Reload this Page Starting Issue
#1: 05-18-2012, 11:18 PM
Starting Issue
 collier89139
collier89139's Avatar
Send a private message to collier89139 Find all posts by collier89139 Reply With Quote
1996 Subarue Legacy 2.2 AWD
177k miles
I was driving it and it was fine
came out of home depot and it started but I would push on the gas and nothing would happen
drove it 50 feet and it started shaking
turned off
turned on and was on for 30 seconds and stalled out
then would not start
turns over but nada
I took this pic Not sure if this is the issue
ANY THOUGHTS?
Thank You
collier89139
Find More Posts by collier89139
#2: 05-19-2012, 01:00 AM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
the rust? that dont matter. as long as the tb works. check coil pack.
Swagon_Wagon
Find More Posts by Swagon_Wagon
#3: 05-19-2012, 01:05 AM
 broknindarkagain
broknindarkagain's Avatar
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
We need more information.
Have you done any work to the car recently?
Is the check engine light on?
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#4: 05-19-2012, 10:29 AM
 collier89139
The check engine light has come on but it is older car so
I am wondering if it is a vacumm hose related to fuel line
no work has been done on the car as of late
collier89139
#5: 05-19-2012, 10:30 AM
 collier89139
@Swagon_Wagon The springs are loose and it seems that the cable going to this area is loose also
collier89139
#6: 05-19-2012, 08:21 PM
 Swagon_Wagon
car should still run and go. you just might not be able to open the butterflies all the way.
Swagon_Wagon
#7: 05-19-2012, 08:25 PM
 broknindarkagain
You need to find out why the check engine light is on. Hook a scanner up to it and that will point you in the right direction.
Just cause its an old car doesn't mean that light should be on.
-broknindarkagain
COME AND TAKE IT
broknindarkagain
#8: 05-19-2012, 11:05 PM
 collier89139
So now the car will crank and it appears the battery is good bc the radio is working and holding the stations
I have heard you can test the starter by hooking jumper cable directly to the starter screw and start it and it will tell you if you have a bad starter
ANY THOUGHTS?
I also wonder if it is the fuel pump?
collier89139
#9: 05-20-2012, 06:23 AM
 Stasis
Stasis's Avatar
Car: 1998 Legacy GTB
Send a private message to Stasis Find all posts by Stasis Reply With Quote
Have you had the code pulled as suggested first? The check engine light should not be on regardless.
Stasis
Find More Posts by Stasis
#10: 05-20-2012, 11:30 AM
 broknindarkagain
If it turns over then the starter is good.
Go pull the codes. Until then, nobody can help you.
-broknindarkagain
COME AND TAKE IT
broknindarkagain
