Reload this Page Subaru Wrx sti Impreza Jdm EJ20T Engine Ver 3 swap?
#1: 10-11-2012, 02:36 AM
 beebs
beebs's Avatar
Car: FIRST CAR, 1998 Subaru Legacy GT
Send a private message to beebs Find all posts by beebs Reply With Quote
http://www.ebay.com/itm/271077078992...84.m1423.l2649
This doesnt include the transmission right?
would this be a good swap with my 2.5 L engine?
worth the money also?
Harness is cut though, does that mean i need to purchase another?
beebs
Find More Posts by beebs
#2: 10-11-2012, 09:40 AM
 monkeyposeur
monkeyposeur's Avatar
Car: 95 BK, 93 SS!
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
No, that doesn't include the trans. I was looking at ej20gs and there were quite a few that came with 5MT for about the same price. They are great engines though.
For that particular engine (or just about any turbo swap) the wiring will a lot of work. The wiring is slightly different on JDM engines from what I have been told, so you will probably have to use a standalone engine management system to get it to work. You could also try and find a complete harness and ecu but I don't know if that would be the best way to go. Keep looking on ebay, you can find the engine, trans, harness, and ecu as a package. Look at some EJ20Gs.
Because of the above mentioned issues, I would recommend doing a wrx swap if you have to have a turbo. Parts are a lot easier to find and plentiful. Keep in mind that you will need a complete new exhaust, a stronger transmission than your stock trans, new axles, maybe a custom driveshaft, etc. Read the turbo sticky at the top of the page if you haven't already.
I am slowly working on a wrx hybrid swap, the main difference is that I will be using a 22T block instead of the 205.
monkeyposeur
Find More Posts by monkeyposeur
