Reload this Page Second Gen Auto Trans Swap.
#1: 11-22-2011, 05:18 AM
 Xuenan
Xuenan's Avatar
Car: 02 Subaru Legacy L
Send a private message to Xuenan Find all posts by Xuenan Reply With Quote
I have a 95 legacy 4EAT. And am wanting to swap to either a 5MT or and sti 6. Has anyone done this before? If so what problems have u encountered any specific year/tran type i should get. Thanks
Xuenan
Find More Posts by Xuenan
#2: 11-22-2011, 08:28 AM
 broknindarkagain
broknindarkagain's Avatar
Title: ProGun & ProLife. So What
Car: 93BC - 95BD - 97BD - 98BG - 96BG
Send a private message to broknindarkagain Find all posts by broknindarkagain Reply With Quote
You will need :
Transmission
Rear diff
Front axles (I think)
Shift Linkage & Shifter
Transmission Mount & Cross Member
Clutch Kit
Flywheel
Slave Cylinder
Master Clutch Cylinder
Starter for MT
Clutch Pedal Assembly on its accessories
There is a pin on the ECU that you have to ground out as well. I dont remember what pin it is
That list is for the 5 speed.If you want to swap in the 6 speed, you will run into problems with the DCCD. I believe if you just leave the DCCD unplugged, it will lock it in a 50/50 torque split
broknindarkagain
Visit broknindarkagain's homepage!
Find More Posts by broknindarkagain
#3: 11-22-2011, 05:07 PM
 subikid90
subikid90's Avatar
Title: EJ22T
Car: 97 LGT & 98 LGT
Send a private message to subikid90 Find all posts by subikid90 Reply With Quote
Pin 83
The 6spd swap requires hubs and brembos also
subikid90
Find More Posts by subikid90
#4: 11-24-2011, 09:29 AM
 Xuenan
Xuenan's Avatar
[MENTION=36285]broknindarkagain[/MENTION] have u done this before?
Xuenan
#5: 11-24-2011, 09:52 AM
 broknindarkagain
No, but I know these cars good enough to be able to do it if I wanted to. I wouldn't buy an Automatic to begin with unless it was an amazing price.
broknindarkagain
#6: 11-24-2011, 01:38 PM
 jamal
jamal's Avatar
Car: 98 2.5GT
Send a private message to jamal Find all posts by jamal Reply With Quote
Originally Posted by subikid90 View Post
Pin 83
it doesn't. just an automatic driveshaft (shorter) and the right final drive. Also new front axles depending on the year of the transmission.
dccd is controlled by varying 0-5v to the trans. 0v is open, 5v is locked, so you could make yourself a switch or dial pretty easily.
jamal
Visit jamal's homepage!
Find More Posts by jamal
#7: 05-20-2012, 03:56 PM
 Swagon_Wagon
Swagon_Wagon's Avatar
Title: Joe The Shit Show
Car: 1997 Legacy GT Swagon
Send a private message to Swagon_Wagon Find all posts by Swagon_Wagon Reply With Quote
Pin 83 on my 97 traces back to the speedo. In my fsm. I got the car to turn over but it fires like hell. Sounds like I got a v8 at 150 rpm. What's going on. I know its not because I don't have the rest of the exhaust on as I have started the car for a sec with no headers. I have the headers on this time.
Things not hooked up are the reverse light switch. The neutral switch.
I have the pins 11and12 from b12 loopped into eachother with a piece of wire to act as if the tyranny was in p or r. That's when I first got the car to turn over.
Front o2 is plugged in to.
Sent from my Galaxy Tab using TapaTalk 2
Originally Posted by Stang70Fastback View Post
Clearly, the solution to shit breaking is to break more shit until the shit works again.
I'm Dumber Then I Seem, Remember That, I Won't.
Swagon_Wagon
Find More Posts by Swagon_Wagon
