Go Back   Subaru Legacy Forums > Regional Forums > New England
Reload this Page Dragging front driver caliper?
#1: 09-11-2012, 09:07 AM
 rkhousman
rkhousman's Avatar
Car: 05 GRP LGT 5EAT Stg 1 Brentuned
Send a private message to rkhousman Find all posts by rkhousman Reply With Quote
I believe that my front driver side caliper is dragging due to the excessive brake dust on the wheel compared to the passenger side. Wondering if anyone has any other possibilities and also where I can get a replacement at a low cost due to limited funds. Any help would be appreciated.
rkhousman
Find More Posts by rkhousman
#2: 09-11-2012, 09:14 AM
 sachilles
Car: 05 LGT/02 wrx/impreza race car
Send a private message to sachilles Find all posts by sachilles Reply With Quote
excessive dust might show a problem. You need to pull the wheel off and check into the problem. First thing to check is to make sure the two sliders actually move. Next, examine the pistons in the caliper and make sure the boots are in good shape.
Other obvious signs of a problem is when you get out of the car, if the wheel in question is physically warmer than the opposite side.
sachilles
Find More Posts by sachilles
#3: 09-11-2012, 09:31 AM
 rkhousman
rkhousman's Avatar
I just did front brakes about 3k ago and everything seemed good but will def check again as I may have missed something.
rkhousman
#4: 09-11-2012, 01:09 PM
 sachilles
If you find the brake slides fine, check to see the wheel bearing is good. Sometimes as they go bad and loosen up, it allows the rotor to move out of plane of the calipers causing it to rub on the pads more than normal.
sachilles
#5: 09-11-2012, 01:25 PM
 jasejase
jasejase's Avatar
Title: <><><><><><><>
Car: S6 and Silverado. Sold Stage 3 specb.
Send a private message to jasejase Find all posts by jasejase Reply With Quote
This happened on my old grand-am. Swapped calipers. Still happened. Turned out to be a clogged, disintegrating brake line. Replaced the brake line at the caliper, and no more hang ups.
jasejase
Find More Posts by jasejase
#6: 09-11-2012, 05:02 PM
 rkhousman
rkhousman's Avatar
Took driver side apart and cleaned everything and lubed it and re assembled everything. Seems a bit better but will have to wait to see if the rim get coated in dust again more than the passenger side
rkhousman
