rebuild question... after research.
#1: 06-08-2012, 03:30 PM
 LeggyMom
LeggyMom's Avatar
Car: '06 spec.B
Send a private message to LeggyMom Find all posts by LeggyMom Reply With Quote
So, I have about 97K on the clock and I think my turbo is starting to leak more oil than I'm comfortable with. I have done a bunch of research and have found that my stock VF40 turbo (that's what's in the '05 LGT, right?) is rebuildable! (right?) However, I haven't found anyone that likes a certain kind of rebuild kit or doesn't like another kind of rebuild kit. Also, I see kits for an IHI RHF5, is that the same turbo? One other thing I couldn't find was either a good writeup, or a good video on how to rebuild a turbo. Any additional help or suggestions would be appreciated.
LeggyMom
Find More Posts by LeggyMom
#2: 06-08-2012, 03:42 PM
 dr_sharp
Title: drives a hybrid now :(
Car: i ride a bike
Send a private message to dr_sharp Find all posts by dr_sharp Reply With Quote
Contact Bryan at BNR Supercars about rebuilding.
Are you single?
lol
dr_sharp
Find More Posts by dr_sharp
#3: 06-08-2012, 03:48 PM
 LeggyMom
LeggyMom's Avatar
Car: '06 spec.B
Originally Posted by dr_sharp View Post
Are you single?
LOL, no, at least my husband keeps telling me I'm not.
I'll give Bryan a call, but I'd also like to see a writeup or a video if anyone knows of one.
LeggyMom
#4: 06-08-2012, 05:57 PM
 reborngarcia1985
reborngarcia1985's Avatar
Car: 2007 subaru spec b
Send a private message to reborngarcia1985 Find all posts by reborngarcia1985 Reply With Quote
Check out http://www.theboostlab.com/ they do most of the rebuild here in the Tampa area and they know a thing or 2. I don't know where you may live but just trying to give you some info.
reborngarcia1985
Find More Posts by reborngarcia1985
#5: 06-09-2012, 05:42 AM
 Max Capacity
Max Capacity's Avatar
Car: 05GT Wagon 5MT stg2, 09 specB stg2
There are a lot of threads and some sticky's about turbo failures and what to do.
I went with a vf52 but you will need to have the car tuned for that turbo. Which by the way is a good idea for the car even in stock form. The factory timing map is not perfect.
I think a vf46 is another direct bolt on too.
If you plan to stay at oem power levels, I would still go with the vf52 and get the tuned by a tuner. The tune is the most important part in keeping the engine healthy for a long time.
Subaru won't admit to that, but there is a ton of proof on the forums.
Oh I also removed the studs from the up pipe and used bolts the dealership gave me to install the turbo, it was much easier then the studs.
You should also have the oem up pipe removed and a catless one installed. It's much safer the nthe catted one, Subaru even figured that one out in later model years.
254,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it.
Engine Build - Click Here
Max Capacity
#6: 06-09-2012, 02:51 PM
 LeggyMom
LeggyMom's Avatar
Car: '06 spec.B
Thanks for the info Max, I will start looking into the VF52. I already have a catless uppipe from an STi that my husband gave me when he upgraded his headers.
LeggyMom
#7: 06-09-2012, 06:03 PM
 Max Capacity
So it appears you know what's your doing, good.
I ordered my vf52 from Mike at www.AZPinstalls.com, I had it the next day.
They are a little more money than the bnr16g, but this is a direct bolt in like the bnr16g but you can remove the banjo filter on the back of the head and use the oem oil feed line.
You'll be happy you replaced the turbo before anything serious happens. I did too.
Max Capacity
